FreeCAD 0.17 32bit was compiled failed in Windows
JOE_FU
Postby JOE_FU » Sat Jan 19, 2019 2:01 am
I used FreeCAD 0.17 64-bit before, but I want to use FreeCAD0.17 32-bit now, but I can't compiled it, and I can't parse external commands.
Creating library E:/FreeCAD32/build_17/lib/Debug/DriverSTL_d.lib and object E:/FreeCAD32/build_17/lib/Debug/DriverSTL_d.exp
37> DriverSTL_R_SMDS_Mesh.obj: Error LNK2001: Unresolved external symbol "public:virtual class opencascade :: handle <class Standard_Type> const&__thiscall Standard_Transient:: DynamicType(void)const"(?DynamicType @ Standard_Transient @@ UBEABV?$ handle @VStandard_Type @@@ opencascade @@ XZ)
37> DriverSTL_W_SMDS_Mesh.obj: error LNK2001: unresolved external symbol?? "Public: virtual class opencascade :: handle <class Standard_Type> const & __ thiscall Standard_Transient :: DynamicType (void) const" (DynamicType @ Standard_Transient @@ UBEABV $ handle @VStandard_Type @@@ opencascade @@ XZ)
37> DriverSTL_R_SMDS_Mesh.obj: Error LNK2019: Unresolved external symbol "public:void __thiscall Standard_Transient::IncrementRefCounter(void)const"(?IncrementRefCounter @ Standard_Transient @@ QBEXXZ), the symbol in the function "private:void __thiscall opencascade :: Handle <class NCollection_BaseAllocator> :: BeginScope(void)" (?BeginScope @?$ handle @ VNCollection_BaseAllocator @@@ opencascade @@ AAEXXZ) is referenced
37> DriverSTL_W_SMDS_Mesh.obj: Error LNK2001: Unresolved external symbol "public:void __thiscall Standard_Transient::IncrementRefCounter(void)const"(?IncrementRefCounter @ Standard_Transient @@ QBEXXZ)
37> DriverSTL_R_SMDS_Mesh.obj: Error LNK2019: Unresolved external symbol "public:int __thiscall Standard_Transient::DecreationRefCounter(void)const"(?DecrementRefCounter @ Standard_Transient @@ QBEHXZ), the symbol in the function "private:void __thiscall opencascade :: Handle <class NCollection_BaseAllocator> :: EndScope(void)" (?EndScope @?$ handle @ VNCollection_BaseAllocator @@@ opencascade @@ AAEXXZ) is referenced
37> DriverSTL_W_SMDS_Mesh.obj: Error LNK2001: Unresolved external symbol "public:int __thiscall Standard_Transient::DecrementRefCounter(void)const"(?DecrementRefCounter @ Standard_Transient @@ QBEHXZ)
37> DriverSTL_R_SMDS_Mesh.obj: Error LNK2019: unresolved external symbol "public: static class Standard_Type * __cdecl Standard_Type :: Register (char const *, char const *, unsigned int, class opencascade :: handle <class Standard_Type> const &)" (?Register @ Standard_Type @@ SAPAV1 @ PBD0IABV?$ handle @ VStandard_Type @@@ opencascade @@@ Z), the symbol is in the function "public:static class opencascade :: handle <class Standard_Type> const&__cdecl opencascade :: type_instance <class Standard_ConstructionError referenced> :: get (void) "(? get @? $ type_instance @ VStandard_ConstructionError @@@ opencascade @@ SAABV? $ handle @ VStandard_Type @@@ 2 @ XZ) in
37> DriverSTL_W_SMDS_Mesh.obj: Error LNK2001: unresolved external symbol "public: static class Standard_Type * __cdecl Standard_Type :: Register (char const *, char const *, unsigned int, class opencascade :: handle <class Standard_Type> const &)" (?Register @ Standard_Type @@ SAPAV1 @ PBD0IABV?$ handle @ VStandard_Type @@@ opencascade @@@ Z)
37> DriverSTL_R_SMDS_Mesh.obj: Error LNK2019: Unresolved external symbol "public:virtual __thiscall Standard_Failure::~Standard_Failure(void)"(?? 1Standard_Failure @@ UAE @ XZ), the symbol in the function "public:virtual __thiscall Standard_DomainError: :~Standard_DomainError(void)" (?? 1Standard_DomainError @@ UAE @ XZ) is referenced
37> DriverSTL_W_SMDS_Mesh.obj: Error LNK2001: Unresolved external symbol "public:virtual __thiscall Standard_Failure::~Standard_Failure(void)"(?? 1Standard_Failure @@ UAE @ XZ)
37> DriverSTL_R_SMDS_Mesh.obj: Error LNK2001: Unresolved external symbol "public:virtual char const * __thiscall Standard_Failure :: GetMessageString(void)const"(?GetMessageString @ Standard_Failure @@ UBEPBDXZ)
37> DriverSTL_W_SMDS_Mesh.obj: Error LNK2001: Unresolved external symbol "public:virtual char const * __thiscall Standard_Failure :: GetMessageString(void)const"(?GetMessageString @ Standard_Failure @@ UBEPBDXZ)
