QtWidgets
keithsloan52
QtWidgets
Postby keithsloan52 » Tue Jan 01, 2019 9:24 pm
I am trying to use Geant4Py with FreeCAD.
Geant4Py uses Qt5 by default and whilst I can see how to build Geant4 with QT4 there is no obvious option for Geant4Py.
So I am after a version of FreeCAD that uses Qt5.
Reading the forum I see that freecad-daily has been update to use Qt5, but when I do a
sudo apt-get update
sudo apt-get install freecad-daily
freecad-daily
And run I get a number of messages where modules cannot find QtWidgets
During initialization the error No module named QtWidgets occurred in /usr/lib/freecad-daily/Mod/Ship/InitGui.py
Please look into the log file for further information
During initialization the error No module named QtWidgets occurred in /usr/lib/freecad-daily/Mod/Tux/InitGui.py
During initialization the error No module named QtWidgets occurred in /usr/lib/freecad-daily/Mod/Plot/InitGui.py
Is there some package I should install to get QtWidgets?
Site Admin
Re: QtWidgets
Postby wmayer » Wed Jan 02, 2019 10:06 am
You have to install PySide2 and shiboken2 which offer the Python bindings for Qt5.
hardeeprai
Re: QtWidgets
Postby hardeeprai » Sun Apr 14, 2019 3:25 pm
To install FreeCAD.18 stable I did distribution upgrade from Ubuntu 16 LTS to 18LTS.
FreeCAD stable:
OS: Ubuntu 18.04.2 LTS
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
does not show start screen.
There are very few
Workbenches from View -> Workbench, 6 in total number,
which include "none" as well. On trying BIM, it says:
No module named 'DraftTools'
File "<string>", line 69, in Initialize
For freecad-daily:
For freecad-daily
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.15rc1
Qt version: 5.9.5
I got message:
On trying to opne BIM workbench, it throw message:
File "/usr/lib/freecad-daily/Mod/Draft/DraftTools.py", line 43, in <module>
from PySide import QtCore,QtGui
File "/usr/lib/freecad-daily/Ext/PySide/QtGui.py", line 2, in <module>
from PySide2.QtWidgets import *
pyside-tools 0.2.15 and shiboken 1.2.2-5 are installed. I could not file shiboken2 and puside2 from package manager.
What can I do?
H.S.Rai
NormandC
Re: QtWidgets
Postby NormandC » Sun Apr 14, 2019 3:51 pm
In my experience, distribution upgrades are always a risky business. They can mess up a system pretty bad. Myself I always make a fresh install.
I recommend you remove any freecad related package, delete both PPA repositories (sometimes the PPA will still link to the older Ubuntu version), then re-add the PPA and re-install freecad.
Note that the freecad-daily PPA is still stuck at 0.18.16093 for now, and is based on Python2/Qt5; the freecad-stable PPA offers the newer 0.18.1 version, and supports both Python2 and Python3 on Qt5. To enable Python 2, install freecad and freecad-python2; freecad-python3 is installed by default.
hardeeprai
Re: QtWidgets
Postby hardeeprai » Mon Apr 15, 2019 2:12 pm
Yes, you are right. But I have been living with this since long, and able to learn many new things from such mess ;-)
I tried to do as above, but unable to get success till time. My focus was to run .18
Removed repositories of freecad.
Then added, and did update and installed freecad, got following error:
<q>
update-alternatives: using /usr/lib/freecad/bin/freecad-python3 to
provide /usr/bin/freecad (freecad) in auto mode
update-alternatives: warning: skip creation of /usr/lib/freecad/lib
because associated file /usr/lib/freecad-python3/lib (of link group
freecad) doesn't exist
</q>
Now on running freecad, got error:
freecad
freecad: error while loading shared libraries: libFreeCADGui.so:
cannot open shared object file: No such file or directory
and on running freecadcmd, getting error:
freecadcmd: error while loading shared libraries: libFreeCADApp.so:
Both these files are not there:
If I can get any hint, to solve it, will be great.
However, for the moment, I am using AppImage, got from:
https://github.com/FreeCAD/FreeCAD/releases
H.S.Rai
ezzieyguywuf
Re: QtWidgets
Postby ezzieyguywuf » Mon Apr 15, 2019 8:40 pm
What do you see when you issue the following command?
dpkg-query -L freecad
What version of python do you have installed? What does the following command show?
