Based on some posts I've seen recently in the debian-devel mailing list, I think Kitware, the company behind VTK, ParaView, and CMake, has dedicated a person to improving the state of their software on Debian, so I think things will be improving in the future in Debian & Ubuntu.sgrogan wrote: ↑Sun Sep 23, 2018 6:53 pmI feel your pain. I wish vtk would split the package upstream, on Ubuntu, at least, python-vtk6 is a separate package.
Maybe this gives some clues: https://github.com/conda-forge/vtk-feedstock/issues/46?
ana(conda) windows packaging
- kkremitzki
Re: ana(conda) windows packaging
for now please pin tbb to version "2018.0.5". The problem here is really that the dependencies are not yet ready for the latest tbb. The package was split in tbb, tbb-devel and tbb4py. So every recipe using tbb in the build-section now also must specify the tbb-devel as additional dependency. I did this change for the occt-recipe, but somehow this didn't solve the issue for freecad.
So I think more packages have to be updated. As this is not going to happen until tomorrow please use the workaround to simple stay with tbb=2018.0.5. To update with pinned tbb please use something like this:
conda update --all tbb=2018.0.5 occt=7.3.*
@UR_ I had another look at your problem-description. To me this problem seems to be directly related to the switch to a spereated tbb / tbb-devel. So installing tbb-devel should fix this issue. But I am not sure if the build will work (binary incompatibility).
OK therefore in short all this channels are needed for now: conda-forge, freecad and freecad/label/dev? Will things stay like this in the (foreseeable) future or the freecad/label/dev channel is only a temporary thing?
Good to hear that.After some further testing it seems pip is fully working with the appimage.
In the past TBB was needed to enable parallelization routines (meshing related, boolean operations (with multiple arguments) ...) but now (by using newer OCCT) using TBB is not mandatory anymore to achieve that (multi-threading):Btw.: I do not have the problem on windows because there I do not build occt with tbb enabled. Does anyone know what the advantages of tbb are?
Is this ready yet to be exposed to (regular) end users? If yes i can add it.But subprocess commands are a bit more difficult to handle... Maybe you can add my pip module to the appimage to get it tested a bit more:
https://github.com/looooo/freecad_conda ... age.sh#L14
P.S. Will do some additional tests tomorrow and read the additional answers. And hopefully enable all what was discussed on Travis.
I will upload releases to conda-forge and weekly builds to freecad/label/dev. It would be also possible to upload to freecad directly. I used the dev-label only because some other projects do it the same way. (The freecad-channel is not yet used, but I will use it if the dependency-tree at some point breaks again, to have tempary fixed/updated packages available. This is necessary because conda-forge is a rolling-release -> unstable (see the current tbb-prolem))
I will try to get all packages build with tbb enabled. If this doesn't work out of the box, I will disable it for all plattforms. I guess the most difficult package will be vtk. I expect to see multiple different problems here: https://github.com/conda-forge/vtk-feedstock/pull/67triplus wrote: ↑Mon Sep 24, 2018 6:55 pm In the past TBB was needed to enable parallelization routines (meshing related, boolean operations (with multiple arguments) ...) but now (by using newer OCCT) using TBB is not mandatory anymore to achieve that (multi-threading):
gkv311 wrote: ↑
Mon Oct 24, 2016 9:48 am
[*] Intel TBB, optional for several modules.
It is NOT mandatory for activating parallel algorithms in OCCT,
but can be more efficient for this task then built-in OCCT parallelization routines (OSD_Parallel).
The question is also if all occt/vtk-dependent packages have to be updated. (netgen, smesh)
As a workaround I will use an old tbb for the next freecad-builds (Done by making freecad dependent on tbb directly). Locally this worked already on linux. I hope this works now as I am already a bit late for the sunday-build https://github.com/looooo/freecad-feeds ... 9230149247
so no binary incompatibilities? Are you compiling occt also by yourself? And what about vtk.
