Hi everyone,
when I launch freecad-daily appimage from terminal I have this messages.
Not sure if the problem is from linux deepin(based on debian) or from freecad.
Perhaps Is that what provokes that when I hover the mouse pointer over the tes¡xt options at bars and menus the selected part dissapear til I select a diferent part.
I attached 2 images while hovering mouse pointer over the Edit menu and unduo option inside the edit menu.(top left) teext become white colour
./FreeCAD-0.17.git201708102146.glibc2.17-x86_64.AppImage
FreeCAD 0.17, Libs: 0.17R11751 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2017
** (freecad-daily:11451): WARNING **: Pixbuf theme: Cannot load pixmap file /usr/share/themes/deepin/gtk-2.0/assets/trough-progressbar.png: No se pudo reconocer el formato de imagen del archivo «/usr/share/themes/deepin/gtk-2.0/assets/trough-progressbar.png»
(freecad-daily:11451): GdkPixbuf-CRITICAL **: gdk_pixbuf_get_width: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
(freecad-daily:11451): GdkPixbuf-CRITICAL **: gdk_pixbuf_get_height: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
** (freecad-daily:11451): WARNING **: Invalid borders specified for theme pixmap:
/usr/share/themes/deepin/gtk-2.0/assets/trough-progressbar.png,
borders don't fit within the image
(freecad-daily:11451): GdkPixbuf-CRITICAL **: gdk_pixbuf_get_n_channels: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
(freecad-daily:11451): GdkPixbuf-CRITICAL **: gdk_pixbuf_get_pixels_with_length: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
(freecad-daily:11451): GdkPixbuf-CRITICAL **: gdk_pixbuf_get_rowstride: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
** (freecad-daily:11451): WARNING **: Pixbuf theme: Cannot load pixmap file /usr/share/themes/deepin/gtk-2.0/assets/tab-bottom-active.png: No se pudo reconocer el formato de imagen del archivo «/usr/share/themes/deepin/gtk-2.0/assets/tab-bottom-active.png»
/usr/share/themes/deepin/gtk-2.0/assets/tab-bottom-active.png,
... more similar under this ones
[solved] (freecad-daily:7665): GdkPixbuf-CRITICAL
- undo option hovering
- DeepinScreenshot_20170811190341.png (134.67 KiB) Viewed 2810 times
- Edit menu hovering
- DeepinScreenshot_20170811190336.png (130.37 KiB) Viewed 2810 times
Reason: added "[Solved]" to the title
Re: (freecad-daily:7665): GdkPixbuf-CRITICAL
Such messages are usually more or less harmless and are highly likely related to custom theme you use (Deepin theme).
P.S. Try out default theme and see if that removes the messages.
Hi triplus,
the default theme is deepin, So I don't know.
I overlooked and read you use Debian. Sorry for that. Well does Deepin by any chance have more themes available by default? To try out a different one? As this looks like an issue with default Deepin theme to me. But all in all do you see any real issues when using FreeCAD besides seeing the messages in terminal (as i am guessing no)?jacquesclouseau wrote: ↑Sat Aug 12, 2017 8:28 pm Hi triplus,
triplus you are right,
I have just checked, not a freecad problem but a deepin theme one.
I will post it at deepin forum.
No problem and a good thing we have narrowed it down a bit further.jacquesclouseau wrote: ↑Sun Aug 13, 2017 1:04 pm triplus you are right,
Hi triplus,
To narrow the problem furthermore, I tried a PPA It worked!
Even being a debian based distro, I installed the freecad-daily and freecad-daily-doc, and problem is not present, text is display is correct.
So the problem only appears when using the appimage.
