I can confirm it works now! Thanks!
edit: no wait, there is something else. When I visit
http://localhost:7465/FreeCADGui.html I get this error:
the signature for "getSoDBVersion" should exist
indeed, checking on the python console:
>>> help(FreeCADGui.getSoDBVersion)
File "/usr/bin/../lib/python3.7/_sitebuiltins.py", line 103, in __call__
return pydoc.help(*args, **kwds)
File "/usr/lib/python3.7/pydoc.py", line 1900, in __call__
self.help(request)
File "/usr/lib/python3.7/pydoc.py", line 1959, in help
else: doc(request, 'Help on %s:', output=self._output)
File "/usr/lib/python3.7/pydoc.py", line 1679, in doc
pager(render_doc(thing, title, forceload))
File "/usr/lib/python3.7/pydoc.py", line 1672, in render_doc
return title % desc + '\n\n' + renderer.document(object, name)
File "/usr/lib/python3.7/pydoc.py", line 391, in document
if inspect.isroutine(object): return self.docroutine(*args)
File "/usr/lib/python3.7/pydoc.py", line 1389, in docroutine
signature = inspect.signature(object)
File "/usr/lib/python3.7/inspect.py", line 3083, in signature
return Signature.from_callable(obj, follow_wrapped=follow_wrapped)
File "/usr/lib/python3.7/inspect.py", line 2833, in from_callable
follow_wrapper_chains=follow_wrapped)
File "/usr/lib/python3.7/inspect.py", line 2238, in _signature_from_callable
sig = obj.__signature__
SystemError: the signature for "getSoDBVersion" should exist
