Clearly something wrong in my config, but what? Missing environment variable? Bad config file somewhere? Any suggestions appreciated.
Qt5.11.2 is installed in /opt/Qt_5.11 using qt-unified-linux-x64-3.0.6-online.run from https://www.qt.io
Mint default Qt5 is 5.9.
"During initialization the error /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /usr/local/lib/python2.7/dist-packages/PySide2/QtCore.so) occurred in /usr/lib/freecad-daily/Mod/Ship/InitGui.py
Please look into the log file for further information"
/usr/lib/freecad-daily/Mod/Draft/InitGui.py
/usr/lib/freecad-daily/Mod/Tux/InitGui.py
/usr/lib/freecad-daily/Mod/Plot/InitGui.py
/usr/lib/freecad-daily/Mod/Arch/InitGui.py
After switching to PD, I get these additional messages:
Wizard shaft module cannot be loaded
Involute gear module cannot be loaded
Unknown command 'PartDesign_InvoluteGear'
Error in Profiles module
Unknown command 'Sketcher_ProfilesHexagon1'
Features from CompoundTools package cannot be loaded. /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /usr/local/lib/python2.7/dist-packages/PySide2/QtGui.so)
Features from BOPTools package cannot be loaded. /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.11' not found (required by /usr/local/lib/python2.7/dist-packages/PySide2/QtCore.so)
Unknown command 'Part_JoinConnect'
Unknown command 'Part_JoinEmbed'
Unknown command 'Part_JoinCutout'
Unknown command 'Part_BooleanFragments'
Unknown command 'Part_SliceApart'
Unknown command 'Part_Slice'
Unknown command 'Part_XOR'
Unknown command 'Part_ExplodeCompound'
Unknown command 'Part_CompoundFilter'
Version: 0.18.15697 (Git)
Hash: dedaa807629ab25cf32977d30bf7610f1346aff7
Python version: 2.7.15rc1
Qt version: 5.9.5
