[conda] compile calculix for osx and windows
bernd
Re: [conda] compile calculix for osx and windows
Postby bernd » Sat Dec 08, 2018 9:41 am
https://github.com/FreeCAD/FreeCAD/blob ... ix.py#L259 was added as a conclution of the problem
looo
Postby looo » Sat Dec 08, 2018 9:55 am
I have uploaded a new build to the freecad channel with a fix for the digits problem. @ _UR can you try again the tests?
update the package with:
conda install calculix -c freecad
I guess with the digits problem ccx is not useful at all... But I am in contact with the calculix-developer. So hopefully some of the patches can be applied to make building ccx in the future a bit simpler.
edit.: here the fix. This will hopefully avoid a lot of hair pulling research... ;)
_set_output_format(_TWO_DIGIT_EXPONENT); for mingw must be called in the main function.
UR_
Postby UR_ » Sat Dec 08, 2018 2:06 pm
Here it is:
error.ccx2.14looo.txt
(13.5 KiB) Downloaded 65 times
tested with:
(freecad_py3) C:\Users\aio>conda info calculix
calculix 2.14 h391fb7c_1
file name   : calculix-2.14-h391fb7c_1.tar.bz2
version     : 2.14
build string: h391fb7c_1
build number: 1
channel     : https://conda.anaconda.org/freecad/win-64
arch        : x86_64
constrains  : ()
license     : GPL 2
license_family: GPL
md5         : 9acba38ae778b13268aa296eff595a94
platform    : win32
subdir      : win-64
timestamp   : 1544258952924
url         : https://conda.anaconda.org/freecad/win-64/calculix-2.14-h391fb7c_1.tar.bz2
dependencies:
    m2w64-gcc-libs
Used script is from test suite:
compare.sh.txt
(3.05 KiB) Downloaded 41 times
I changed only some lines to ensure usage of correct executable and mingw libraries.
Script was executed in single threaded mode, and that's the sunny side ;)
looo wrote:
Sat Dec 08, 2018 4:35 am
For example Eigenvectors can have different values for the same result using different solvers
Solvers are determined by *.inp files from test suite. Of course no changes were made!
UR_
Postby UR_ » Sat Dec 08, 2018 2:18 pm
Starting FreeCAD from
C:\Users\aio\Miniconda3\envs\freecad_py3\Library\bin
works as expected. No special settings of environ variables are needed.
But running ccx by FreeCAD's FEM WB didn't work, because ccx can't load mingw dll's located at
C:\Users\aio\Miniconda3\envs\freecad_py3\Library\mingw-w64\bin
IMO, a static linked build seams to be more reliable.
looo
Postby looo » Sat Dec 08, 2018 3:03 pm
activating the environment with conda does the job for me and setup all paths etc.
If you want to make the library maximal portable this is true. If it should be part of a modular environment I guess shared libraries are the better approach.
if v is an eigenvector than -v should be the same eigenvector with the same norm. But I am not sure how eigenvectors are normed in calculix.
looo
Postby looo » Tue Dec 18, 2018 8:31 am
Good news:
calculix 2.15 was released which include most of the patches I mentioned earlier. Thanks again @Guido Dhondt.
Also the package is now build with the gcc-7 based toolchain.
Jee-Bee
Postby Jee-Bee » Tue Dec 18, 2018 8:43 am
Good news:
congrats!! thanks for all your (hard) work!!
Postby Kunda1 » Tue Dec 18, 2018 12:11 pm
Good news:
Cool. I bumped downstream Arch AUR and FreeBSD CalculiX maintainers. I hope conda gets in to repology soon
