[SOLVED] FreeCAD 0.17 doesn't start
I searched in the forum and found several topics related to this problem, but I think it's not exactly the same so I open another thread.
I've installed two versions of FreeCAD (0.15 and 0.17) and a few weeks ago the two versions worked correctly; but, now, the 0.17 doesn't start (only show the splash screen).
If I run FreeCAD 0.17 from another user there is no problem. I tried to re install FreeCAD 0.17 but it doesn't work.
->>> Log from my user:
Log: Init: Initializing C:\Program Files\FreeCAD 0.17\Mod\Drawing... done
Log: Init: Initializing freecad.pip
Err: Error in FreeCADGuiInit.py: invalid syntax (app.py, line 11)
Log: Destruct Gui::Application
Err: Traceback (most recent call last):
File "<string>", line 168, in <module>
File "<string>", line 145, in InitApplications
File "C:\Program Files\FreeCAD 0.17\bin\lib\importlib\__init__.py", line 37, in import_module
__import__(name)
File "C:\Users\lucia.alonso\AppData\Roaming\Python\Python27\site-packages\freecad\pip\init_gui.py", line 12, in <module>
from freecad.pip.gui import PipWidget
File "C:\Users\lucia.alonso\AppData\Roaming\Python\Python27\site-packages\freecad\pip\gui.py", line 3, in <module>
from freecad.pip.app import pip
<type 'exceptions.SyntaxError'>: invalid syntax (app.py, line 11)
->>> Log from another user:
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Loading GUI of Web module... done
Log: Loading GUI of Start module... done
Log: Loading Start module... done
OS: Windows 7
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
Locale: Spanish/Spain (es_ES)
__import__(name)
OS: Windows 7
OCC version: 7.2.0
- HarryGeier
Re: FreeCAD 0.17 doesn't start
Hello Lucia
Try to remove/rename the users FreeCAD Folder from his appdata/roaming folder , it´s hidden and you need to make visible first, look at the picture of my post in this thread:
https://forum.freecadweb.org/viewtopic. ... 0&start=10
It´s german, but the structure should be clear
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
I forgot to comment in the first post that I had also tried that. I usually work with the configuration files (user.cfg and system.cfg) and thought the error could also be there, but it's not.
But, I just tried it again and the program still hasn't started.
Hi Lucia, your user name is with an accent over i?
No. But, I don't understand why weeks ago FreeCAD 0.17 runs perfectly... could be a Windows update, driver update or something like this?
We have seen such issues after Windows updates. Usually the graphics card driver is the culprit. Try an older/newer/from manufacturer/thirdparty.
- HarryGeier
What about trying 0.18 , the CONDA PY3 Version ?
just as the error comes along in app.py
@Lu27, how did you install FreeCAD? I don't see anything like PipWidget in the current FreeCAD source...
Hi @lu27
You likely installed pip-integration at some point? Or maybe it got installed automatically with Conda based Windows build.
https://github.com/looooo/freecad.pip
That seems to be causing some issues. Best if you ask here:
https://forum.freecadweb.org/viewtopic.php?f=22&t=29584
Thanks for the answers.
@triplus is right, the problem was the installation of Pip-integration. I renamed the folder where the module "freecad" was called "AppData/Roaming/Python" and FreeCAD runs correctly.
