[conda] compile calculix for osx and windows
looo
Re: [conda] compile calculix for osx and windows
Postby looo » Fri Nov 30, 2018 6:27 am
as spooles should be available for win/linux/osx it's time to test calculix build. But it is more diffficult than I expected.
If anyone sees something obviously wrong, please report:
https://github.com/conda-forge/staged-recipes/pull/6827
looo
Postby looo » Sat Dec 01, 2018 7:05 pm
Finally a first build for windows. Maybe someone wants to test this.
conda install calculix -c freecad
https://anaconda.org/freecad/calculix/files
looo
Postby looo » Sat Dec 01, 2018 8:08 pm
tried it myself and it seems like there is missing a ".exe" But after renaming the file it seems to work.
In FreeCAD there are still come problems:
During handling of the above exception, another exception occurred:
  File "C:\Users\hans_\conda\envs\freecad\Library\Mod\Fem\femguiobjects\_ViewProviderFemSolverCalculix.py", line 257, in calculixFinished
    majorVersion, minorVersion = fea.get_ccx_version()
  File "C:\Users\hans_\conda\envs\freecad\Library\Mod\Fem\femtools\ccxtools.py", line 696, in get_ccx_version
    m = re.search(r"(\d+).(\d+)", ccx_stdout)
  File "C:\Users\hans_\conda\envs\freecad\lib\re.py", line 182, in search
    return _compile(pattern, flags).search(string)
TypeError: cannot use a string pattern on a bytes-like object
looo
Postby looo » Fri Dec 07, 2018 7:33 am
https://anaconda.org/conda-forge/calculix/files
Calculix is now uploaded to the conda-forge channel.
Postby Kunda1 » Fri Dec 07, 2018 1:01 pm
Sweet!
Until repology incorporates conda-forge, is there a list (of links) of dependencies that are on conda-forge that FreeCAD currently uses ?
looo
Postby looo » Fri Dec 07, 2018 3:36 pm
Sweet!
Yes, I am trying to have this list updated: https://github.com/FreeCAD/FreeCAD_Cond ... /README.md
UR_
Postby UR_ » Fri Dec 07, 2018 11:31 pm
Just ran your build against guido's official test suite from here:
http://www.dhondt.de/ccx_2.14.test.tar.bz2
And this is the result log
error.ccx2.14looo.txt
(29.02 KiB) Downloaded 17 times
In comparison to ddfem's build
error.ccx2.14ddfem.txt
(8.27 KiB) Downloaded 18 times
As said, ccx is a pretty sensible beast ;)
(especially in regard of code optimizations of fortran parts, perhaps worth a look)
looo
Postby looo » Sat Dec 08, 2018 4:35 am
can you share the script for running this test? I guess it's not always necessary to have matching output. For example Eigenvectors can have different values for the same result using different solvers. But looking at file eg b31.inp there shouldn't be a difference in the result of a static computation...
looo
Postby looo » Sat Dec 08, 2018 4:50 am
ok looking at b31.frd and comparing the results shows one obvious problem:
b31.frd
 -1        12-1.25000E-0011.25000E-0010.00000E+000
 -1        13-1.25000E-001-1.25000E-0010.00000E+000
 -1        141.25000E-001-1.25000E-0010.00000E+000
b31.frd.ref
 -1        12-1.25000E-01 1.25000E-01 0.00000E+00
 -1        13-1.25000E-01-1.25000E-01 0.00000E+00
 -1        14 1.25000E-01-1.25000E-01 0.00000E+00
So it seems we have a formatting problem here and directly comparing the results is not really possible.
edit: This problem is related to the number of exponential digits printed. Somehow the default value is 3, but calculix needs 2. If anyone knows how to fix this, please add a note here: https://github.com/conda-forge/calculix ... k/issues/3
bernd
Postby bernd » Sat Dec 08, 2018 9:35 am
we had similar problem already but I can not find it ...
