I have a new laptop, install Freecad 017, Part design, make a cirkle, create a coincident, change radius, close the editing of the sketch, create a pad, and than a have a problem, the sketch is not massieve but it has a cup form.
After that a can not select a face for an other sketch! If a wil make an other cirkle on the face it's only to see on the grid
Whats the problem and what is the solution?
[Solved] Freecad do not work on new computer
Reason: added [Solved] to topic title
Re: Freecad do not work on new computer
This sounds like an extremely common operation which usually works flawlessly. From your description it is not possible to understand what might be wrong.
Can you explain in more detail the exact steps you took? A screenshot of the resulting pad would be useful.
Gene
Gene
Sounds very much like a graphics driver issue. Perhaps you find some hints here: https://forum.freecadweb.org/viewtopic.php?f=3&t=30573.
quote=GeneFC post_id=295692 time=1553178480 user_id=8180]
Gene
[/quote]
https://forum.freecadweb.org/download/f ... w&id=79539
Gene
[/quote]
- 2019-03-21.png (231.15 KiB) Viewed 704 times
This looks very much like the Radeon driver issues linked above.
I have install an older version of Redeon and the problem is solved. Super!!!
Thanks for the respons
