Workbench BOLTSFC installed but no menue
hello,
i installed in fc 0.18 using tne addon-manager the workbench extesion "boltsfc" but i can not find any more workbench. what am i doing wrong ? how to use boltsfc ?? in the addonmanager the green check is set.
thanks a lot
w
thanks a lot
w
Re: Workbench BOLTSFC installed but no menue
Did you restart FreeCAD? Additional workbenches are not visible before restarting.
yes, i restarted
Do you have some other additional workbench that works? If not, can you try installing Fasteners?
And please add your full FreeCAD info.
thanks for tip with fasteners, i installed, restarted and the new workbench in there, now i have a first look to this....
best regards
my version:
OS: Ubuntu 16.04.4 LTS
Version: 0.18.13712 (Git)
Build type: None
Hash: 57b7f3389a846454d01c2abea509b8394099735c
Python version: 2.7.12
OCC version: 7.2.0
best regards
my version:
Build type: None
OCC version: 7.2.0
BOLTSFC is not a wb it is a macro. You should have a macro called start bolts.
hi bernd,
thanks for info but...
i searched start bolts macro but could not find. not in the macro menu in the list and not in addonmanager in the macro tab see pictures (system-tab is empty)
today my preview is out of order, i can see more than my 2 attached pictures but i removed in the textbox...
- f2.png (57.32 KiB) Viewed 3045 times
- f1.png (48.74 KiB) Viewed 3045 times
A bit late but since you get an email you may read this anyway.
If you install BOLTSFC by the addon manager wait some time ... may be 5 minutes. It will not tell you it is successful installed, but it will copy it anyway. Open a Python Console in FreeCAD and put in If you get no error message BOLTS is installed.
Afterwards go to your FreeCAD Mod directory. There should be a file called "start_bolts.FCMacro inside the BOLTSFC directory. Move this file into your macro folder. Run this macro to start BOLTS.
for reference: https://github.com/FreeCAD/FreeCAD-addons/issues/102
import BOLTS
OS: Windows 7
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
I tried the phyton command and get this:
Addon Manager says addon is installed.
I also copied the files into the macro dir, that did not helped.
Link to Bolts at Github:
https://github.com/MindScraper/BOLTS-Op ... shers-...-
Someone can read & identify the problem in the phyton error mesages?
Qt version: 5.6.2
I got same messages when I execute the macro in normal way.>>> import BOLTS
File "C:\Users\DANIEL\AppData\Roaming\FreeCAD\Mod\BOLTSFC\BOLTS\__init__.py", line 40, in <module>
from .gui import freecad_bolts as boltsgui
File "C:\Users\DANIEL\AppData\Roaming\FreeCAD\Mod\BOLTSFC\BOLTS\gui\freecad_bolts.py", line 29, in <module>
Ui_BoltsWidget,QBoltsWidget = uic.loadUiType(join(bolts_path,'bolts_widget.ui'))
File "<string>", line 15
exec pyc in frame
SyntaxError: Missing parentheses in call to 'exec'
you need 0.18.2 which is 0.18.16117
The problem was fixed with https://github.com/FreeCAD/FreeCAD/comm ... 3749771eea If you are interested: https://forum.freecadweb.org/viewtopic. ... 86#p306308
