Compile w/Py3 & Qt5 for Dummies
NormandC
Re: Compile w/Py3 & Qt5 for Dummies
Post by NormandC »
Well, after several tries, I gave up on using cmake-gui. The compilation would always fails around 60%, and the error messages indicated that Qt4 still seemed to be used.
Here's an excerpt:
/usr/include/qt4/QtCore/qstring.h:1277:8: error: ‘QBool’ does not name a type; did you mean ‘bool’?
 inline QBool QStringRef::contains(QLatin1String s, Qt::CaseSensitivity cs) const
        bool
/usr/include/qt4/QtCore/qstring.h:1279:8: error: ‘QBool’ does not name a type; did you mean ‘bool’?
 inline QBool QStringRef::contains(QChar c, Qt::CaseSensitivity cs) const
        bool
/usr/include/qt4/QtCore/qstring.h:1281:8: error: ‘QBool’ does not name a type; did you mean ‘bool’?
 inline QBool QStringRef::contains(const QStringRef &s, Qt::CaseSensitivity cs) const
        bool
src/Mod/Draft/App/CMakeFiles/DraftUtils.dir/build.make:158: recipe for target 'src/Mod/Draft/App/CMakeFiles/DraftUtils.dir/DraftDxf.cpp.o' failed
make[2]: *** [src/Mod/Draft/App/CMakeFiles/DraftUtils.dir/DraftDxf.cpp.o] Error 1
CMakeFiles/Makefile2:3413: recipe for target 'src/Mod/Draft/App/CMakeFiles/DraftUtils.dir/all' failed
make[1]: *** [src/Mod/Draft/App/CMakeFiles/DraftUtils.dir/all] Error 2
I finally succeeded in compiling FreeCAD with Py3/Qt5 using the CLI based on triplus' simple line of code.
https://forum.freecadweb.org/viewtopic. ... 40#p275323
Founder
Post by wmayer »
BUILD_QT5 is also a switch in the CMake GUI you have to check.
NormandC
Post by NormandC »
But I did check it. What's odd is I succeeded in compiling with Qt5 and Py2. But trying to set switches for Py3 and Qt5 from cmake-gui repeatedly fails for me with the error above. And I started from a clean build folder at least two times.
Moult
Post by Moult »
Good day all. I have successfully compiled FreeCAD on Gentoo with Python 3 and Qt5.
First, I needed all the dependencies. I found out pretty quickly that there are quite a lot of dependencies, and they are a little tricky to get all in one place. Even in Gentoo they are not all there in the tree. I was lucky to find that there is a Gentoo overlay by waebbl which has an ebuild for FreeCAD. By attempting to emerge that, it resolves all the dependencies.
Resolving dependencies will be different on your system, but that ebuild does list all of the required packages (see L50-90), which can help guide you.
Now, all that's left is to compile FreeCAD itself. This is relatively straightforward:
$ git clone https://github.com/FreeCAD/FreeCAD.git
$ cd FreeCAD
$ cmake -DPYTHON_LIBRARY=/usr/lib64/libpython3.6m.so -DPYTHON_INCLUDE_DIR=/usr/include/python3.6m -DBUILD_QT5=ON -DPYTHON_PACKAGES_PATH=/usr/lib64/python3.6/site-packages -DPYTHON_EXECUTABLE=/usr/bin/python3.6 .
$ make
$ ./bin/FreeCAD
Please note that library "*.so" file, include directory, site-packages path, and executable may be different. The Unix "locate" command may help you find out where yours are on your system. You will know if it works if in the cmake step it says it finds the python 3 version for boost, and the python 3 executable.
Keep in mind that you will need to make sure you are doing it on a fresh clone. If you have messed around, you should reset your git directory:
$ > .gitignore
$ git clean -df
$ git reset --hard HEAD
For future reference, you can inspect all cmake flags by doing `cmake -LH`.
I hope it helps.
bernd
Post by bernd »
Moult wrote: Sat Jan 12, 2019 11:12 am ... you can inspect all cmake flags by doing `cmake -LH`.
never knew about that one :D
bernd
Post by bernd »
@Normand: Which ubuntu system are you on?
Moult
Post by Moult »
I would like to edit the wiki page https://www.freecadweb.org/wiki/CompileOnUnix to include these instructions, as well as what I have discovered specifically for the Gentoo distribution. (I would also like to fix some of the mistakes I have seen in the tutorials) However, I am told I need an account. Can somebody please help create an account for me? I would like "Moult" to be my username.
NormandC
Post by NormandC »
bernd wrote: Sat Jan 12, 2019 8:47 pm @Normand: Which ubuntu system are you on?
OS: Ubuntu 18.04.1 LTS
Version: 0.18.15619 (Git)
Hash: 7d8e5662648b794b5c93e28835a2bf5c1fddffec
Python version: 3.6.7
Qt version: 5.9.5
Locale: French/Canada (fr_CA)
Moult wrote: Sat Jan 12, 2019 9:21 pm I am told I need an account. Can somebody please help create an account for me?
https://forum.freecadweb.org/viewtopic.php?f=21&t=6830
Moult
Post by Moult »
FYI, wiki page updated.
reox
Post by reox »
I got QT5 + Py3.7 working on debian sid using these changes: https://github.com/reox/FreeCAD_gitpack ... f4af524697
I'm not sure about all the cmake variables, maybe some of them are also autogenerated...
But it looks like that freecad is not useable then:
<class 'AttributeError'>: 'Gui.ViewProviderDocumentObject' object has no attribute 'Visibility'
Most files I open does not show anything and pressing space on the features gives me this error message.
Should python 3 work already?
OS: Debian GNU/Linux buster/sid
Python version: 3.7.2
Qt version: 5.11.3
Locale: German/Austria (de_AT)
If you like to replicate this:
# Not required if you already have a pbuilder environment
sudo pbuilder create
PACKAGINGBRANCH="dailybuild-occt-qt5"
DEBVERSION="0.18+git$(date +%Y%m%d%H%M)-1"
pushd FreeCAD
git remote add gitpackaging https://github.com/reox/FreeCAD_gitpackaging.git
git remote add gitversioning https://git.launchpad.net/~freecad-maintainers/+git/gitversioning
git remote update
git merge gitpackaging/$PACKAGINGBRANCH --allow-unrelated-histories --no-edit
git merge gitversioning/master --allow-unrelated-histories --no-edit
dch --newversion "$DEBVERSION" --distribution unstable "Daily build"
pdebuild --use-pdebuild-internal
popd
