**FIXED***Latest freecad-community update broke *all* versions of FreeCAD on Ubuntu 18.04
NormandC
Post by NormandC »
EDIT: everything now seems back to normal as of January 12th, you may need to force your software updates.
Warning to any freecad-daily PPA users: do NOT apply today's update!!!! ---> the problem is not the freecad-daily PPA, it's the freecad-community PPA. See below.
kkremitzki wrote:ping
sgrogan wrote:ping
With the latest freecad-daily_0.18~beta1+git201812281613~ubuntu18.04.1, a new libcoin80c package was installed; now both the freecad-stable and freecad-daily packages crash when launched. With freecad-daily I'm getting a totally blank (white) window for a few seconds with 100% , then a crash. Even my self-compiled FreeCAD crashes!
All the FreeCAD versions on my system, including my self-compiled one are completely shot to hell.
How the hell did that happen?!?!?
freecad-stable:
$ freecad
FreeCAD 0.17, Libs: 0.17R13541 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
Sheet Metal workbench loaded
Gtk-Message: 12:32:17.646: Failed to load module "canberra-gtk-module"
freecad: /build/freecad-KxCZeY/freecad-0.17.13541/src/Mod/Part/Gui/TaskDimension.cpp :1175 : static void PartGui::ArcEngine::initClass():  l'assertion « SoEngine::getClassTypeId() != SoType::badType() » a échoué.
Abandon (core dumped)
freecad-daily:
freecad-daily: SoType.cpp :739 : SbBool SoType::isDerivedFrom(SoType) const:  l'assertion « !this->isBad() » a échoué.
Founder
Re: Latest freecad-daily update broke *ALL* versions of FreeCAD on Ubuntu 18.04
Post by wmayer »
According to the error message to me it looks like FreeCAD is linked to two Coin versions. What does this give:
ldd libFreeCADGui.so
NormandC
Post by NormandC »
/var/log/apt/history.log
Start-Date: 2018-12-29  12:26:07
Commandline: aptdaemon role='role-commit-packages' sender=':1.236'
Install: libcoin80c:amd64 (4.0.0~CMake~6f54f1602475+ds1-0ppa1~ubuntu18.04, automatic), libsoqt520:amd64 (1.6.0~ea5cd76+ds1-0ppa1~ubuntu18.04, automatic)
Upgrade: python3-pivy:amd64 (0.6.4-0ppa1~ubuntu18.04.1, 0.6.4-0ppa2~ubuntu18.04), freecad-daily:amd64 (0.18~beta1+git201812252025~ubuntu18.04.1, 0.18~beta1+git201812281613~ubuntu18.04.1), python-pivy:amd64 (0.6.4-0ppa1~ubuntu18.04.1, 0.6.4-0ppa2~ubuntu18.04)
End-Date: 2018-12-29  12:26:22
wmayer wrote: Sat Dec 29, 2018 5:54 pm According to the error message to me it looks like FreeCAD is linked to two Coin versions. What does this give:
Where should I input this from? From default terminal location (home), it finds nothing.
NormandC wrote: Sat Dec 29, 2018 5:44 pm freecad-daily: SoType.cpp :739 : SbBool SoType::isDerivedFrom(SoType) const: l'assertion « !this->isBad() » a échoué.
At least the error message does not lack a certain sense of humour: Yes, this is bad!
NormandC
Re: Latest freecad-community update broke *ALL* versions of FreeCAD on Ubuntu 18.04
Post by NormandC »
I was going crazy, because none of those packages that were installed are found in the freecad-daily PPA.
Turns out, they come from the FreeCAD Community PPA.
https://launchpad.net/~freecad-communit ... ubuntu/ppa
Founder
Post by wmayer »
NormandC wrote: Sat Dec 29, 2018 5:57 pm Where should I input this from? From default terminal location (home), it finds nothing.
From a terminal window. libFreeCADGui.so is underneath /usr/lib/freecad-daily/lib I think. So, either cd into there or type the full path:
ldd /usr/lib/freecad-daily/lib/libFreeCADGui.so
NormandC
Post by NormandC »
So the problem is that freecad-community PPA pushes a python-pivy_0.6.4-0ppa2 update that depends on a new libcoin80c package; but, existing FreeCAD packages still depend on libcoin80v5 from the Ubuntu repositories.
The fix is to revert to the python-pivy_0.6.4-0ppa1 package that is in the freecad-daily PPA; this one depends on libcoin80v5.
NormandC
Post by NormandC »
wmayer wrote: Sat Dec 29, 2018 6:49 pm libFreeCADGui.so is underneath /usr/lib/freecad-daily/lib I think.
Sorry I hadn't noticed your reply just before mine. Indeed that's the directory where libFreeCADGui.so is located.
Just out of curiosity, is there a known way to use ldd recursively, that is to search all sub-directories if I place myself at /? The manpage doesn't mention it.
Founder
Post by wmayer »
Just for my own information, is there a known way to use ldd recursively, that is to search all sub-directories if I place myself at /? The manpage doesn't mention it.
I don't think this is possible.
kkremitzki
Post by kkremitzki »
Sorry, this was me. I'm trying to stage the rollout of the new Coin which fixes the SVG import bug and Pivy with Python 3 support. I'll post more shortly when I get home.
