I can only speak for the conda related stuff and this is already outdated.
I guess using the appimage is the simplest way to test python3-compatibility on linux.
What should we do about this wiki page then, if it's obsolete ?
"Under Construction"
During initialization the error /home/k/conda/envs/freecad-gcc7/lib/././libSMESHUtils.so.8.3: undefined symbol: _ZN5boost6system6detail24system_category_instanceE occurred in /home/k/.FreeCAD/Mod/CfdOF/InitGui.py
[13/205] $BUILD_PREFIX/bin/x86_64-conda_cos6-linux-gnu-c++ -DCSFDB -DHAVE_CONFIG_H -DHAVE_FREEIMAGE -DHAVE_LIMITS_H -DHAVE_TBB -DLIN -DOCC_CONVERT_SIGNALS -DSMDS_EXPORTS -I$PREFIX/include/opencascade -I$PREFIX/include -I$PREFIX/include/freetype2 -I$PREFIX/include/python3.7m -I$PREFIX/include/libxml2 -I$PREFIX/include/netgen -I$PREFIX/include/netgen/occ -I$PREFIX/include/netgen/meshing -I$PREFIX/include/netgen/general -I$PREFIX/include/netgen/linalg -I$PREFIX/include/netgen/csg -I$PREFIX/include/netgen/geom2d -I$PREFIX/include/netgen/gprim -I$PREFIX/include/netgen/include -I$PREFIX/include/netgen/stlgeom -I../inc -isystem $PREFIX/include/vtk-8.1 -fvisibility-inlines-hidden -std=c++17 -fmessage-length=0 -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -pipe -I$PREFIX/include -fdebug-prefix-map==/usr/local/src/conda/- -fdebug-prefix-map==/usr/local/src/conda-prefix -O3 -DNDEBUG -fPIC -std=gnu++1z -MD -MT CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh0DElement.cxx.o -MF CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh0DElement.cxx.o.d -o CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh0DElement.cxx.o -c ../src/SMDS/SMDS_Mesh0DElement.cxx
FAILED: CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh0DElement.cxx.o
In file included from ../src/SMDS/SMDS_Mesh0DElement.cxx:31:0:
../inc/SMDS_Mesh.hxx:698:55: error: ISO C++1z does not allow dynamic exception specifications
static int CheckMemory(const bool doNotRaise=false) throw (std::bad_alloc);
import TestFemCommon
import TestObjectCreate
import TestObjectType
Call from Python thread (not synchronized): count=1
Call from Python thread (not synchronized): count=2
Call from Python thread (not synchronized): count=3
Call from Python thread (not synchronized): count=4
Call from Python thread (not synchronized): count=5
Call from Python thread (not synchronized): count=6
Call from Python thread (not synchronized): count=7
Call from Python thread (not synchronized): count=8
Call from Python thread (not synchronized): count=9
Call from Python thread (not synchronized): count=10
libgcc_s.so.1 must be installed for pthread_cancel to work
undefined reference to `boost::re_detail_106700::cpp_regex_traits_implementation<char>::transform[abi:cxx11](char const*, char const*) const'
[abi:cxx11]
Thanks for the hints.blacey wrote: ↑Sat Feb 02, 2019 4:06 pm@loo, Theseems to indicate that boost was compiled with an Application Binary Interface (ABI) that is not compatible with cxx17. I believe that either boost needs to be compiled with cxx17 or you need to compile it with the newer ABI. Checkout https://gcc.gnu.org/onlinedocs/libstdc+ ... l_abi.html,Code: Select all
[abi:cxx11]
https://docs.computecanada.ca/wiki/GCC_C%2B%2B_Dual_ABI and
https://stackoverflow.com/questions/306 ... i-mismatch
