0003784: Path: error - /opt/freecad/lib/libSMDS.so: undefined symbol: _ZN19vtkUnstructuredGrid12GetMeshMTimeEv
memfis
Postby memfis » Sun Feb 10, 2019 5:47 pm
OS: Arch Linux
Version: 0.18.15657 (Git)
Hash: ed06cbe62676e954b486afe594310452af582c1c
Python version: 2.7.15
Qt version: 5.12.0
Coin version: 3.1.3
Locale: Russian/Russia (ru_RU)
run FreeCad
choose the Path workbench
When selecting the Path workbench, the error message
File "<string>", line 75, in Initialize
File "/opt/freecad/Mod/Path/PathScripts/PathGuiInit.py", line 69, in Startup
from PathScripts import PathSurfaceGui
File "/opt/freecad/Mod/Path/PathScripts/PathSurfaceGui.py", line 27, in <module>
import PathScripts.PathSurface as PathSurface
File "/opt/freecad/Mod/Path/PathScripts/PathSurface.py", line 28, in <module>
import MeshPart
and the workbench do not start.
Replaced the package coin -> coin-hg, rebuilt the program. The result is about the same
0.18, Libs: 0.18R15687 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
/usr/lib/python2.7/site-packages/pivy/_coin.so: undefined symbol: _ZN23SoGLTextureImageElement15hasTransparencyEP7SoState
File "<string>", line 73, in Initialize
File "/opt/freecad/Mod/Path/PathScripts/PathJobCmd.py", line 27, in <module>
import PathScripts.PathJob as PathJob
File "/opt/freecad/Mod/Path/PathScripts/PathJob.py", line 25, in <module>
import ArchPanel
File "/opt/freecad/Mod/Arch/ArchPanel.py", line 24, in <module>
import FreeCAD,Draft,ArchComponent,DraftVecUtils,ArchCommands,math, Part, ArchNesting
File "/opt/freecad/Mod/Arch/ArchComponent.py", line 83, in <module>
import FreeCAD,Draft,ArchCommands,math,sys
File "/opt/freecad/Mod/Arch/ArchCommands.py", line 32, in <module>
from DraftTools import translate, utf8_decode
File "/opt/freecad/Mod/Draft/DraftTools.py", line 44, in <module>
from DraftGui import todo, translate, utf8_decode
File "/opt/freecad/Mod/Draft/DraftGui.py", line 2488, in <module>
import DraftSnap
File "/opt/freecad/Mod/Draft/DraftSnap.py", line 36, in <module>
import FreeCAD, FreeCADGui, math, Draft, DraftGui, DraftTrackers, DraftVecUtils, itertools
File "/opt/freecad/Mod/Draft/DraftTrackers.py", line 38, in <module>
from pivy import coin
File "/usr/lib/python2.7/site-packages/pivy/__init__.py", line 28, in <module>
from coin import SoDB, SoNodeKit, SoInteraction
File "/usr/lib/python2.7/site-packages/pivy/coin.py", line 36, in <module>
_coin = swig_import_helper()
File "/usr/lib/python2.7/site-packages/pivy/coin.py", line 32, in swig_import_helper
_mod = imp.load_module('_coin', fp, pathname, description)
OS: Arch Linux
Version: 0.18.15805 (Git)
Hash: f431226bb827d960588485fbae5b5c072c7b640c
Qt version: 5.12.1
File "/home/memfis/yaourt-tmp-memfis/freecad_020/Mod/Path/PathScripts/PathJobCmd.py", line 27, in <module>
File "/home/memfis/yaourt-tmp-memfis/freecad_020/Mod/Path/PathScripts/PathJob.py", line 25, in <module>
import ArchPanel
File "/home/memfis/yaourt-tmp-memfis/freecad_020/Mod/Arch/ArchPanel.py", line 24, in <module>
File "/home/memfis/yaourt-tmp-memfis/freecad_020/Mod/Arch/ArchComponent.py", line 83, in <module>
File "/home/memfis/yaourt-tmp-memfis/freecad_020/Mod/Arch/ArchCommands.py", line 32, in <module>
File "/home/memfis/yaourt-tmp-memfis/freecad_020/Mod/Draft/DraftTools.py", line 44, in <module>
File "/home/memfis/yaourt-tmp-memfis/freecad_020/Mod/Draft/DraftGui.py", line 2503, in <module>
import DraftSnap
File "/home/memfis/yaourt-tmp-memfis/freecad_020/Mod/Draft/DraftSnap.py", line 36, in <module>
File "/home/memfis/yaourt-tmp-memfis/freecad_020/Mod/Draft/DraftTrackers.py", line 38, in <module>
https://www.freecadweb.org/tracker/view.php?id=3784
triplus
Re: 0003784: Path: error - /opt/freecad/lib/libSMDS.so: undefined symbol: _ZN19vtkUnstructuredGrid12GetMeshMTimeEv
Postby triplus » Sun Feb 10, 2019 5:55 pm
Did you compile FreeCAD? Usually such issues are related to borked build. Deleting everything and starting from scratch could therefore resolve the issue.
