Win "Daily builds"
Re: Win "Daily builds"
[Arch] ArchRebar, Error: when change "Custom Spacing" property.
I added your fix.https://github.com/FreeCAD/FreeCAD/pull ... 3c99ffe52f
[Spreadsheet]: Cannot change text alignment and text properties.
<class 'TypeError'>: style must be either set or string, not str
Thanks for testing. Please post further problems in the py3-topic: https://forum.freecadweb.org/viewtopic.php?f=10&t=12534
edit: done: https://github.com/FreeCAD/FreeCAD/pull ... 55c61ae736
I will try to solve this. It's a unicode/bytes problem.chakkree wrote:[Spreadsheet]: Cannot change text alignment and text properties.
First "official" update is available. https://github.com/FreeCAD/FreeCAD/rele ... g/0.18_pre
@looo's fixes haven't been merged yet, so this is more a test of the update process.
I would welcome some text to add to the github page. I feel that I am too much in the middle of it to explain clearly
Squash those bugs
"fight the good fight"
@looo what is the correct version of netgen to use w/FreeCAD on Conda. I think I have broken netgen support for FreeCAD with an unintended update.
yes, I tried to make pyocct work, and therefor added a patch for the netgen build. This build was not compatible with freecad.
the latest netgen build on conda-forge works again.
also it would be nice if you could try to use the external smesh. there is a package on conda-forge but this one has problems with pyocct. so better use smesh from the cad-channel. I will update the conda-forge smesh once vtk for osx is available. currently I cant build smesh for osx because of troubles with the anaconda vtk...
also there are some cmake settings necessary to build flatmesh and use the external smesh.
This one?
conda install -c conda-forge netgen
yes this one should be ok. should be build number: 3
https://anaconda.org/conda-forge/netgen ... _3.tar.bz2
Up
Do exist windows daily builds now or not?
Up
Here, also reachable from the Download page as Development builds: https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
