netgen 6.2, cmake options for compiling for FreeCAD
When compiling netgen 5.3 with configure one had to set some parameters.
Netgen 6.3 uses cmake to set up build. Does someone know which parameters to set for building netgen for FreeCAD on debian.
bernd
EDIT: it is about Netgen 6.2, Version 6.3 is not yet released
bernd
- kkremitzki
Re: cmake options for netgen 6.3
Do you mean 6.2? It doesn't seem 6.3 is released yet from what I can find. Anyway, 6.2 is already in Debian Testing/Unstable so you should just be able to install it (https://tracker.debian.org/pkg/netgen). The rules for the package build here show the flags used: https://salsa.debian.org/science-team/n ... bian/rules
I only need netgen to build FreeCAD with. This never worked with the debian packages. One had to build netgen and to copy include files.
Does it mean on buster we can use the debian packages? are they build with opencascade?
- kkremitzki
Yes, it should be possible to do that as they are built with OCCT 7.3.0 but I've never tried using it in much depth since it seemed disabled in the FEM workbench.
sure, it is disabled in FEM and Mesh wb if FreeCAD is not build with netgen. As soon as FreeCAD is build with netgen the mesher is available in FEM an in Mesh WB.
I lately switched to Buster and Py3 and Qt5 and just realised no netgen anymore for my in FEM wb ...
yes. I changed the topic title in this regardkkremitzki wrote: ↑Thu Jan 10, 2019 8:35 pm Do you mean 6.2? It doesn't seem 6.3 is released yet from what I can find.
Re: netgen 6.2, cmake options for compiling for FreeCAD
with this I got it compiled ... The strange thing is netgen cmake would like to have write permissions to the install dir I never had this on cmake or make run ... I just made them with sudo. I may try later if it would work without too.
ok now FreeCAD with netgen ...
git clone https://github.com/looooo/netgen netgen
mkdir build
cd build
sudo cmake \
-DUSE_PYTHON=False \
-DUSE_GUI=False \
-DUSE_OCC=True \
-DOCC_INCLUDE_DIR=/usr/include/occt \
../netgen
sudo make -j4
sudo make install
I guess this is because of the "superbuild". There is an option to disable "superbuild":
https://github.com/conda-forge/netgen-f ... ild.sh#L19
looo wrote: ↑Sat Jan 12, 2019 1:10 pmI guess this is because of the "superbuild". There is an option to disable "superbuild":
mkdir build
cd build
cmake \
-DUSE_GUI=False \
-DUSE_OCC=True \
-DUSE_SUPERBUILD=False \
../netgen
make -j4
sudo make install
