xcb problem when starting new build of freecad
Chris_G
Re: xcb problem when starting new build of freecad
Postby Chris_G » Mon Jul 09, 2018 3:00 pm
nemesis wrote:
Mon Jul 09, 2018 2:49 pm
How did you enable Wayland with KDE?
I don't find clear informations on wayland / X11 ... I'm on Debian 9.4
On Ubuntu, I had to install plasma-workspace-wayland, and then I get a dropdown menu at the bottom of the login screen to choose the type of session.
NormandC
Postby NormandC » Fri Jul 13, 2018 3:19 am
Out of curiosity, do you all have AMD (ATI) graphics? Is it recent hardware?
Chris_G
Postby Chris_G » Fri Jul 13, 2018 8:05 am
I use an AMD RX580, with the open-source AMDGPU driver.
nemesis
Postby nemesis » Sat Aug 04, 2018 2:47 pm
lspci :
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Broadway PRO [Mobility Radeon HD 5850]
that's a 2010 Imac 27"
nemesis
Postby nemesis » Mon Aug 06, 2018 12:52 pm
Damned, Wayland is just a mess on my Debian, it's logging out without visible explanation...
I'm will stay with the "LIBGL_DRI3_DISABLE=true" tip for the moment.
anyway thanks for the hint!
Chris_G
Postby Chris_G » Mon Aug 06, 2018 1:05 pm
It's a bit buggy on Kubuntu also, so I use the "LIBGL_DRI3_DISABLE=true" too ...
Postby Kunda1 » Tue Dec 18, 2018 11:36 am
issue #3717
Are there any updates for this bug or is there just a workaround ?
dmalham
Postby dmalham » Mon Dec 02, 2019 3:40 pm
I came across this problem when installing Freecad on a new Ubuntu system, having always run it in a Mac Powerbook before with no problems. I knocked up a script file to implement the work around given in this thread. That worked but Freecad grumbled a bit about a missing Webgui module - it still worked, but...
Anyway, I searched for a solution to that and came across
https://techoverflow.net/2018/06/03/how ... ntu-18-04/
The interesting thing is that this fixes both the missing Webgui AND the original "failed to create drawable' problems so it seems that Freecad for Ubuntu should be installed not from the Ubuntu repositories but from the freecad-stable PPA:
Dave
vocx
Postby vocx » Tue Dec 03, 2019 4:45 am
... so it seems that Freecad for Ubuntu should be installed not from the Ubuntu repositories but from the freecad-stable PPA:
Yes, in general, the FreeCAD in the Ubuntu Universe repository is not up to date. We prefer the stable or daily versions that you can find in the PPA. See Install on Unix.
