Thanks wmayer, I had seen your other post about this.wmayer wrote: ↑Fri Sep 14, 2018 12:31 pmWe should try to use QtWebEngine as an alternative since QtWebkit is not part of the official Qt source tarball but in a separate git repo. In a branch on github I worked on the port but it doesn't work stable ATM. Unfortunately, I could not use a debug Qt version as I never succeeded in creating the debug dll of QtWebEngine -- it also stopped at linking time.
If we could use QtWebEngine alternatively this would also simplify life for macOS on travis.
As this doesn't seem easy, I'm investigating if I can build QTWebKit compatible with our Conda QT 5.6.
Basically what Peterl94 did for OSX on Travis.
It looks like someone was able to build WebKit for OSX on Conda but not for linux or win.
I see lots of failed attempts with VS2015, and one that succeeded with mysys2.
Is there anything we can try to do to support the port to QTWebEngine? I'm pretty sure I could build your webengine branch with conds deps, but we have no debug libs (yet)
