0.17 & Mac Mojave total crash
Re: 0.17 & Mac Mojave total crash
Postby Kunda1 » Wed Nov 14, 2018 12:40 am
Can someone get a traceback by Debugging and post here? That could help move this issue along
leonardshelby
Postby leonardshelby » Wed Nov 14, 2018 2:57 pm
I'd be happy to help, but even getting FreeCAD compiled in debug mode on macOS Mojave seems to be too complicated at this time.
I am trying to compile FreeCAD, basically following https://www.freecadweb.org/wiki/CompileOnMac.
As from another thread I installed
brew install gmsh --with-opencascade
and I added a few variables so cmake would find more stuff:
cmake \
-DCMAKE_BUILD_TYPE="Release" \
-DBUILD_QT5=1 \
-DCMAKE_PREFIX_PATH="/usr/local/Cellar/qt/5.11.2/lib/cmake" \
-DCMAKE_PREFIX_PATH="/usr/local/Cellar/qtwebkit/5.212-72cfbd_3/lib/cmake/Qt5WebKitWidgets" \
-DCMAKE_PREFIX_PATH="/usr/local/Cellar/qtwebkit/5.212-72cfbd_3/lib/cmake/Qt5WebKit" \
-DFREECAD_USE_EXTERNAL_KDL=1 \
-DBUILD_FEM_NETGEN=1 \
-DFREECAD_CREATE_MAC_APP=1 \
-DCMAKE_INSTALL_PREFIX="./.." \
../FreeCAD-git/
Make exits at 0% already (with -j5 it sometimes gets to 7-11%..) and I don't know what to do.
leonardshelby
Postby leonardshelby » Fri Nov 16, 2018 8:45 pm
Here's the output of make. Are there any more ressources that help getting a working setup to compile FreeCAD on Mojave?
[  0%] Built target Driver
[  0%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh.cpp.o
In file included from /Users/turbo/FreeCAD/FreeCAD-git/src/3rdParty/salomesmesh/src/SMDS/SMDS_Mesh.cpp:47:
In file included from /usr/local/Cellar/vtk/8.1.1_2/include/vtk-8.1/vtkUnsignedCharArray.h:29:
In file included from /usr/local/Cellar/vtk/8.1.1_2/include/vtk-8.1/vtkAOSDataArrayTemplate.h:35:
In file included from /usr/local/Cellar/vtk/8.1.1_2/include/vtk-8.1/vtkGenericDataArray.h:72:
In file included from /usr/local/Cellar/vtk/8.1.1_2/include/vtk-8.1/vtkGenericDataArrayLookupHelper.h:26:
/Library/Developer/CommandLineTools/usr/include/c++/v1/cmath:313:9: error: no member named 'signbit' in the global namespace
using ::signbit;
/Library/Developer/CommandLineTools/usr/include/c++/v1/cmath:314:9: error: no member named 'fpclassify' in the global namespace
using ::fpclassify;
/Library/Developer/CommandLineTools/usr/include/c++/v1/cmath:315:9: error: no member named 'isfinite' in the global namespace; did you mean 'finite'?
using ::isfinite;
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/usr/include/math.h:749:12: note: 'finite' declared here
extern int finite(double)
/Library/Developer/CommandLineTools/usr/include/c++/v1/cmath:316:9: error: no member named 'isinf' in the global namespace
using ::isinf;
/Library/Developer/CommandLineTools/usr/include/c++/v1/cmath:317:9: error: no member named 'isnan' in the global namespace
using ::isnan;
/Library/Developer/CommandLineTools/usr/include/c++/v1/cmath:318:9: error: no member named 'isnormal' in the global namespace
using ::isnormal;
/Library/Developer/CommandLineTools/usr/include/c++/v1/cmath:319:9: error: no member named 'isgreater' in the global namespace; did you mean 'greater'?
using ::isgreater;
/Library/Developer/CommandLineTools/usr/include/c++/v1/functional:720:29: note: 'greater' declared here
struct _LIBCPP_TEMPLATE_VIS greater : binary_function<_Tp, _Tp, bool>
/Library/Developer/CommandLineTools/usr/include/c++/v1/cmath:320:9: error: no member named 'isgreaterequal' in the global namespace; did you mean 'greater_equal'?
using ::isgreaterequal;
/Library/Developer/CommandLineTools/usr/include/c++/v1/functional:749:29: note: 'greater_equal' declared here
struct _LIBCPP_TEMPLATE_VIS greater_equal : binary_function<_Tp, _Tp, bool>
/Library/Developer/CommandLineTools/usr/include/c++/v1/cmath:321:9: error: no member named 'isless' in the global namespace
using ::isless;
/Library/Developer/CommandLineTools/usr/include/c++/v1/cmath:322:9: error: no member named 'islessequal' in the global namespace; did you mean 'less_equal'?
