[DONE] conda: update to gcc7 and py3.7
looo
Re: [wip] conda: update to gcc7 and py3.7
Postby looo » Sun Jan 20, 2019 7:34 pm
I can only speak for the conda related stuff and this is already outdated.
I guess using the appimage is the simplest way to test python3-compatibility on linux.
Postby Kunda1 » Sun Jan 20, 2019 8:59 pm
What should we do about this wiki page then, if it's obsolete ?
sgrogan
Postby sgrogan » Thu Jan 24, 2019 12:15 am
"Under Construction"
For conda based PY3, which includes Win, OSX, and AppImage, this is a work in progress. For Linux, there is all of kkremitzki's work on Debian and Ubuntu.
Maybe in the short term, some links to the relevant forum threads, although this is less than ideal because it's also spread out and evolving.
looo
Postby looo » Wed Jan 30, 2019 8:19 am
little update:
A freecad-package for linux is uploaded to freecad/label/testing . This build include one problem with boost. A smesh library reports a problem with boost:
During initialization the error /home/k/conda/envs/freecad-gcc7/lib/././libSMESHUtils.so.8.3: undefined symbol: _ZN5boost6system6detail24system_category_instanceE occurred in /home/k/.FreeCAD/Mod/CfdOF/InitGui.py
Normally these kind errors are due to different linked boost-versions but this is not the case here. I think the problem is because boost 1.68.0 is build with -std=c++17 and smesh is build with -sdt=c++14. It seems it's not possible to mix these different standards.
There is no such problem with FreeCAD. I guess this is because FreeCAD doesn't depend on boost::system, but I am not sure.
So in the long run we should try to make these libraries work with c++17.
As a riminder: Errors to fix in smesh. Maybe it's already done for internal smesh?
[13/205] $BUILD_PREFIX/bin/x86_64-conda_cos6-linux-gnu-c++  -DCSFDB -DHAVE_CONFIG_H -DHAVE_FREEIMAGE -DHAVE_LIMITS_H -DHAVE_TBB -DLIN -DOCC_CONVERT_SIGNALS -DSMDS_EXPORTS -I$PREFIX/include/opencascade -I$PREFIX/include -I$PREFIX/include/freetype2 -I$PREFIX/include/python3.7m -I$PREFIX/include/libxml2 -I$PREFIX/include/netgen -I$PREFIX/include/netgen/occ -I$PREFIX/include/netgen/meshing -I$PREFIX/include/netgen/general -I$PREFIX/include/netgen/linalg -I$PREFIX/include/netgen/csg -I$PREFIX/include/netgen/geom2d -I$PREFIX/include/netgen/gprim -I$PREFIX/include/netgen/include -I$PREFIX/include/netgen/stlgeom -I../inc -isystem $PREFIX/include/vtk-8.1 -fvisibility-inlines-hidden -std=c++17 -fmessage-length=0 -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -pipe -I$PREFIX/include -fdebug-prefix-map==/usr/local/src/conda/- -fdebug-prefix-map==/usr/local/src/conda-prefix -O3 -DNDEBUG -fPIC   -std=gnu++1z -MD -MT CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh0DElement.cxx.o -MF CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh0DElement.cxx.o.d -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh0DElement.cxx.o -c ../src/SMDS/SMDS_Mesh0DElement.cxx
FAILED: CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh0DElement.cxx.o
In file included from ../src/SMDS/SMDS_Mesh0DElement.cxx:31:0:
../inc/SMDS_Mesh.hxx:698:55: error: ISO C++1z does not allow dynamic exception specifications
   static int CheckMemory(const bool doNotRaise=false) throw (std::bad_alloc);
looo
Postby looo » Wed Jan 30, 2019 2:59 pm
also if someone knows what this is about please drop a comment:
import TestFemCommon
import TestObjectCreate
import TestObjectType
Call from Python thread (not synchronized): count=1
Call from Python thread (not synchronized): count=2
Call from Python thread (not synchronized): count=3
Call from Python thread (not synchronized): count=4
Call from Python thread (not synchronized): count=5
Call from Python thread (not synchronized): count=6
Call from Python thread (not synchronized): count=7
Call from Python thread (not synchronized): count=8
Call from Python thread (not synchronized): count=9
Call from Python thread (not synchronized): count=10
libgcc_s.so.1 must be installed for pthread_cancel to work
looo
Postby looo » Sat Feb 02, 2019 8:59 am
The smesh problem is because of different c++-standarts used for smesh and boost. Conda's boost is now compiled with c++17 and some symbols are not available if a library is build with c++14. This means: We have to build smesh (and maybe FreeCAD) with c++17 if boost is build with c++17.
this is how packaging feels:
https://proxy.duckduckgo.com/iu/?u=http ... ka.jpg&f=1
looo
Postby looo » Sat Feb 02, 2019 9:04 am
anyway, I tried to build freecad with c++17. @wmayer Any ideas?
undefined reference to `boost::re_detail_106700::cpp_regex_traits_implementation<char>::transform[abi:cxx11](char const*, char const*) const'
Postby wmayer » Sat Feb 02, 2019 2:37 pm
Sorry, no idea what is wrong here.
blacey
Postby blacey » Sat Feb 02, 2019 4:06 pm
@loo, The
[abi:cxx11]
seems to indicate that boost was compiled with an Application Binary Interface (ABI) that is not compatible with cxx17. I believe that either boost needs to be compiled with cxx17 or you need to compile it with the newer ABI. Checkout https://gcc.gnu.org/onlinedocs/libstdc+ ... l_abi.html,
https://docs.computecanada.ca/wiki/GCC_C%2B%2B_Dual_ABI and
https://stackoverflow.com/questions/306 ... i-mismatch
looo
Postby looo » Mon Feb 04, 2019 11:13 am
@loo, The
[abi:cxx11]
Thanks for the hints.
The boost lib from conda-forge is now compiled with c++17. This adds some additional headache:
https://github.com/LaughlinResearch/SMESH/issues/12
https://github.com/conda-forge/boost-cp ... /issues/43
https://github.com/conda/conda-build/issues/3375
It did compile the boost-library with c++11 locally. Maybe this library was the one used for the build, and therefor the error occured. I will ignore this for now, as I think we do not have to port freecad to c++17(But we will see after tests are done)
The way to proceed looks like the following:
- port smesh to work with c++17 (help needed how to replace something like this https://github.com/LaughlinResearch/SME ... 3D.cxx#L80 with noexpect)
- try building freecad with c++11 and see if it works. I guess it should work allthough boost is build with c++17 because only the boost::system lib seems to be dependent on the c++-standart (which is soooooo anoying)
Maybe someone can help with the throw/noexpect stuff.
http://www.open-std.org/jtc1/sc22/wg21/ ... 003r0.html