37> DriverSTL_R_SMDS_Mesh.obj: Error LNK2001: Unresolved external symbol "public:virtual void __thiscall Standard_Failure::SetMessageString(char const * const)"(?SetMessageString @ Standard_Failure @@ UAEXQBD @ Z)
37> DriverSTL_W_SMDS_Mesh.obj: Error LNK2001: Unresolved external symbol "public:virtual void __thiscall Standard_Failure::SetMessageString(char const * const)"(?SetMessageString @ Standard_Failure @@ UAEXQBD @ Z)
37> DriverSTL_R_SMDS_Mesh.obj: error LNK2019: unresolved external symbol?? "Public: static class opencascade :: handle <class NCollection_BaseAllocator> const & __ cdecl NCollection_BaseAllocator :: CommonBaseAllocator (void)" (CommonBaseAllocator @ NCollection_BaseAllocator @@ SAABV $ handle @ VNCollection_BaseAllocator @ @@ opencascade @@ XZ), the symbol in the function "protected: __ thiscall NCollection_BaseMap :: NCollection_BaseMap (int, unsigned int, class opencascade :: handle <class NCollection_BaseAllocator> const &)" (?? 0NCollection_BaseMap @@ IAE @HIABV $? Referenced in handle @ VNCollection_BaseAllocator @@@ opencascade @@@ Z)
37> DriverSTL_R_SMDS_Mesh.obj: Error LNK2019: Unresolved external symbol "protected:unsigned int __thiscall NCollection_BaseMap :: BeginResize(int,int&,class NCollection_ListNode * *&,class NCollection_ListNode * *&)const"(?BeginResize @ NCollection_BaseMap @ @ IBEIHAAHAAPAPAVNCollection_ListNode @@ 1 @ Z), the symbol is in the function "public:void __thiscall NCollection_DataMap <class gp_Pnt,class SMDS_MeshNode *,struct`s anonymous namespace':: Hasher> ::ReSize(int)"(?ReSize @?$ NCollection_DataMap @ Vgp_Pnt @@ PAVSMDS_MeshNode @@ UHasher @?A0xd0548417 @@@@ QAEXH @ Z)
Creating library E:/FreeCAD32/build_17/lib/Debug/SMESHDS_d.lib and object E:/FreeCAD32/build_17/lib/Debug/SMESHDS_d.exp
4>E:\FreeCAD32\FreeCAD-0.17\src\zipios++\basicentry.cpp(36): warning C4244: “=”: Convert from “std::streamoff” to “int”, data may be lost
36>SMESHDS_GroupOnGeom.obj : error LNK2001: Unresolved external symbol "public: virtual class opencascade::handle<class Standard_Type> const & __thiscall Standard_Transient::DynamicType(void)const " (?DynamicType@Standard_Transient@@UBEABV?$handle @VStandard_Type@@@opencascade@@XZ)
36>SMESHDS_Mesh.obj : error LNK2001: Unresolved external symbol "public: virtual class opencascade::handle<class Standard_Type> const & __thiscall Standard_Transient::DynamicType(void)const " (?DynamicType@Standard_Transient@@UBEABV?$handle @VStandard_Type@@@opencascade@@XZ)
36>SMESHDS_SubMesh.obj : error LNK2001: Unresolved external symbol "public: virtual class opencascade::handle<class Standard_Type> const & __thiscall Standard_Transient::DynamicType(void)const " (?DynamicType@Standard_Transient@@UBEABV?$handle @VStandard_Type@@@opencascade@@XZ)
36>SMESHDS_Document.obj : error LNK2001: Unresolved external symbol "public: virtual class opencascade::handle<class Standard_Type> const & __thiscall Standard_Transient::DynamicType(void)const " (?DynamicType@Standard_Transient@@UBEABV?$handle @VStandard_Type@@@opencascade@@XZ)
36>SMESHDS_Group.obj : error LNK2001: Unresolved external symbol "public: virtual class opencascade::handle<class Standard_Type> const & __thiscall Standard_Transient::DynamicType(void)const " (?DynamicType@Standard_Transient@@UBEABV?$handle @VStandard_Type@@@opencascade@@XZ)
36>SMESHDS_GroupBase.obj : error LNK2001: Unresolved external symbol "public: virtual class opencascade::handle<class Standard_Type> const & __thiscall Standard_Transient::DynamicType(void)const " (?DynamicType@Standard_Transient@@UBEABV?$handle @VStandard_Type@@@opencascade@@XZ)
36>SMESHDS_GroupOnFilter.obj : error LNK2019: Unresolved external symbol "public: virtual class opencascade::handle<class Standard_Type> const & __thiscall Standard_Transient::DynamicType(void)const " (?DynamicType@Standard_Transient@@UBEABV?$handle @VStandard_Type@@@opencascade@@XZ), the symbol in the function "public: void __thiscall std::list<class SMESHDS_Hypothesis const *, class std::allocator<class SMESHDS_Hypothesis const *> >::_Incsize(unsigned int)" (?_Incsize@?$list@PBVSMESHDS_Hypothesis@@V?$allocator@PBVSMESHDS_Hypothesis@@@std@@@std@@QAEXI@Z)