apt-cache policy freecad
hardeeprai
Re: QtWidgets
Postby hardeeprai » Wed Apr 17, 2019 2:46 am
hsrai@rai:~$ dpkg-query -L freecad
/usr
/usr/share
/usr/share/doc
/usr/share/doc/freecad
/usr/share/doc/freecad/changelog.Debian.gz
/usr/share/doc/freecad/changelog.gz
/usr/share/doc/freecad/copyright
/usr/share/lintian
/usr/share/lintian/overrides
/usr/share/lintian/overrides/freecad
/usr/share/mime
/usr/share/mime/packages
/usr/share/mime/packages/freecad.xml
hsrai@rai:~$
hsrai@rai:~$ apt-cache policy freecad
freecad:
Installed: 2:0.18.1+dfsg1~201904061907~ubuntu18.04.1
Candidate: 2:0.18.1+dfsg1~201904061907~ubuntu18.04.1
Version table:
*** 2:0.18.1+dfsg1~201904061907~ubuntu18.04.1 500
500 http://ppa.launchpad.net/freecad-mainta ... ble/ubuntu bionic/main amd64 Packages
500 http://ppa.launchpad.net/freecad-mainta ... ble/ubuntu bionic/main i386 Packages
100 /var/lib/dpkg/status
0.16.6712+dfsg1-1ubuntu2 500
500 http://us.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
hsrai@rai:~$
Both 2 and 3.
hsrai@rai:~$ python
python python2.7-config python3.6 python3-unidiff
python2 python2-config python3.6m python-config
python2.7 python3 python3m
hsrai@rai:~$ python
Path of FreeCAD is:
hsrai@rai:~$ which freecad
/usr/bin/freecad
hsrai@rai:~$ ls -l /usr/bin/freecad
lrwxrwxrwx 1 root root 25 Apr 15 15:04 /usr/bin/freecad -> /etc/alternatives/freecad
hsrai@rai:~$ ls -l /etc/alternatives/freecad
lrwxrwxrwx 1 root root 36 Apr 15 15:04 /etc/alternatives/freecad -> /usr/lib/freecad/bin/freecad-python3
hsrai@rai:~$
H.S.Rai
ezzieyguywuf
Re: QtWidgets
Postby ezzieyguywuf » Mon Apr 22, 2019 1:46 pm
freecad:
I find this part interesting - it seems on the ppa that the latest daily posted is from march 15th, however you have something installed from april 6th.
Have you run `sudo apt-get update` recently? It could be your using an older package that for whatever does not work, and was thus reverted to an older commit (I'm just guessing here, but its worth a shot)
ezzieyguywuf
Re: QtWidgets
Postby ezzieyguywuf » Mon Apr 22, 2019 2:13 pm
I think your thread may have gotten hijacked a bit, so sorry about that!
Looking through the Geant4 source code a bit, and specifically the Geat4Py portions, it seems that they use boost::python for wrapping the core c++ library in a python module. That being said, I don't see anything specific to Qt4 or Qt5 in the python wrapping code. In other words, if you compile the core library using qt4, I believe the python wrapper should also use the same, at it will simply call the Geant4 library as it was built.
That being said...
As wmayer mentioned, you need pyside2 and shiboken2 installed - did this fix your problem?
hardeeprai
Re: QtWidgets
Postby hardeeprai » Tue Apr 23, 2019 11:36 am
I am using Ubuntu 18.04.2 LTS (bionic) which has FreeCAD .16
https://packages.ubuntu.com/bionic/freecad
Even that also fail to install:
<q>
[Last few lines of apt-get install freeacad]
Selecting previously unselected package python-qt4-gl.
Preparing to unpack .../28-python-qt4-gl_4.12.1+dfsg-2_amd64.deb ...
Unpacking python-qt4-gl (4.12.1+dfsg-2) ...
Selecting previously unselected package python-pivy.
Preparing to unpack .../29-python-pivy_0.5.0~v609hg-4_amd64.deb ...
Unpacking python-pivy (0.5.0~v609hg-4) ...
Selecting previously unselected package freecad.
Preparing to unpack .../30-freecad_0.16.6712+dfsg1-1ubuntu2_amd64.deb ...
Unpacking freecad (0.16.6712+dfsg1-1ubuntu2) ...
dpkg: error processing archive /tmp/apt-dpkg-install-SjrGQV/30-freecad_0.16.6712+dfsg1-1ubuntu2_amd64.deb (--unpack):
trying to overwrite '/usr/share/freecad/Mod', which is also in package freecad-runtime 2:0.18.1+dfsg1~201904061907~ubuntu18.04.1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
</q>
Then I did:
sudo add-apt-repository ppa:freecad-maintainers/freecad-stable
sudo apt-get update
It shows version 2:0.18.1+dfsg1~201904061907~ubuntu18.04.1 which in your opinion is from future date.
It got installed, but it fail to run. Same problem, as per my previous emails in this thread.
hsrai@rai:~$ freecad
freecad: error while loading shared libraries: libFreeCADGui.so: cannot open shared object file: No such file or directory
hsrai@rai:~$ freecadcmd
freecadcmd: error while loading shared libraries: libFreeCADApp.so: cannot open shared object file: No such file or directory
H.S.Rai