Hmm, difficult question. I haven't found a solution to install packages to a custom directory. Currently a directory shared with the system python is used to install all packages installed via the pipintegration tool. But I don't think I can come up with a solution very soon (see the packaging troubles, which need to be solved first)triplus wrote:Is this ready yet to be exposed to (regular) end users? If yes i can add it.
I'm just using these precompiled conda packages
(freecad_py3) C:\Users\aio>conda list
# packages in environment at C:\Users\aio\Miniconda3\envs\freecad_py3:
# Name Version Build Channel
blas 1.0 mkl
boost-cpp 1.67.0 vc14_0 [vc14] conda-forge
ca-certificates 2018.8.24 ha4d7672_0 conda-forge
certifi 2018.8.24 py36_1001 conda-forge
clangdev 5.0.0 flang_3 [flang vc14] conda-forge
coin3d 4.0.0 h037026a_4 conda-forge
curl 7.60.0 vc14_0 [vc14] conda-forge
cycler 0.10.0 py_1 conda-forge
eigen 3.3.5 he980bc4_1001 conda-forge
expat 2.2.5 vc14_0 [vc14] conda-forge
freecad 0.18b0 py36ha567227_4 conda-forge
freetype 2.8.1 vc14_0 [vc14] conda-forge
future 0.16.0 py36_2 conda-forge
gitdb2 2.0.4 py_0 conda-forge
gitpython 2.1.11 py_0 conda-forge
graphviz 2.38.0 h6538335_9 conda-forge
hdf4 4.2.13 vc14_0 [vc14] conda-forge
hdf5 1.10.1 vc14_2 [vc14] conda-forge
icc_rt 2017.0.4 h97af966_0
icu 58.2 vc14_0 [vc14] conda-forge
intel-openmp 2019.0 118
jpeg 9b vc14_2 [vc14] conda-forge
jsoncpp 1.8.1 vc14_0 [vc14] conda-forge
kiwisolver 1.0.1 py36he980bc4_2 conda-forge
krb5 1.14.6 vc14_0 [vc14] conda-forge
libflang 5.0.0 vc14_20180207 [vc14] conda-forge
libiconv 1.14 vc14_4 [vc14] conda-forge
libnetcdf 4.4.1.1 vc14_10 [vc14] conda-forge
libpng 1.6.34 vc14_0 [vc14] conda-forge
libssh2 1.8.0 vc14_2 [vc14] conda-forge
libtiff 4.0.9 vc14_0 [vc14] conda-forge
libxml2 2.9.5 vc14_1 [vc14] conda-forge
libxslt 1.1.32 vc14_0 [vc14] conda-forge
llvm-meta 6.0.1 0 conda-forge
llvmdev 4.0.0 default_0 [vc14] conda-forge
lz4-c 1.8.2 vc14_0 [vc14] conda-forge
matplotlib 2.2.2 py36_1 conda-forge
mkl 2019.0 118
mkl_fft 1.0.6 py36_0 conda-forge
mkl_random 1.0.1 py36_0 conda-forge
netgen 6.2.1804 py36he980bc4_3 conda-forge
numpy 1.15.1 py36ha559c80_0
numpy-base 1.15.1 py36h8128ebf_0
occt 7.3.0 h39117bb_0 conda-forge
openblas 0.2.20 vc14_8 [vc14] conda-forge
openmp 5.0.0 vc14_0 [vc14] conda-forge
openssl 1.0.2p hfa6e2cd_1000 conda-forge
pip 18.0 py36_1 conda-forge
pivy 0.6.4b2 py36_vc14_0 [vc14] conda-forge
pthreads-win32 2.9.1 vc14_1 [vc14] conda-forge
pybind11 2.2.4 py36he980bc4_1000 conda-forge
pyparsing 2.2.1 py_0 conda-forge
pyqt 5.6.0 py36h764d66f_7 conda-forge
pyside2 5.6.0a1 py36_vc14_2 [vc14] conda-forge
python 3.6.6 he025d50_0 conda-forge
python-dateutil 2.7.3 py_0 conda-forge
pytz 2018.5 py_0 conda-forge
qt 5.6.2 vc14_1 [vc14] conda-forge
setuptools 40.4.0 py36_1000 conda-forge
sip 4.18.1 py36h6538335_0 conda-forge
six 1.11.0 py36_1 conda-forge
smesh 8.3.0b0 py36h7731f85_9 conda-forge
