(SOLVED) Compile error when using OpenCascade 7.3 and netgen
apeltauer
Postby apeltauer » Wed Jan 16, 2019 8:40 am
Hi all,
during compiling FreeCAD with OpenCascade 7.3 on Windows I get the following compile error:
\src\3rdParty\salomesmesh\inc\NETGENPlugin_Mesher.hxx(88): fatal error C1017: invalid integer constant expression
this is the source code in NETGENPlugin_Mesher.hxx:
#if NETGEN_VERSION < NETGEN_VERSION_STRING(6,0)
Does anyone know why this happens when compiling with OpenCascade 7.3?? Everything works with OCC 7.1!
Br Manuel
Site Admin
Re: Compile error when using OpenCascade 7.3 and netgen
Postby wmayer » Wed Jan 16, 2019 9:35 am
Maybe this is the problem:
#define NETGEN_VERSION_STRING(a,b) (a << 16) + (b << 8)
Try this
#define NETGEN_VERSION_STRING(a,b) ((a << 16) + (b << 8))
or this
#define NETGEN_VERSION_STRING(a,b) ((a << 16) | (b << 8))
apeltauer
Postby apeltauer » Wed Jan 16, 2019 2:16 pm
Thanks for the help.
After debuging i figured out the the netgen which was found by cmake was from the conda environment.
"NETGEN_VERSION" was set to 6.2-dev, this is why it didnt worked.
After removing the conda stuff from my env varibale the compiling works...
Sorry for the noise and thanks for the help!
