0.18 buidling...
0.18 buidling...
Hi, trying to build with boost 1.67 but have issues with libarea in cmake and compilation stops at FEM module ?
cheers,
Re: 0.18 buidling...
do you need the fem module otherwise compile without fem
cmake errors:
CMake Warning at /usr/share/cmake-3.10/Modules/FindBoost.cmake:801 (message):
New Boost version may have incorrect or missing dependencies and imported
targets
/usr/share/cmake-3.10/Modules/FindBoost.cmake:907 (_Boost_COMPONENT_DEPENDENCIES)
/usr/share/cmake-3.10/Modules/FindBoost.cmake:1558 (_Boost_MISSING_DEPENDENCIES)
CMakeLists.txt:605 (find_package)
targets
targets
targets
targets
targets
targets
targets
targets
setting gcc options: -Wall -Werror -Wno-deprecated -pedantic-errors
targets
src/Mod/Path/libarea/CMakeLists.txt:20 (find_package)
CMake Warning at /usr/share/cmake-3.10/Modules/FindBoost.cmake:1626 (message):
No header defined for python27; skipping header check
Compilation errors - boost lib. related:
[ 15%] Built target area
[ 18%] Built target Stylesheets_data
CMakeFiles/FreeCADBase.dir/Interpreter.cpp.o: In function `bool boost::regex_match<char const*, std::allocator<boost::sub_match<char const*> >, char, boost::regex_traits<char, boost::cpp_regex_traits<char> > >(char const*, char const*, boost::match_results<char const*, std::allocator<boost::sub_match<char const*> > >&, boost::basic_regex<char, boost::regex_traits<char, boost::cpp_regex_traits<char> > > const&, boost::regex_constants::_match_flags)':
Interpreter.cpp:(.text._ZN5boost11regex_matchIPKcSaINS_9sub_matchIS2_EEEcNS_12regex_traitsIcNS_16cpp_regex_traitsIcEEEEEEbT_SA_RNS_13match_resultsISA_T0_EERKNS_11basic_regexIT1_T2_EENS_15regex_constants12_match_flagsE[_ZN5boost11regex_matchIPKcSaINS_9sub_matchIS2_EEEcNS_12regex_traitsIcNS_16cpp_regex_traitsIcEEEEEEbT_SA_RNS_13match_resultsISA_T0_EERKNS_11basic_regexIT1_T2_EENS_15regex_constants12_match_flagsE]+0x8f): undefined reference to `boost::re_detail_106700::perl_matcher<char const*, std::allocator<boost::sub_match<char const*> >, boost::regex_traits<char, boost::cpp_regex_traits<char> > >::match()'
CMakeFiles/FreeCADBase.dir/Interpreter.cpp.o: In function `boost::re_detail_106700::perl_matcher<char const*, std::allocator<boost::sub_match<char const*> >, boost::regex_traits<char, boost::cpp_regex_traits<char> > >::perl_matcher(char const*, char const*, boost::match_results<char const*, std::allocator<boost::sub_match<char const*> > >&, boost::basic_regex<char, boost::regex_traits<char, boost::cpp_regex_traits<char> > > const&, boost::regex_constants::_match_flags, char const*)':
Interpreter.cpp:(.text._ZN5boost16re_detail_10670012perl_matcherIPKcSaINS_9sub_matchIS3_EEENS_12regex_traitsIcNS_16cpp_regex_traitsIcEEEEEC2ES3_S3_RNS_13match_resultsIS3_S6_EERKNS_11basic_regexIcSA_EENS_15regex_constants12_match_flagsES3_[_ZN5boost16re_detail_10670012perl_matcherIPKcSaINS_9sub_matchIS3_EEENS_12regex_traitsIcNS_16cpp_regex_traitsIcEEEEEC5ES3_S3_RNS_13match_resultsIS3_S6_EERKNS_11basic_regexIcSA_EENS_15regex_constants12_match_flagsES3_]+0x101): undefined reference to `boost::re_detail_106700::perl_matcher<char const*, std::allocator<boost::sub_match<char const*> >, boost::regex_traits<char, boost::cpp_regex_traits<char> > >::construct_init(boost::basic_regex<char, boost::regex_traits<char, boost::cpp_regex_traits<char> > > const&, boost::regex_constants::_match_flags)'
src/Base/CMakeFiles/FreeCADBase.dir/build.make:2596: recipe for target 'lib/libFreeCADBase.so' failed
make[2]: *** [lib/libFreeCADBase.so] Error 1
CMakeFiles/Makefile2:291: recipe for target 'src/Base/CMakeFiles/FreeCADBase.dir/all' failed
make[1]: *** [src/Base/CMakeFiles/FreeCADBase.dir/all] Error 2
Makefile:129: recipe for target 'all' failed
make: *** [all] Error 2
bluecd@bluecd-System-Product-Name:~/freecad_build$ ^C
cheers,
libarea depends on libboost-python which is separate from libboost. Path uses libarea, I didn't think FEM depended on this. boost-python will also depend on Python so the Python used for libboost-python has to match the rest of FreeCAD Python.
Did you build boost yourself? Did you install it?
"fight the good fight"
yes, i ve built boost 1.67 myself and installed /linux mint tara x64/ and then rebuilt libarea and installed.
PS. Above build log has been inserted here AFTER disabling FEM module in cmake-gui so the errors do not refer to FEM anymore.
cheers,
CMakeFiles/Makefile2:674: recipe for target 'src/Base/CMakeFiles/FreeCADBase.dir/all' failed
make[1]: *** Waiting for unfinished jobs....
[ 28%] Built target SMESH
cheers,
