Is it possible to get 0.17.13515 for MacOS?
The topic says it all.
sgrogan
Re: Is it possible to get 0.17.13515 for MacOS?
Post by sgrogan »
chrisb wrote: Fri Apr 20, 2018 8:16 am The topic says it all.
It should auto deploy. The problem is that the OSX builds are broken at the moment https://travis-ci.org/FreeCAD/FreeCAD/b ... tification
Looks due to an update of boost to 1.67
"fight the good fight"
Founder
Post by wmayer »
Do you have access to the travis build directory? It would be interesting to get the cmake log files as they show exactly what happened inside.
Yesterday we got a PR to fix a build failure with boost.python under FreeBSD. See: git commit 869b5c89
Maybe we have to apply this also for macOS since it has its root in FreeBSD.
wmayer wrote: Fri Apr 20, 2018 12:01 pm Do you have access to the travis build directory?
I don't have a build environment (yet).
sgrogan
Post by sgrogan »
No, only the Travis log.
Founder
Post by wmayer »
OK. I created a PR to check if pthread is the problem: https://github.com/FreeCAD/FreeCAD/pull/1412
Founder
Post by wmayer »
I have locally built boost 1.67 and I ran into the same problem. Searching for a solution I found this statement in the cmake docs:
https://cmake.org/cmake/help/latest/module/FindBoost.html wrote: Note that Boost Python components require a Python version suffix (Boost 1.67 and later), e.g. python36 or python27 for the versions built against Python 3.6 and 2.7, respectively. This also applies to additional components using Python including mpi_python and numpy. Earlier Boost releases may use distribution-specific suffixes such as 2, 3 or 2.7. These may also be used as suffixes, but note that they are not portable.
This means that using
find_package( Boost COMPONENTS python REQUIRED)
doesn't work any more with boost 1.67 and later. Instead you must write (in case of Python 2.7)
find_package( Boost COMPONENTS python27 REQUIRED)
sgrogan
Post by sgrogan »
wmayer wrote: Sat Apr 21, 2018 8:40 am doesn't work any more with boost 1.67 and later. Instead you must write (in case of Python 2.7)
Thank you, can this be back-ported to 0.17?
I wonder what's going on. This morning I wanted to download the current 0.18 MacOS version. It didn't exist any 0.18, instead there was a version FreeCAD_0.17-13519.1a8b868 available. I started downloading it, and when I came back it had vanished and instead I have a current 0.18.13567.33b883a available. Now the improved 0.17 has vanished.
Can't we have both of them?
peterl94
Post by peterl94 »
The deploy script makes sure there is only one build so that the daily builds don't accumulate. Since travis is set to deploy to the 0.18_pre release, triggering a build on the release branch makes it overwrite the current 0.18 build. What I'll have to do is first download the 0.17 build, upload it to the 0.17 release then rebuild 0.18.