memfis
Postby memfis » Sun Feb 10, 2019 6:22 pm
I installed from the repository, and from scratch from git.
memfis
Postby memfis » Sun Feb 10, 2019 6:39 pm
Power is changing. Rolled back -
python-pivy & python2-pivy
The error has changed, but the result is the same -
OS: "Arch Linux"
Version: 0.17.13544 (Git)
Branch: makepkg
Hash: e1db7bff8ff36439373eb9a426567d8afe289c4d
Qt version: 5.12.0
No module named _coin
File "<string>", line 52, in Initialize
File "/usr/lib/freecad/Mod/Path/PathScripts/PathDressupDogbone.py", line 31, in <module>
import PathScripts.PathDressup as PathDressup
File "/usr/lib/freecad/Mod/Path/PathScripts/PathDressup.py", line 27, in <module>
File "/usr/lib/freecad/Mod/Path/PathScripts/PathJob.py", line 25, in <module>
import ArchPanel
File "/usr/lib/freecad/Mod/Arch/ArchPanel.py", line 24, in <module>
File "/usr/lib/freecad/Mod/Arch/ArchComponent.py", line 34, in <module>
File "/usr/lib/freecad/Mod/Arch/ArchCommands.py", line 31, in <module>
File "/usr/lib/freecad/Mod/Draft/DraftTools.py", line 43, in <module>
from DraftGui import todo, QtCore, QtGui, translate, utf8_decode
File "/usr/lib/freecad/Mod/Draft/DraftGui.py", line 2276, in <module>
import DraftSnap
File "/usr/lib/freecad/Mod/Draft/DraftSnap.py", line 36, in <module>
File "/usr/lib/freecad/Mod/Draft/DraftTrackers.py", line 38, in <module>
File "/usr/lib/python2.7/site-packages/pivy/coin.py", line 26, in <module>
File "/usr/lib/python2.7/site-packages/pivy/coin.py", line 25, in swig_import_helper
return importlib.import_module('_coin')
File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
__import__(name)
OS: Arch Linux
Qt version: 5.12.1
import ArchPanel
import DraftSnap
__import__(name)
package, of course, is -
pacman -Qs coin
local/coin-docs 3.1.3-18
A high-level 3D graphics toolkit on top of OpenGL (docs)
local/coin-hg r11936.6c7a6ce6eed6-1
A high-level, retained-mode 3D graphics toolkit compatible with Open Inventor 2.1
local/python-pivy 0.6.4-1
A Python binding for Coin
local/python2-pivy 20101207-1
Coin binding for Python
triplus
Postby triplus » Sun Feb 10, 2019 6:48 pm
Please use the code tags.
Until you resolve the issue, you can use the AppImage.
https://github.com/FreeCAD/FreeCAD/releases
As for resolving the issue. This second issue feels Pivy related, therefore try reinstalling the Pivy package.
memfis
Postby memfis » Sun Feb 10, 2019 6:52 pm
Rolled back
coin-hg -> coin
./../freecad_020/bin/FreeCAD: symbol lookup error: /home/memfis/yaourt-tmp-memfis/freecad_020/lib/libFreeCADGui.so: undefined symbol: _ZN6SoBase12createNotRecEv
freecad
freecad: symbol lookup error: /usr/lib/freecad/lib/libFreeCADGui.so: undefined symbol: _ZN6SoBase12createNotRecEv
Postby Kunda1 » Mon Feb 11, 2019 10:53 am
@memfis opened an issue prior to this thread: issue #3784
triplus
Postby triplus » Tue Feb 12, 2019 11:17 pm
This is highly likely packaging/compile issue.
