crash switching work bench
HarryvL
Postby HarryvL » Wed Aug 08, 2018 9:07 pm
Hi, I recently moved from Ubuntu 16.04 to Windows 10 and managed to build two versions of FreeCAD (version info below) using CMake 3.12.0, LibPack FreeCADLibs_11.11_x64_VC12 and Visual Studio 2013. As far as I can see I don't get any errors along the way. However, although fully functional, both versions crash when switching work bench. Saving of the FCStd file in between WB switches seems to reduce the likelihood of a crash, but not consistently so. Did anybody experience the same issue and/or have a suggestion what to do about it?
Version: 0.18.14267 (Git)
Hash: f99940ff1943a8985d76b339ea973191b71986b8
Python version: 2.7.14
OCC version: 7.2.0
Locale: English/Denmark (en_DK)
Version: 0.18.14094 (Git)
Branch: trajectories
Hash: ce3e7dde66665997b33134b531d6d01834130730
OCC version: 7.2.0
Site Admin
Re: crash switching work bench
Postby wmayer » Wed Aug 08, 2018 11:10 pm
Open a Windows Explorer and enter %APPDATA% into the address bar and got to the FreeCAD directory. Here you may find the file crash.dmp which you can load into Visual Studio. After pressing F5 it should show the call stack of the crash. Maybe you can see the function name of the last call.
If you don't get any useful information it's best to make a debug build and test it there.
HarryvL
Postby HarryvL » Thu Aug 09, 2018 3:42 am
Thanks Werner. There is no crash.dmp file in >AppData>Roaming>FreeCAD. I will try a Debug Build. Harry
HarryvL
Postby HarryvL » Thu Aug 09, 2018 5:24 am
I managed to do a debug build, but can't start that with "F5" (Unable to start program; ...\x64\Debug\ALL_BUILD; access denied). Anyway, starting FreeCAD_d.exe from Windows Explorer gives an (unrelated?) python error in the report window: x64\Debug\ALL_BUILD
File "C:\Users\hvlan\Documents\FC_Daily\Build\Mod\Fem\femguiobjects\_ViewProviderFemResultMechanical.py", line 43, in <module>
import numpy as np
File "C:\Users\hvlan\Documents\FC_Daily\Build\bin\lib\site-packages\numpy\__init__.py", line 142, in <module>
from . import add_newdocs
File "C:\Users\hvlan\Documents\FC_Daily\Build\bin\lib\site-packages\numpy\add_newdocs.py", line 13, in <module>
from numpy.lib import add_newdoc
File "C:\Users\hvlan\Documents\FC_Daily\Build\bin\lib\site-packages\numpy\lib\__init__.py", line 8, in <module>
from .type_check import *
File "C:\Users\hvlan\Documents\FC_Daily\Build\bin\lib\site-packages\numpy\lib\type_check.py", line 11, in <module>
import numpy.core.numeric as _nx
File "C:\Users\hvlan\Documents\FC_Daily\Build\bin\lib\site-packages\numpy\core\__init__.py", line 24, in <module>
raise ImportError(msg)
<type 'exceptions.ImportError'>:
Importing the multiarray numpy extension module failed. Most
likely you are trying to import a failed build of numpy.
If you're working with a numpy git repo, try `git clean -xdf` (removes all
files not under version control). Otherwise reinstall numpy.
However, I wouldn't exepect that to be related to the crash (?). Apart from that, I am pretty much stuck.
HarryvL
Postby HarryvL » Thu Aug 09, 2018 5:46 am
By the way, FreeCAD_d does produce a crash.dmp file, but it is not very informative:
HarryvL
Postby HarryvL » Thu Aug 09, 2018 5:50 am
Hang-on, there is more interesting information ...
Site Admin
Postby wmayer » Thu Aug 09, 2018 6:06 am
You have to set FreeCADMain as the active project or alternatively set the executable in the properties of the ALL_BUILD project.
So, the debug version did but the release version not? I don't know how VS 2013 (or later) handles .dmp files but with VS 2008 (or earlier) you could load it via Edit > Open > Project/Solution and then press F5 to start the debugger. It then jumps to the location where the crash happened. So, it's not just statistical information as shown in your screen shot.
But anyway you get the crash inside the destructor of an OCCT array class which is called from ViewProviderPartExt::getNormals. But I don't see how this can be called only from a wb switch. Maybe you can scroll down the Call Stack window a bit to see which are the calling instances. Maybe it gives you, me or someone else an idea.
HarryvL
Postby HarryvL » Thu Aug 09, 2018 7:56 pm
Correct
Indeed. See below for the full dump. Any help would be appreciated, because unfortunately I lack knowledge in all relevant areas :? ...
Site Admin
Postby wmayer » Thu Aug 09, 2018 8:47 pm
Apparently you have opened the HTML Startpage and clicked on one of the files there. I guess internally it runs a Python script that switches the workbench and loads the file.
But it doesn't seem that the switch of the workbench is the problem but loading the Part object. Now, on which link on the Startpage did you click?
HarryvL
Postby HarryvL » Thu Aug 09, 2018 8:58 pm
I don't fully understand Werner. In all cases the crash occurred when switching between work benches. So I didn't leave the program nor did I open any pages from within the program (didn't know that was possible anyway). I did not open help pages or anything at the time of the crash, if that is what you mean?
