I have added an entry in the known issues topic.
FreeCAD on macOS Mojave
Re: FreeCAD on macOS Mojave
- martijnthe
Works for me too -- Mojave 10.14.2 (18C54) on a MacBook Pro (Retina, 15-inch, Late 2013).leonardshelby wrote: ↑Wed Nov 28, 2018 9:09 pm A simple workaround for now:
Create an alias to the FreeCAD binary on your Desktop. When started from this alias, it will automatically open from a terminal. This for some reason fixes the freezes.
- martijnthe
This workaround works for me too.leonardshelby wrote: ↑Wed Nov 28, 2018 9:09 pm A simple workaround for now:
Looking at the system logs, I suspect it has something to do with the FreeCAD.app not being code-signed.
When launching through Terminal.app (which the shortcut/alias helps doing), the checks are being by-passed.
Launching by double clicking FreeCAD.app:
standaard 10:37:30.889721 +0100 tccd -[TCCDAccessIdentity staticCode]: static code for: identifier , type: 0: 0x7fad78d00b30 at /Applications/FreeCAD-0.18_pre.app
standaard 10:37:30.889868 +0100 tccd MacOS error: -67062
standaard 10:37:30.891132 +0100 tccd MacOS error: -67062
standaard 10:40:53.214961 +0100 tccd -[TCCDAccessIdentity staticCode]: static code for: identifier com.apple.Terminal, type: 0: 0x7fad78c04720 at /Applications/Utilities/Terminal.app
standaard 10:40:53.222475 +0100 tccd Platform binary prompting is 'Allow without Requiring Usage String' because: is Terminal
Miraculously, it helps to get rid of the system freeze!
So, this raises a question with me: should binary macOS releases be signed?
If that's possible, they probably should be code signed. I wouldn't be surprised if Apple soon won't allow any unsigned apps at all. I believe the default setting on Mojave is already even stricter: App Store only.
I have tried to disable "gatekeeper", but it does not fix the freezes.
User opened issue #3744martijnthe wrote: ↑Thu Jan 31, 2019 10:05 amThis workaround works for me too.leonardshelby wrote: ↑Wed Nov 28, 2018 9:09 pm A simple workaround for now:
Launching by double clicking FreeCAD.app:Launching through Terminal or double clicking alias to FreeCAD.app/Contents/MacOS/FreeCAD:Code: Select all
standaard 10:37:30.889721 +0100 tccd -[TCCDAccessIdentity staticCode]: static code for: identifier , type: 0: 0x7fad78d00b30 at /Applications/FreeCAD-0.18_pre.app standaard 10:37:30.889868 +0100 tccd MacOS error: -67062 standaard 10:37:30.891132 +0100 tccd MacOS error: -67062
I'm not very familiar with macOS' codesigning / security architecture, but to test my theory, I tried code-signing the FreeCAD.app.Code: Select all
standaard 10:40:53.214961 +0100 tccd -[TCCDAccessIdentity staticCode]: static code for: identifier com.apple.Terminal, type: 0: 0x7fad78c04720 at /Applications/Utilities/Terminal.app standaard 10:40:53.222475 +0100 tccd Platform binary prompting is 'Allow without Requiring Usage String' because: is Terminal
Is this issue going anywhere? There have been several releases since 0.18 official one and it still impossible to use FC on mac. Its basically dysfunctional if you need to wait for the machine to unfreeze every time you need to open a file.
You can use 0.18.3 from conda-forge:
conda create -n freecad0.18.3 -c conda-forge
The bundles are only for the lazy people. In the background everything ispackaged with conda.
Also you can use the latest 0.19 bundle which is also based on qt5.9.
Best solution for sure is to avoid Mac at all.
Also experiencing this problem.
But at least I can add my voice saying that launching directly from the binary at /Applications/FreeCAD.app/Contents/MacOS/FreeCAD works (either via terminal or an alias).
I made an aplescript app with the code
and gave it a nice icon by replacing the applet.icns with the freecad .icns file.
My info:
MacOS 10.14.6 (18G87)
FreeCAD 0.19:
OS: macOS 10.14
Version: 0.19.17798 (Git)
Hash: 7e60631239109c632a8f6cca83f6e7e5502e43a1
Python version: 3.7.3
Qt version: 5.9.7
FreeCAD 0.18:
OS: macOS 10.14
Version: 0.18.16131 (Git)
Branch: (HEAD detached at 0.18.3)
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.7
Qt version: 5.6.2
do shell script "/Applications/FreeCAD.app/Contents/MacOS/FreeCAD"
My info:
FreeCAD 0.19:
OS: macOS 10.14
Qt version: 5.9.7
FreeCAD 0.18:
OS: macOS 10.14
Qt version: 5.6.2
Arvid Tomayko
Audio Equipment Product Development >>> http://yourheaven.net
Musician, Multimedia Artist >>> http://arvidtomayko.com
I have added a link to this post to the "Known OS specific issues".
Good news for now: On macOS 10.15 (Catalina) this issue seems to be gone. No more need for workarounds You just have to go through a few more safety measures to get freecad running after downloading.
There's another little bug, also with macOS 10.14: Freecad unexpectedly quits when I try to open a file from the "recent files" menu with no other file opened before. Is this macOS specific also?
Version Info:
OS: macOS 10.15
Version: 0.19.18403 (Git)
Hash: 0717b4fc23ef1db70964c3977d25e2fe46a739d1
Qt version: 5.12.5
Locale: English/Germany (en_DE)
Version Info:
OS: macOS 10.15
Qt version: 5.12.5
- Screenshot 2019-10-10 at 11.23.13.png (203.7 KiB) Viewed 2605 times
- Screenshot 2019-10-10 at 11.23.05.png (605.93 KiB) Viewed 2605 times
- Screenshot 2019-10-10 at 11.22.48.png (291.27 KiB) Viewed 2605 times
