Upgrade Win to PY2.7.14
sgrogan
Postby sgrogan » Sat Jan 27, 2018 7:09 pm
In response to issue #3295
I have been able to build PY2.7.14 release and debug versions and attempt to add to the Libpack. https://github.com/sgrogan/FreeCAD/rele ... py_2.17.14 (debug build for FreeCAD won't work due to VTK and other stuff)
I get the following when starting FreeCAD (Start WB is my default)
'module' object has no attribute 'openssl_md_meth_names'
I suspect some conflict with mysql/ssl/mariadb due to using the pre-compiled QT 4.8.7(VS2013) binaries from here: https://www.npcglib.org/~stathis/blog/p ... d-qt4-qt5/
I tried to profile with depends but didn't see anything obvious to me.
Any suggestions?
"fight the good fight"
sgrogan
Re: Upgrade Win to PY2.7.14
Postby sgrogan » Thu Feb 01, 2018 11:11 pm
I found this: https://github.com/Homebrew/legacy-home ... sues/36346
so I ran
>>> print _hashlib.__file__
C:\Users\Chris\GitHub\FCAutoBuild\var\build_x64_VC12\bin\DLLs\_hashlib.pyd
I haven't updated these file since peterl94's original VS2013 libpacks. Do I need to update them? And from which package are they created from? Still this symbol should exist in the older python they came from?
Site Admin
Postby wmayer » Fri Feb 02, 2018 11:48 am
All what I have replaced in the libpack are two files:
* the python27.dll in the bin directory
* patchlevel.h in the include directory (this is required when running cmake so that interpreter version matches with the C defines)
I haven't replaced any other files i.e. I left all the .pyd files. And so far I haven't noticed any problems.
Not sure but do you lack of the file _ssl.pyd?
All these files are part of the Python sources. When loading the .sln file into VS you should get a list of all targets.
sgrogan
Postby sgrogan » Fri Feb 02, 2018 12:20 pm
wmayer wrote: Fri Feb 02, 2018 11:48 am * the python27.dll in the bin directory
Ahh, I have replaced everything, all the headers, libs, and .py files. I will try to build the addition dll's and replace them as well.
Thanks as always for the help.
Site Admin
Postby wmayer » Fri Feb 02, 2018 12:56 pm
sgrogan wrote: Fri Feb 02, 2018 12:20 pm
It might be safer to replace all Python related files because there are also a lot of changes inside the .py files.
sgrogan
Postby sgrogan » Fri Feb 02, 2018 5:53 pm
wmayer wrote: Fri Feb 02, 2018 12:56 pm It might be safer to replace all Python related files because there are also a lot of changes inside the .py files.
Is it desirable to include the debug (and pdb's) versions in the libpack of the .pyd's?
sgrogan
Postby sgrogan » Fri Feb 02, 2018 6:16 pm
'openssl_md_meth_names' was added to _hashlib.pyd in Python 2.7.9, so this explains the error.
It seems when building _hashlib.pyd the Python project tries to build it's own openssl as part of the process. I think I now understand @peterl94's patches mentioned in the issue tracker.
Site Admin
Postby wmayer » Fri Feb 02, 2018 7:10 pm
sgrogan wrote: Fri Feb 02, 2018 5:53 pm
If they take too much space you can omit them.
sgrogan
Postby sgrogan » Sat Feb 24, 2018 4:07 pm
I am almost there.
Only _sqlite3.pyd remains. I'm linking against sqlite3.lib (version 3.8.5) in the 11.x series libpacks, but I get the following.
1>------ Build started: Project: _sqlite3, Configuration: Release x64 ------
1>LINK : warning LNK4001: no object files specified; libraries used
1>LINK : error LNK2001: unresolved external symbol _DllMainCRTStartup
1>C:\Users\Chris\Downloads\Python-2.7.14-copy\PCBuild\\amd64\_sqlite3.pyd : fatal error LNK1120: 1 unresolved externals
Any ideas?
Site Admin
Postby wmayer » Mon Feb 26, 2018 12:36 pm
I never tried to build the _sqlite3 module and I don't think that we really need it.