smmap2 2.0.4 py_0 conda-forge
soqt 1.6.0a he980bc4_0 conda-forge
sqlite 3.22.0 vc14_0 [vc14] conda-forge
swig 3.0.12 2 conda-forge
tbb 2019.0 he980bc4_0 conda-forge
tbb-devel 2019.0 he980bc4_0 conda-forge
tornado 5.1.1 py36hfa6e2cd_0 conda-forge
vc 14 0 conda-forge
vs2015_runtime 14.0.25420 0 conda-forge
vtk 8.1.1 py36_vc14h99a48a5_200 [vc14] conda-forge
wheel 0.31.1 py36_1001 conda-forge
wincertstore 0.2 py36_1002 conda-forge
xerces-c 3.2.0 vc14_0 [vc14] conda-forge
zlib 1.2.11 vc14_0 [vc14] conda-forge
so it seems the new tbb is compatible with the old one (At least for freecad on windows). But anyway I will try to get vtk and occt updated before I release the pinning of the freecad-feedstock again.
Running tests with the GUI I see some failing tests which are not reported. Maybe someone can report them so we can work on these issues.
@triplus:
the new build is available. Creating an Appimage with my script works fine, but still the size is about 280Mb. And finally:
This would be welcome, also for Win on conda. For the PY2 builds I package only a small sub-set of VTK that FreeCAD needs, but for conda such a stripped down package is limited. Splitting the package would go a long way. Some CMake help would help on all OS's.kkremitzki wrote: ↑Sun Sep 23, 2018 9:31 pm Based on some posts I've seen recently in the debian-devel mailing list, I think Kitware, the company behind VTK, ParaView, and CMake, has dedicated a person to improving the state of their software on Debian, so I think things will be improving in the future in Debian & Ubuntu.
Do you have a link to the mailing list? I might sign up and express my opinion.
"fight the good fight"
I only get one
File "C:\Users\Chris\GitHub\FreeCAD_0.18.14802_Conda_Py3QT5-WinVS2015_x64\bin\lib\unittest\case.py", line 59, in testPartExecutor
yield
File "C:\Users\Chris\GitHub\FreeCAD_0.18.14802_Conda_Py3QT5-WinVS2015_x64\bin\lib\unittest\case.py", line 605, in run
testMethod()
File "C:\Users\Chris\GitHub\FreeCAD_0.18.14802_Conda_Py3QT5-WinVS2015_x64\Mod\Test\TestPythonSyntax.py", line 44, in testAll
test_python_syntax(mod_dir, self.whitelist)
File "C:\Users\Chris\GitHub\FreeCAD_0.18.14802_Conda_Py3QT5-WinVS2015_x64\Mod\Test\TestPythonSyntax.py", line 19, in test_python_syntax
ast.parse(py_file.read())
File "C:\Users\Chris\GitHub\FreeCAD_0.18.14802_Conda_Py3QT5-WinVS2015_x64\bin\lib\encodings\cp1252.py", line 23, in decode
return codecs.charmap_decode(input,self.errors,decoding_table)[0]
UnicodeDecodeError: 'charmap' codec can't decode byte 0x81 in position 30763: character maps to <undefined>
OS: Windows 7
Version: 0.18.14802 (Git)
Hash: dfd3d86b227099bab3649624507fcb205cdd93a2
Python version: 3.6.6
Qt version: 5.6.2
This is from the portable builds, and I DO NOT regularly update the conda env I package them from. I will test with the new env. conda is very good for me in this respect.
