No module named WebGui on Mac OS
amrit3701
Postby amrit3701 » Fri Sep 21, 2018 12:06 pm
I compiled FreeCAD on Mac OS successfully. But when I trying to run FreeCAD it gives me an error:
  File "<string>", line 43, in Initialize
Given below are the command I used to compile FreeCAD.
$ cmake -DCMAKE_BUILD_TYPE="Release" \
  -DBUILD_QT5=1 \
  -DCMAKE_PREFIX_PATH="/usr/local/Cellar/qt/5.11.2/lib/cmake"  \
$ make ..
Screen Shot 2018-09-21 at 5.32.55 PM.png (551.61 KiB) Viewed 2185 times
peterl94
Re: No module named WebGui on Mac OS
Postby peterl94 » Fri Sep 21, 2018 2:24 pm
Qtwebkit is installed separately, and so cmake doesn't find it with just the qt prefix. You also need to add the path to qtwebkit.
-DCMAKE_PREFIX_PATH="/usr/local/Cellar/qt/5.11.2/lib/cmake;/usr/local/Cellar/qtwebkit/5.212-72cfbd_2/lib/cmake"
amrit3701
Postby amrit3701 » Fri Sep 21, 2018 3:46 pm
Yeah! it works. Thanks @peterl94
