I deleted my build directory and started from scratch (as I did last week with no difference in the failure). This time I got a different error which yielded
one Google hit:
https://forum.freecadweb.org/viewtopic.php?f=10&t=16229
From PrzemoF's cmake switches, I added '-DFREECAD_USE_EXTERNAL_SMESH=TRUE' and got to 60% before this failure:
In file included from /usr/lib64/oce-0.18/../../include/oce/NCollection_EBTree.hxx:23,
from /usr/lib64/oce-0.18/../../include/oce/BRepMesh.hxx:34,
from /usr/lib64/oce-0.18/../../include/oce/BRepMesh_VertexInspector.hxx:22,
from /usr/lib64/oce-0.18/../../include/oce/BRepMesh_VertexTool.hxx:20,
from /usr/lib64/oce-0.18/../../include/oce/BRepMesh_DataStructureOfDelaun.hxx:19,
from /usr/lib64/oce-0.18/../../include/oce/BRepMesh_FastDiscret.hxx:20,
from /usr/lib64/oce-0.18/../../include/oce/BRepMesh_IncrementalMesh.hxx:20,
from /home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp:35:
/usr/lib64/oce-0.18/../../include/oce/TCollection_Sequence.lxx: In copy constructor ‘TColStd_SequenceOfInteger::TColStd_SequenceOfInteger(const TColStd_SequenceOfInteger&)’:
/usr/lib64/oce-0.18/../../include/oce/TColStd_SequenceOfInteger.hxx:108:30: warning: base class ‘class TCollection_BaseSequence’ should be explicitly initialized in the copy constructor [-Wextra]
#define TCollection_Sequence TColStd_SequenceOfInteger
/usr/lib64/oce-0.18/../../include/oce/TColStd_SequenceOfInteger.hxx:108:30: note: in definition of macro ‘TCollection_Sequence’
In file included from /usr/lib64/oce-0.18/../../include/oce/GCPnts_TangentialDeflection.hxx:15,
from /usr/lib64/oce-0.18/../../include/oce/BRepMesh_GeomTool.hxx:20,
from /usr/lib64/oce-0.18/../../include/oce/BRepMesh_Delaun.hxx:28,
from /usr/lib64/oce-0.18/../../include/oce/BRepMesh_FastDiscret.hxx:29,
/usr/lib64/oce-0.18/../../include/oce/TCollection_Sequence.lxx: In copy constructor ‘TColgp_SequenceOfPnt::TColgp_SequenceOfPnt(const TColgp_SequenceOfPnt&)’:
/usr/lib64/oce-0.18/../../include/oce/TColgp_SequenceOfPnt.hxx:109:30: warning: base class ‘class TCollection_BaseSequence’ should be explicitly initialized in the copy constructor [-Wextra]
#define TCollection_Sequence TColgp_SequenceOfPnt
/usr/lib64/oce-0.18/../../include/oce/TColgp_SequenceOfPnt.hxx:109:30: note: in definition of macro ‘TCollection_Sequence’
In file included from /usr/lib64/oce-0.18/../../include/oce/GCPnts_TangentialDeflection.hxx:16,
/usr/lib64/oce-0.18/../../include/oce/TCollection_Sequence.lxx: In copy constructor ‘TColStd_SequenceOfReal::TColStd_SequenceOfReal(const TColStd_SequenceOfReal&)’:
/usr/lib64/oce-0.18/../../include/oce/TColStd_SequenceOfReal.hxx:109:30: warning: base class ‘class TCollection_BaseSequence’ should be explicitly initialized in the copy constructor [-Wextra]
#define TCollection_Sequence TColStd_SequenceOfReal
/usr/lib64/oce-0.18/../../include/oce/TColStd_SequenceOfReal.hxx:109:30: note: in definition of macro ‘TCollection_Sequence’
In file included from /usr/include/smesh/SMESHDS_Mesh.hxx:31,
from /usr/include/smesh/SMESH_subMesh.hxx:32,
from /usr/include/smesh/SMESH_2D_Algo.hxx:34,
from /usr/include/smesh/SMESH_Gen.hxx:40,
from /home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp:43:
/usr/include/smesh/SMDS_Mesh.hxx: At global scope:
/usr/include/smesh/SMDS_Mesh.hxx:501:55: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
static int CheckMemory(const bool doNotRaise=false) throw (std::bad_alloc);
In file included from /usr/include/smesh/SMESH_Gen.hxx:42,
/usr/include/smesh/SMESH_Mesh.hxx:113:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:117:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/SMESH_Mesh.hxx:121:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/SMESH_Mesh.hxx:133:48: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
const std::list<SMESHDS_Command*> & GetLog() throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:135:19: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
void ClearLog() throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:144:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/SMESH_Mesh.hxx:147:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/SMESH_Mesh.hxx:150:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/SMESH_Mesh.hxx:155:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/SMESH_Mesh.hxx:162:57: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
GetSubMeshUsingHypothesis(SMESHDS_Hypothesis * anHyp) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:180:40: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
void SetAutoColor(bool theAutoColor) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:182:23: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
bool GetAutoColor() throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:199:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/SMESH_Mesh.hxx:201:36: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
void ExportDAT(const char *file) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:202:36: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
void ExportUNV(const char *file) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:203:56: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
void ExportSTL(const char *file, const bool isascii) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:205:17: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int NbNodes() throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:207:22: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int Nb0DElements() throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:209:55: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int NbEdges(SMDSAbs_ElementOrder order = ORDER_ANY) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:211:55: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int NbFaces(SMDSAbs_ElementOrder order = ORDER_ANY) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:213:59: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int NbTriangles(SMDSAbs_ElementOrder order = ORDER_ANY) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:215:61: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int NbQuadrangles(SMDSAbs_ElementOrder order = ORDER_ANY) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:217:20: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int NbPolygons() throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:219:57: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int NbVolumes(SMDSAbs_ElementOrder order = ORDER_ANY) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:221:56: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int NbTetras(SMDSAbs_ElementOrder order = ORDER_ANY) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:223:55: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int NbHexas(SMDSAbs_ElementOrder order = ORDER_ANY) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:225:58: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int NbPyramids(SMDSAbs_ElementOrder order = ORDER_ANY) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:227:56: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int NbPrisms(SMDSAbs_ElementOrder order = ORDER_ANY) throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:229:23: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int NbPolyhedrons() throw(SALOME_Exception);
