gilou
Posts: 15 Joined: Fri May 09, 2014 9:00 pm
Post
by gilou » Wed May 14, 2014 11:18 am
I don't understand exactly because it tell me :
Err https://dl.dropboxusercontent.com ./ Sources
The requested URL returned error: 404
Réception de : 53 https://dl.dropboxusercontent.com ./ Packages [8 522 B]
En when I want install with :
It can't find freecad.
Have a good day
OS: Debian GNU/Linux 8.2 (jessie)
OS: 64-bit
FreeCAD: 64-bit
Version: 0.16.6155 (Git)
Build type: Unknown
Hash: 0ea477b4205a45d399179301b59af802dcd520bf
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.7.0
cblt2l
Posts: 155 Joined: Sat May 15, 2010 3:59 am
Post
by cblt2l » Wed May 14, 2014 11:47 pm
gilou wrote: Code: Select all
AFAIK, 'Sources' means that you have the repository set to deb-src, which is a debian source code archive. I am only providing a binary package so make sure your entry looks like this:
deb https://dl.dropboxusercontent.com/u/63300398/deb-packages ./
and
NOT this:
deb-src https://dl.dropboxusercontent.com/u/63300398/deb-packages ./
Past that I'm stumped. I have had no issues with the current setup. Maybe some other Wheezy users will chime in and let us know if its working for them.
Posts: 18587 Joined: Sat Feb 06, 2010 9:52 pm
Post
by NormandC » Fri May 16, 2014 9:09 pm
Hello bejant,
See cblt2l's answer to this here:
viewtopic.php?f=4&t=2995&start=30#p51514
cblt2l wrote: Keep in mind that the link from my first post works only when set up as an apt repository i.e. you have to add the line to your sources.list file. If you are trying to follow the link and download the packages manually then you will get a 404.
gilou
Post
by gilou » Wed May 21, 2014 7:36 pm
Thanks cblt2l for your answers,
I've not continue in this way because I managed to compile directly with git sources repository.
effectively I had the deb-src link in my sources.list.
OS: 64-bit
FreeCAD: 64-bit
Build type: Unknown
Qt version: 4.8.6
OCC version: 6.7.0
