HowTo install FreeCAD 0.18 on Ubuntu 18.04?
R-INYURU
Postby R-INYURU » Wed Sep 19, 2018 5:56 pm
I have tried to install the daily build of FreeCAD on Ubuntu 18.04 and I used the information on this page https://www.freecadweb.org/wiki/Install_on_Unix. After adding the PPA, as I was going to install Freecad-daily and I was prompted that some packages are missing.
  The following packages have unmet dependencies.
 freecad-daily : Depends: libmedc1v5 but it is not going to be installed
                 Depends: libvtk6.3 but it is not going to be installed
                 Recommends: calculix-ccx but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
so I started installing package by package but it turns out that those package needs other packages.
 libmedc1v5 : Depends: libhdf5-openmpi-100 (>= 1.8.14) but it is not going to be installed
and yes it continues.
 libhdf5-openmpi-100 : Depends: libgfortran4 (>= 7) but it is not going to be installed
At this point I just stopped.
what I am doing wrong or whats could the cause of this?
sgrogan
Re: HowTo install FreeCAD 0.18 on Ubuntu 18.04?
Postby sgrogan » Wed Sep 19, 2018 8:26 pm
Is this a fresh install of 18.04 or an upgrade of an older release?
If fresh how did you install?
triplus
Postby triplus » Wed Sep 19, 2018 11:37 pm
Hi @R-INYURU and welcome. Make sure you have the universe repository enabled:
https://forum.freecadweb.org/viewtopic. ... 80#p251226
P.S. While sorting out the dependency situation you can still start using FreeCAD by using the AppImage:
https://github.com/FreeCAD/FreeCAD/releases/
R-INYURU
Postby R-INYURU » Thu Sep 20, 2018 8:41 am
I have upgraded from 16.04
I have followed suggestion given on that topic, but it didn't work, I am still getting the same problem.
Currently I am using the FC 0.17 the AppImage, I wanted to try out the daily build also.
sgrogan
Postby sgrogan » Thu Sep 20, 2018 8:48 pm
Maybe this helps? https://askubuntu.com/questions/363200/ ... n-packages
Have you tried
sudo apt-get upgrade
sudo apt-get update
sudo apt-get install freecad-daily
Be careful before just firing off sudo commands
triplus
Postby triplus » Fri Sep 21, 2018 12:16 am
Too bad. Therefore likely more in-depth investigation will be needed on what got borked during the upgrade procedure. And to sort out the dependencies first. Some old package causing the problems or something like that is likely at play.
Note that daily FreeCAD AppImage is available too (under the 0.18_pre section).
Postby chrisb » Fri Sep 21, 2018 12:27 am
sudo apt-get update
You mixed the sequence. And I would use dist-upgrade as it does more cleaning on heavyer changes:
sudo apt-get update
sudo apt-get dist-upgrade
R-INYURU
Postby R-INYURU » Fri Sep 21, 2018 8:48 am
I have tried all the command suggested but nothing change its the same issue. I personally suspect the Ubuntu 18.04 to be the issue, there is some package (unrelated to freecad) that I can't upgrade since I moved to 18.04 and the autoremove command removes some packages after I get an update telling me to reinstall them.
Thanks.
NormandC
Postby NormandC » Sun Sep 23, 2018 5:04 pm
I'm afraid you'll need to troubleshoot and fix this issue then... Good luck.
cron
