Conda AppImage: all base WBs up to date?
I set up a new System with OpenSuse 15.1 beta, where only the conda AppImage works, atm it's
OS: openSUSE Leap 15.1Beta
Version: 0.18.16079 (Git) AppImage
Hash: 6363c90a20b296ab69d7b52230009928199d90df
Python version: 3.6.7
Qt version: 5.6.2
The most things i try'd are working like expected, but some are not.
Especially at the Path WB i have a lot of bugs where are in mind that they are fixed since some time... So for me it looks like Path is not up to date at Conda.
Also i can't customate the toolbar. At the menue where to select the WB where the tool comes from only a few WBs apere, but a lot of not (also not base WBs like Draft)
Qt version: 5.6.2
Gruß Herbert
Re: Conda AppImage: all base WBs up to date?
This works different with QT5/PY3, the Python WB's show up some different. I think it was me and easy-fc that discussed this in the forum. I will search for the thread.
"fight the good fight"
Hi looo,
Not for that issues... that are deffently Path releated issues - like not evenly divided milling pathes, ignored options...
Gruß Herbert
Couldn't find the thread, but this is how it works.
You need to activate the workbench for it to show up in the menu. Even then pure python stuff like the the draft workbench show up under the Python menu entry.
Note that when it comes to FreeCAD 0.18 development builds you still have an option to use Py2/Qt4 AppImage. I could imagine some general Py3/Qt5 bugs will still be detected by people, when it comes to FreeCAD 0.18.
It seems that in AppImage there is something missing:
1) yaml module seems missing
testing:
testing:
2) SSL not working for urllibimport yaml
ModuleNotFoundError: No module named 'yaml'
It would be nice to have those fixed for the 0.18 release deployWe failed to reach a server.
Reason: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:847)
I guess we don't depend on this module officially. Where is it used?
yaml is already bundled with ' FreeCAD_0.18.16085_Conda_Py3QT5-WinVS2015_x64.7z' and 'FreeCAD_0.18.16085_x64_dev_win.7z'
yaml is used by some external wbs and by many FC step model generators for KiCAD libraries
the SSL error message is coming when using urlopen with AppImage (it is working fine with Win Std & Conda build)
here a sample code generating the error in AppImage
import urllib
from urllib import request, error #URLError, HTTPError
url='https://github.com/FreeCAD/FreeCAD/releases'
req = request.Request(url)
try:
response = request.urlopen(req)
resp_ok = True
the_page = response.read().decode("utf-8")
except error.HTTPError as e:
FreeCAD.Console.PrintWarning('The server couldn\'t fulfill the request.')
FreeCAD.Console.PrintWarning('Error code: ' + str(e.code)+'\n')
except error.URLError as e:
FreeCAD.Console.PrintWarning('We failed to reach a server.\n')
FreeCAD.Console.PrintWarning('Reason: '+ str(e.reason)+'\n')