/usr/include/smesh/SMESH_Mesh.hxx:231:19: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
int NbSubMesh() throw(SALOME_Exception);
In file included from /home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp:43:
/usr/include/smesh/SMESH_Gen.hxx:69:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/SMESH_Gen.hxx: In constructor ‘SMESH_Gen::TAlgoStateError::TAlgoStateError()’:
/usr/include/smesh/SMESH_Gen.hxx:117:25: warning: ‘SMESH_Gen::TAlgoStateError::_algoDim’ will be initialized after [-Wreorder]
int _algoDim;
/usr/include/smesh/SMESH_Gen.hxx:116:25: warning: ‘const SMESH_Algo* SMESH_Gen::TAlgoStateError::_algo’ [-Wreorder]
const SMESH_Algo* _algo;
/usr/include/smesh/SMESH_Gen.hxx:120:5: warning: when initialized here [-Wreorder]
TAlgoStateError(): _algoDim(0),_algo(0),_name(SMESH_Hypothesis::HYP_OK) {}
/usr/include/smesh/SMESH_Gen.hxx:116:25: warning: ‘SMESH_Gen::TAlgoStateError::_algo’ will be initialized after [-Wreorder]
/usr/include/smesh/SMESH_Gen.hxx:115:25: warning: ‘TAlgoStateErrorName SMESH_Gen::TAlgoStateError::_name’ [-Wreorder]
TAlgoStateErrorName _name;
In file included from /home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp:44:
/usr/include/smesh/StdMeshers_MaxLength.hxx: At global scope:
/usr/include/smesh/StdMeshers_MaxLength.hxx:39:33: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
void SetLength(double length) throw(SALOME_Exception);
In file included from /home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp:45:
/usr/include/smesh/StdMeshers_LocalLength.hxx:43:33: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/StdMeshers_LocalLength.hxx:44:39: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
void SetPrecision(double precision) throw(SALOME_Exception);
In file included from /home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp:46:
/usr/include/smesh/StdMeshers_NumberOfSegments.hxx:51:77: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
const std::vector<double>& BuildDistributionExpr( const char*, int, int ) throw ( SALOME_Exception );
/usr/include/smesh/StdMeshers_NumberOfSegments.hxx:52:91: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
const std::vector<double>& BuildDistributionTab( const std::vector<double>&, int, int ) throw ( SALOME_Exception );
/usr/include/smesh/StdMeshers_NumberOfSegments.hxx:59:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
throw (SALOME_Exception);
/usr/include/smesh/StdMeshers_NumberOfSegments.hxx:81:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/StdMeshers_NumberOfSegments.hxx:96:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/StdMeshers_NumberOfSegments.hxx:104:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/StdMeshers_NumberOfSegments.hxx:116:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/StdMeshers_NumberOfSegments.hxx:124:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/StdMeshers_NumberOfSegments.hxx:134:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/StdMeshers_NumberOfSegments.hxx:142:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/StdMeshers_NumberOfSegments.hxx:154:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/StdMeshers_NumberOfSegments.hxx:162:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
In file included from /home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp:47:
/usr/include/smesh/StdMeshers_AutomaticLength.hxx:58:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/StdMeshers_AutomaticLength.hxx:64:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/StdMeshers_AutomaticLength.hxx:77:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
In file included from /home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp:50:
/usr/include/smesh/StdMeshers_Deflection1D.hxx:41:36: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
void SetDeflection(double value) throw(SALOME_Exception);
In file included from /home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp:51:
/usr/include/smesh/StdMeshers_Arithmetic1D.hxx:46:53: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
void SetLength(double length, bool isStartLength) throw(SALOME_Exception);
In file included from /home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp:52:
/usr/include/smesh/StdMeshers_MaxElementArea.hxx:42:35: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
void SetMaxArea(double maxArea) throw(SALOME_Exception);
In file included from /usr/include/smesh/StdMeshers_Regular_1D.hxx:35,
from /home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp:53:
/usr/include/smesh/StdMeshers_FixedPoints1D.hxx:47:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/usr/include/smesh/StdMeshers_FixedPoints1D.hxx:50:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
In file included from /home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp:57:
/usr/include/smesh/StdMeshers_LengthFromEdges.hxx:45:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]
/home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp: In member function ‘Mesh::MeshObject* MeshPart::Mesher::createMesh() const’:
/home/mike/free-cad-code/src/Mod/MeshPart/App/Mesher.cpp:314:37: error: ‘get’ is not a member of ‘SMESH_Gen’
SMESH_Gen* meshgen = SMESH_Gen::get();
make[2]: *** [src/Mod/MeshPart/App/CMakeFiles/MeshPart.dir/build.make:163: src/Mod/MeshPart/App/CMakeFiles/MeshPart.dir/Mesher.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:2489: src/Mod/MeshPart/App/CMakeFiles/MeshPart.dir/all] Error 2
make: *** [Makefile:130: all] Error 2