36>SMESHDS_GroupOnGeom.obj : error LNK2019: Unresolved external symbol "public: void __thiscall Standard_Transient::IncrementRefCounter(void)const " (?IncrementRefCounter@Standard_Transient@@QBEXXZ), the symbol is in the function __unwindfunclet$??1TopoDS_Shape@@ Quoted in QAE@XZ$0
36>SMESHDS_Mesh.obj : error LNK2001: Unresolved external symbol "public: void __thiscall Standard_Transient::IncrementRefCounter(void)const " (?IncrementRefCounter@Standard_Transient@@QBEXXZ)
36>SMESHDS_SubMesh.obj : error LNK2001: Unresolved external symbol "public: void __thiscall Standard_Transient::IncrementRefCounter(void)const " (?IncrementRefCounter@Standard_Transient@@QBEXXZ)
36>SMESHDS_Document.obj : error LNK2001: Unresolved external symbol "public: void __thiscall Standard_Transient::IncrementRefCounter(void)const " (?IncrementRefCounter@Standard_Transient@@QBEXXZ)
36>SMESHDS_Group.obj : error LNK2001: Unresolved external symbol "public: void __thiscall Standard_Transient::IncrementRefCounter(void)const " (?IncrementRefCounter@Standard_Transient@@QBEXXZ)
36>SMESHDS_GroupBase.obj : error LNK2001: Unresolved external symbol "public: void __thiscall Standard_Transient::IncrementRefCounter(void)const " (?IncrementRefCounter@Standard_Transient@@QBEXXZ)
36>SMESHDS_GroupOnFilter.obj : error LNK2001: Unresolved external symbol "public: void __thiscall Standard_Transient::IncrementRefCounter(void)const " (?IncrementRefCounter@Standard_Transient@@QBEXXZ)
36>SMESHDS_GroupOnGeom.obj : error LNK2001: Unresolved external symbol "public: int __thiscall Standard_Transient::DecrementRefCounter(void)const " (?DecrementRefCounter@Standard_Transient@@QBEHXZ)
36>SMESHDS_Mesh.obj : error LNK2001: Unresolved external symbol "public: int __thiscall Standard_Transient::DecrementRefCounter(void)const " (?DecrementRefCounter@Standard_Transient@@QBEHXZ)
36>SMESHDS_SubMesh.obj : error LNK2001: Unresolved external symbol "public: int __thiscall Standard_Transient::DecrementRefCounter(void)const " (?DecrementRefCounter@Standard_Transient@@QBEHXZ)
36>SMESHDS_Document.obj : error LNK2019: Unresolved external symbol "public: int __thiscall Standard_Transient::DecrementRefCounter(void)const " (?DecrementRefCounter@Standard_Transient@@QBEHXZ), the symbol in the function "private: void __thiscall opencascade:: Referenced in handle<class NCollection_BaseAllocator>::EndScope(void)" (?EndScope@?$handle@VNCollection_BaseAllocator@@@opencascade@@AAEXXZ)
36>SMESHDS_Group.obj : error LNK2001: Unresolved external symbol "public: int __thiscall Standard_Transient::DecrementRefCounter(void)const " (?DecrementRefCounter@Standard_Transient@@QBEHXZ)
36>SMESHDS_GroupBase.obj : error LNK2001: Unresolved external symbol "public: int __thiscall Standard_Transient::DecrementRefCounter(void)const " (?DecrementRefCounter@Standard_Transient@@QBEHXZ)
36>SMESHDS_GroupOnFilter.obj : error LNK2001: Unresolved external symbol "public: int __thiscall Standard_Transient::DecrementRefCounter(void)const " (?Decr
There are many similar mistakes. Do you know how to solve them? Maybe someone can help me or provide me with some FreeCAD0.17 32bit compiled source code and libraries.
I am looking forward to your reply.
wandererfan
Re: FreeCAD 0.17 32bit was compiled failed in Windows
Postby wandererfan » Sat Jan 19, 2019 2:04 pm
Did you try building without the FEM & FEM_NETGEN modules? All the errors seem to be SMESH related, and AFAIK FEM is where SMESH is used.
JOE_FU
Postby JOE_FU » Tue Jan 22, 2019 2:36 am
Not only these errors, but also some similar mistakes are not put up.
Site Admin
Postby wmayer » Tue Jan 22, 2019 10:01 am
The errors you get are linker errors. So, the compilation actually worked. Are you sure you use the 32-bit version of the OCCT libraries?
JOE_FU
Postby JOE_FU » Wed Jan 23, 2019 2:42 am
I downloaded the libraries in the link below.
https://github.com/FreeCAD/FreeCAD-ports-cache/releases
Maybe you can give me your correct download link.Thank you.
Site Admin
Postby wmayer » Wed Jan 23, 2019 10:29 am
The 32-bit version is offered with https://github.com/FreeCAD/FreeCAD-port ... 86_VC12.7z
And note that you also must use Visual Studio 2013, using a newer version won't work.
sgrogan
Postby sgrogan » Thu Jan 24, 2019 12:00 am
There are no debug libs for occt or vtk in the Libpack :oops:
A release build should work.
