Is it possible to set the freecad-version manually?
Edit: currently used commit: https://github.com/conda-forge/freecad- ... /meta.yamltriplus wrote:
As part of the build process on Launchpad, a source tarball is created (effectively throwing away the git info) then Launchpad builds from the tarball.
Yup. The link you posted a while ago about triggering Lanchpad from Travis seems promising. I just haven't found the time to investigate.
See Here:https://blog.notfoss.com/posts/get-tota ... ithub-api/
thanks for the information. I will first try to setup a fork of the freecad-feedstock which pulls packages to the freecad-channel (so conda-forge will be more like a release-channel and the freecad-channel will contain the more recent builds without the need to build the packages locally. For the packages of freecad-channel we can use git directly and therefor version-info should be available.sgrogan wrote:See Here:https://blog.notfoss.com/posts/get-tota ... ithub-api/
Then we can build our own version.h file and inject it into the source tar.gz somehow.
I guess conda-build is not yet totally ready for MSCVC2017.zbigg wrote: ↑Wed Aug 08, 2018 9:05 am hi guys,
I see 'daily' builds appear constantly but I personally cant compile v.018 on MSVC2017 x64 with the Libs 11.5.3 from sgrogan
Could anybody advice where/how move on with this - either w/conda or cmake ?
Can I use /just compiled/ QT 5.11.1 ?
Should I build any individual deps ?
