Beta 18/ no Draft WB appears
Leatherman
Postby Leatherman » Sat Apr 14, 2018 2:06 am
after my upgrade today, I'm facing strange problems. For example my Draft WB appears to be empty. Somebody has an idea what is going on?
May be something went wrong by installing. In this case could somebody tell me how I should go about it?
Thanks
OS: Ubuntu 16.04.4 LTS
Version: 0.18.13524 (Git)
Build type: None
Hash: 04a7f566fe71dcad8fda92af2f467d3cc211a372
Python version: 2.7.12
OCC version: 7.2.0
Locale: English/India (en_IN)
Screenshot from 2018-04-14 07-27-50.png (192.85 KiB) Viewed 754 times
Re: Beta 18/ no Draft WB appears
Postby chrisb » Sat Apr 14, 2018 6:02 am
We have seen this recently in different places. Deleting the config files seems to help. Don't forget to select the correct Mouse Model after doing so.
Leatherman
Postby Leatherman » Sat Apr 14, 2018 1:50 pm
This didn'd do the trick :(
Started from the command line and got following text:
andre@Andre-PC:~/.FreeCAD$ freecad-daily
FreeCAD 0.18, Libs: 0.18R13524 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
invalid syntax (DraftTools.py, line 1617)
Error: Initializing one or more of the Draft modules failed, Draft will not work as expected.
Unknown command 'Draft_Line'
Unknown command 'Draft_Wire'
Unknown command 'Draft_Circle'
Unknown command 'Draft_Arc'
Unknown command 'Draft_Ellipse'
Unknown command 'Draft_Polygon'
Unknown command 'Draft_Rectangle'
Unknown command 'Draft_Text'
Unknown command 'Draft_Dimension'
Unknown command 'Draft_BSpline'
Unknown command 'Draft_Point'
Unknown command 'Draft_ShapeString'
Unknown command 'Draft_Facebinder'
Unknown command 'Draft_BezCurve'
Unknown command 'Draft_Label'
Unknown command 'Draft_Move'
Unknown command 'Draft_Rotate'
Unknown command 'Draft_Offset'
Unknown command 'Draft_Trimex'
Unknown command 'Draft_Upgrade'
Unknown command 'Draft_Downgrade'
Unknown command 'Draft_Scale'
Unknown command 'Draft_Edit'
Unknown command 'Draft_WireToBSpline'
Unknown command 'Draft_AddPoint'
Unknown command 'Draft_DelPoint'
Unknown command 'Draft_Shape2DView'
Unknown command 'Draft_Draft2Sketch'
Unknown command 'Draft_Array'
Unknown command 'Draft_PathArray'
Unknown command 'Draft_Clone'
Unknown command 'Draft_Drawing'
Unknown command 'Draft_Mirror'
Unknown command 'Draft_Stretch'
Unknown command 'Draft_VisGroup'
Unknown command 'Draft_Heal'
Unknown command 'Draft_FlipDimension'
Unknown command 'Draft_ToggleConstructionMode'
Unknown command 'Draft_ToggleContinueMode'
Unknown command 'Draft_Slope'
Unknown command 'Draft_SetWorkingPlaneProxy'
Unknown command 'Draft_AddConstruction'
Unknown command 'Draft_ApplyStyle'
Unknown command 'Draft_ToggleDisplayMode'
Unknown command 'Draft_AddToGroup'
Unknown command 'Draft_SelectGroup'
Unknown command 'Draft_SelectPlane'
Unknown command 'Draft_ShowSnapBar'
Unknown command 'Draft_ToggleGrid'
Unknown command 'Draft_AutoGroup'
Unknown command 'Draft_UndoLine'
Unknown command 'Draft_FinishLine'
Unknown command 'Draft_CloseLine'
Unknown command 'Draft_Snap_Lock'
Unknown command 'Draft_Snap_Midpoint'
Unknown command 'Draft_Snap_Perpendicular'
Unknown command 'Draft_Snap_Grid'
Unknown command 'Draft_Snap_Intersection'
Unknown command 'Draft_Snap_Parallel'
Unknown command 'Draft_Snap_Endpoint'
Unknown command 'Draft_Snap_Angle'
Unknown command 'Draft_Snap_Center'
Unknown command 'Draft_Snap_Extension'
Unknown command 'Draft_Snap_Near'
Unknown command 'Draft_Snap_Ortho'
Unknown command 'Draft_Snap_Special'
Unknown command 'Draft_Snap_Dimensions'
Unknown command 'Draft_Snap_WorkingPlane'
Somebody has another idea, please?
sgrogan
Postby sgrogan » Sat Apr 14, 2018 2:13 pm
https://forum.freecadweb.org/viewtopic. ... 70#p227249
PPA is building now with the fix included. Y can make the change locally if you don't want to wait.
"fight the good fight"
Leatherman
Postby Leatherman » Sat Apr 14, 2018 2:30 pm
Does this mean, that with the next upgrade this will be fixed on its own? Guess this is what you mean, isn't it?
sgrogan
Postby sgrogan » Sat Apr 14, 2018 3:21 pm
Yes, force an update and you should be good to go.
Leatherman
Postby Leatherman » Sun Apr 15, 2018 3:45 am
Yes, thank you very much, this was simple as that. Great :lol:
