CMake Deprecation Warning at CMakeLists.txt:22 (cmake_policy):
The OLD behavior for policy CMP0050 will be removed from a future version
of CMake.
The cmake-policies(7) manual explains that the OLD behaviors of all
policies are deprecated and that a policy should be set to OLD only under
specific short-term circumstances. Projects should be ported to the NEW
behavior and not rely on setting a policy to OLD.
Compiler: MSVC, version: 18.0.31101.0
prefix: C:/Program Files/FreeCAD_trunk
datadir: data
docdir: doc
includedir: include
libdir: lib
PyCXX found:
Headers: C:/Users/hvlan/OneDrive/FC_Dev/FC_Master/Source/FreeCAD/src
Sources: C:/Users/hvlan/OneDrive/FC_Dev/FC_Master/Source/FreeCAD/src/CXX
Version: 6.2.8
Boost version: 1.55.0
Found the following Boost libraries:
filesystem
program_options
regex
signals
system
thread
chrono
date_time
Found Xerces-C: C:/Users/hvlan/OneDrive/FC_Dev/Libraries/FreeCADLibs_11.8_x64_VC12/lib/xerces-c_3.lib
PyCXX found:
Version: 6.2.8
-- OpenCASCADE Community Edition has been found.
-- Found OCE/OpenCASCADE version: 7.1.0
-- OCE/OpenCASCADE include directory: C:/Users/hvlan/OneDrive/FC_Dev/Libraries/FreeCADLibs_11.8_x64_VC12/lib/cmake/../../include/oce
-- OCE/OpenCASCADE shared libraries directory:
VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkhdf5;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
Could NOT find SMESH (missing: SMESH_DIR)
ERROR================
SMESH not found.
Could NOT find Netgen (missing: Netgen_DIR)
Found NETGEN version 5.3, calculated: 328448
CMake Warning at CMakeLists.txt:795 (message):
Disable module flatmesh because it requires minimum Eigen3 version 3.3.1
but version 3.2.5 was found
Using default python: -python2.7
libshiboken built for Release
Found PySide Tools: C:/Users/hvlan/OneDrive/FC_Dev/Libraries/FreeCADLibs_11.8_x64_VC12/bin/pyside-uic, C:/Users/hvlan/OneDrive/FC_Dev/Libraries/FreeCADLibs_11.8_x64_VC12/bin/pyside-rcc.exe
-- matplotlib-1.4.2 has been found.
Platform is 64-bit, set -D_OCC64
git
C:/Users/hvlan/OneDrive/FC_Dev/FC_Master/Build/src/Build/Version.h written
CMake Error at src/Base/CMakeLists.txt:365 (message):
Using external zipios++ was specified but was not found.
Configuring incomplete, errors occurred!
See also "C:/Users/hvlan/OneDrive/FC_Dev/FC_Master/Build/CMakeFiles/CMakeOutput.log".
See also "C:/Users/hvlan/OneDrive/FC_Dev/FC_Master/Build/CMakeFiles/CMakeError.log".
Thanks, Harry
