-- -- OCE/OpenCASCADE shared libraries directory: /opt/local/FreeCAD-0.17/lib
-- The imported target "vtkRenderingPythonTkWidgets" references the file
"/usr/lib/x86_64-linux-gnu/libvtkRenderingPythonTkWidgets.so"
but this file does not exist. Possible reasons include:
* The file was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and contained
"/usr/lib/cmake/vtk-6.2/VTKTargets.cmake"
but not all the files it references.
-- The imported target "vtk" references the file
"/usr/bin/vtk"
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkIOMPIParallel;vtkParallelMPI;vtkhdf5
-- Check for medfile (libmed and libmedc) ...
-- Found NETGEN version 5.3, calculated: 328448
CMake Warning at CMakeLists.txt:793 (message):
Disable module flatmesh because it requires minimum Eigen3 version 3.3.1
but version 3.2.92 was found
-- Checking for module 'Coin'
-- No package 'Coin' found
-- libshiboken built for Release
-- Found PySide Tools: /usr/bin/pyside-uic, /usr/bin/pyside-rcc
-- -- matplotlib-1.5.1 has been found.
-- Platform is 64-bit, set -D_OCC64
-- Build type: Release
git
/home/harry/Documents/build_FreeCAD/freecad/build/src/Build/Version.h written
-- setting gcc options: -Wall -Werror -Wno-deprecated -pedantic-errors
-- Could NOT find Boost
-- Boost version: 1.58.0
-- Found the following Boost libraries:
-- python
-- found Boost: 1_58
-- boost-incude dirs are: /usr/include
-- boost-python lib is: /usr/lib/x86_64-linux-gnu/libboost_python.so
-- boost_LIBRARY_DIRS is: /usr/lib/x86_64-linux-gnu
-- Boost_LIBRARIES is: /usr/lib/x86_64-linux-gnu/libboost_python.so
-- area module (for Path Workbench) will be installed to: /opt/local/FreeCAD-0.17/lib
-- Coin3D doc is not installed
Indeed some of the clues provided from your feedback indicated your build environment could be a bit borked. Not knowing the details it is hard to suggest something. What would likely work is a fresh install of operating system + installing FreeCAD build dependencies and trying to compile FreeCAD after. If you want to fix your current build environment you would likely need to think about the things you changed in the past and revert some of that.
Thanks @triplus I indeed jumped to that conclusion and am currently reinstalling my virtual machine with Ubuntu 16.04. I had so many versions of FreeCAD on my machine that it was bound to go wrong at some point
