[Solved] Failed compilation on Debian
Re: [Solved] Failed compilation on Debian
Thank for the hint.
Re: Failed compilation on Debian
On a fresh Debian Stretch OCCT 7.2 self compiled but installed on /opt/local/FreeCAD-0.17/ I run in similar trouble. Cmake and compiling of FreeCAD runs smooth, FreeCAD starts but on a change to Part WB there is a libTK...so missing.
For me it is
this one helped. AFAIK I did not disable any RPATH option.wmayer wrote: ↑Tue Sep 05, 2017 5:56 pm Could it be that you have the RPATH option disabled when building OCC? In this case you can use LD_LIBRARY_PATH and set it to:Code: Select all
export LD_LIBRARY_PATH=~/softwares/occt/lib:$LD_LIBRARY_PATH
For me it is
export LD_LIBRARY_PATH=/opt/local/FreeCAD-0.17/lib:$LD_LIBRARY_PATH