using ::islessequal;
/Library/Developer/CommandLineTools/usr/include/c++/v1/functional:776:29: note: 'less_equal' declared here
struct _LIBCPP_TEMPLATE_VIS less_equal : binary_function<_Tp, _Tp, bool>
/Library/Developer/CommandLineTools/usr/include/c++/v1/cmath:323:9: error: no member named 'islessgreater' in the global namespace
using ::islessgreater;
/Library/Developer/CommandLineTools/usr/include/c++/v1/cmath:324:9: error: no member named 'isunordered' in the global namespace
using ::isunordered;
/Library/Developer/CommandLineTools/usr/include/c++/v1/cmath:325:9: error: no member named 'isunordered' in the global namespace
/usr/local/Cellar/vtk/8.1.1_2/include/vtk-8.1/vtkGenericDataArrayLookupHelper.h:40:13: error: expected member name or ';' after declaration specifiers
static bool isnan(T x)
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/usr/include/math.h:165:7: note: expanded from macro 'isnan'
    ( sizeof(x) == sizeof(float)  ? __inline_isnanf((float)(x))          \
/usr/local/Cellar/vtk/8.1.1_2/include/vtk-8.1/vtkGenericDataArrayLookupHelper.h:40:13: error: expected ')'
/usr/local/Cellar/vtk/8.1.1_2/include/vtk-8.1/vtkGenericDataArrayLookupHelper.h:40:13: note: to match this '('
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/usr/include/math.h:165:5: note: expanded from macro 'isnan'
/usr/local/Cellar/vtk/8.1.1_2/include/vtk-8.1/vtkGenericDataArrayLookupHelper.h:49:15: error: expected member name or ';' after declaration specifiers
  static bool isnan(T)
/usr/local/Cellar/vtk/8.1.1_2/include/vtk-8.1/vtkGenericDataArrayLookupHelper.h:49:15: error: expected ')'
/usr/local/Cellar/vtk/8.1.1_2/include/vtk-8.1/vtkGenericDataArrayLookupHelper.h:49:15: note: to match this '('
/usr/local/Cellar/vtk/8.1.1_2/include/vtk-8.1/vtkGenericDataArrayLookupHelper.h:56:6: error: expected unqualified-id
bool isnan(T x)
/usr/local/Cellar/vtk/8.1.1_2/include/vtk-8.1/vtkGenericDataArrayLookupHelper.h:56:6: error: expected ')'
/usr/local/Cellar/vtk/8.1.1_2/include/vtk-8.1/vtkGenericDataArrayLookupHelper.h:56:6: note: to match this '('
fatal error: too many errors emitted, stopping now [-ferror-limit=]
20 errors generated.
make[2]: *** [src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/SMDS_Mesh.cpp.o] Error 1
make[1]: *** [src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/all] Error 2
make: *** [all] Error 2
Last edited by leonardshelby on Fri Nov 16, 2018 10:20 pm, edited 1 time in total.
Jee-Bee
Postby Jee-Bee » Fri Nov 16, 2018 9:47 pm
please add in code brackets
Darcad
Postby Darcad » Tue Dec 04, 2018 1:21 pm
I have completely erased FreeCAD and install it again. but I have the same problem. I can't open two documents at the same time (Crash). I have to close the first and open the second one, this way it's working.
If I import a part into a project, it's the same. (Crash)
Terminal write a message, maybe it's the reason of all my problems. Can somebody help me please?.
Thank you in advance.
Capture d’écran 2018-12-04 à 13.53.55.png (27.56 KiB) Viewed 1135 times
OS: macOS 10.14
Ws of OS: 64-bit
Ws of FreeCAD: 64-bit
V: 0.18.14976 (Git)
B T: Release
Brc (HEAD detached at e79a19828)
Hash: e79a19828e2e92269ff96110dfeadaa245ad17c2
Python v: 2.7.15
Qt v: 5.11.2
Coin v: 4.0.0a
OCC v: 7.2.0
(fr_CH)
Postby chrisb » Tue Dec 04, 2018 7:34 pm
You can try to reset the configuration with the button in the preferences. Another possiility is to delete your config files or to move them in case you want to restore them.
federico.carminati
Postby federico.carminati » Thu Dec 06, 2018 11:04 am
using ::signbit;
using ::fpclassify;
using ::isfinite;
using ::isinf;
using ::isnan;
using ::isnormal;
using ::isgreater;
using ::isless;
bool isnan(T x)
I have the same problem. Does anyone has a workable solution? If I remove the line
-I/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/usr/include
this error goes away, but I do not know how to convince cmake not to include it. Does anyone have a solution? Best,
Federico Carminati
Switzerland/Suisse
federico.carminati
Postby federico.carminati » Tue Dec 11, 2018 9:40 am
I managed to build FreeCAD on Mojave. After cmake I run
for i in `grep -Rl '\-I/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/usr/include'` ; do sed -e 's?-I/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/usr/include??' $i >/tmp/junk ; mv /tmp/junk $i ; done
Really not elegant, but I think this is a cmake problem. best,
Federico Carminati
Federico Carminati
Switzerland/Suisse
Postby Kunda1 » Tue Dec 11, 2018 5:48 pm
wmayer wrote::point_up:
If I knew how to make a cmake patch I would
ezkay
Postby ezkay » Sat Feb 23, 2019 2:41 pm
My Mac also crashes immediately as I click on "Edit -> Alignment".
The "About FreeCAD"-window works..
Can somebody please explain what cmake is or how and what to do?
MBP 15" Ret mid 2014 - 2,2 GHz Intel Core i7
FreeCAD 0.17
macOS (that we all already know it su**) Mojave 10.14.2 (18C54)
Federico Carminati
