Solved -- Report View does not display - Fixed
micksulley
Postby micksulley » Tue Aug 28, 2018 7:36 pm
OS: Linux Mint 19 Tara
Version: 0.18.14448 (Git) AppImage
Build type: None
Hash: 561be08211c21bcae5b8e3c6f2dbc7b09306da21
Python version: 2.7.6
Qt version: 4.8.6
Both Report View and also Path > Inspect G-Code display coloured blocks instead of text. In both cases if I copy paste into a text editor it displays correctly. Screenshot attached
I have run with the -l option to generate a log file, attached, but I can't see anything in there to give me a clue.
Any ideas?
Mick
Screenshot from 2018-08-28 20-30-38.png (210.98 KiB) Viewed 436 times
FreeCAD.log
(14.76 KiB) Downloaded 7 times
sgrogan
Re: Report View does not display
Postby sgrogan » Tue Aug 28, 2018 8:25 pm
Any ideas?
Both Report View and Inspect G-code works for me with:
OS: Ubuntu 14.04.5 LTS
Version: 0.17.13528 (Git) AppImage
Build type: None
Branch: releases/FreeCAD-0-17
Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b
Qt version: 4.8.6
and
Version: 0.18.5235 (Git shallow) AppImage
Hash: 3e6cc7bbcd03ef2a9d57d504b0971c098e64171a
Python version: 3.6.5
Qt version: 5.6.2
OCC version: 7.2.0
and
Version: 0.18.14482 (Git) AppImage
Build type: None
Hash: 6f06345634e25839b535a4534face9d9c1196201
Qt version: 4.8.6
Our freecad-daily PPA supports Linux Mint, have you tried that? I don't think it would make a difference.
I would try to rename your .cfg files in .FreeCAD folder.
Beyond that maybe a graphics driver issue?
EDIT: see here https://forum.freecadweb.org/viewtopic. ... 54#p227269 your Mint version is based on Ubuntu 18.04
micksulley
Postby micksulley » Tue Aug 28, 2018 9:53 pm
Renamed both .cfg files, restarted FC and taraaaa! it all works fine now.
Many thanks
Mick
sgrogan
Re: Report View does not display - Fixed
Postby sgrogan » Tue Aug 28, 2018 10:02 pm
Many thanks
Mick
Great! Any reason you don't use the PPA? You will get automatic, delta updates, maybe save some bandwidth.
micksulley
Postby micksulley » Tue Aug 28, 2018 10:26 pm
Celebrating too soon, its not fixed.
If I delete user.cfg and restart FC it is fine, but if I go to Edit > Preferences, even just clicking Apply without changing anything causes the problem again. Just ran it again to generate a log file which is attached, but I cannot see anything relevant.
Any ideas?
re PPA, I have it installed but that only gets me version 17, not 18, unless there is some other way to do it?
FreeCAD.log
(14.76 KiB) Downloaded 11 times
sgrogan
Postby sgrogan » Tue Aug 28, 2018 10:30 pm
0.18 is freecad-daily, 0.17 is freecad. They can exist side by side.
Any ideas?
I'll look. Do you experience problems w/ the 0.17 PPA? I mix appimages and freecad-daily and freecad PPA all the time without problems, but?
sgrogan
Postby sgrogan » Tue Aug 28, 2018 10:34 pm
Any ideas?
Not sure if this is normal
Msg: Path workbench activated
Log: Hide main window
Log: Finish: Event loop left
Log: Destruct Gui::Application
Log: Couldn't disconnect from spacenav daemon
Log: FreeCAD terminating...
micksulley
Postby micksulley » Tue Aug 28, 2018 10:35 pm
Yes exactly the same in 17, as I hit Apply the characters change to blocks
sgrogan
Postby sgrogan » Tue Aug 28, 2018 10:41 pm
Maybe this is also still in play? EDIT: see here https://forum.freecadweb.org/viewtopic. ... 54#p227269
triplus wrote: ping
micksulley
Postby micksulley » Tue Aug 28, 2018 10:52 pm
Sorry your link doesn't work, can you post the full address
