PPA problem updating to Release of 0.18
iogui
Postby iogui » Mon Apr 01, 2019 10:04 pm
I have an ubuntu 16.04 machine and I was waiting for the 0.18 FreeCAD to get ready on the ppa. A few minutes ago I've made the apt verification:
sudo apt list --upgradable
The result:
Listing... Pronto
freecad/xenial,xenial 2:0.18+dfsg1~201903301803~ubuntu16.04.1 amd64 [upgradable from: 1:0.17.13541-1ppa3~ubuntu16.04.1]
But when I ran the upgrade, the package was not upgraded, so I forced it by running
sudo apt install freecad
That's what came from it:
Lendo listas de pacotes... Pronto
Construindo árvore de dependências
Lendo informação de estado... Pronto
Os seguintes pacotes foram instalados automaticamente e já não são necessários:
  libboost-signals1.58.0 libfontconfig1-dev libfreetype6-dev
Utilize 'sudo apt autoremove' para os remover.
The following additional packages will be installed:
  freecad-common freecad-python2 freecad-runtime libfreecad-python2-0.18
Pacotes sugeridos:
  freecad-doc povray
Os pacotes a seguir serão REMOVIDOS:
  freecad-doc
Os NOVOS pacotes a seguir serão instalados:
Os pacotes a seguir serão atualizados:
  freecad
1 pacotes atualizados, 4 pacotes novos instalados, 1 a serem removidos e 0 não atualizados.
É preciso baixar 31,8 MB de arquivos.
Depois desta operação, 146 MB de espaço em disco serão liberados.
Você quer continuar? [S/n]
So... to be upgraded, the freecad-doc package had to be removed... but the apt package manager is suggesting for me to install freecad-doc. Don't you think that it is a little bit weird?
Also I didn't understand why the apt upgrade command didn't upgraded FreeCAD, WAS this freecad-doc package preventing FreeCAD to be upgraded?
Also when I try to reinstall freecad-doc, the apt package manager lists freecad as a package to be removed... As it seems there is no freecad-doc package for the freecad 0.18 version, am I right?
Be the change you want to see in the world. - Mahatma Gandhi
kkremitzki
Re: Release of 0.18
Postby kkremitzki » Mon Apr 01, 2019 11:09 pm
Did you do an upgrade, or a full-upgrade/dist-upgrade?
jmaustpc
Re: PPA problem updating to Release of 0.18
Postby jmaustpc » Tue Apr 02, 2019 12:19 am
I split this out of "release of 0.18" Dev forum topic moved it here,
can you have a look (easiest in gui) at the list of FreeCAD package dependencies? Docs is supposed to be a "suggests" not a "recommends" but treating either of those as a "depends" is an option in your package manager. By default, I think, some distros tick "treat recommands" as "depends" by default, but there are two options, on for "recommends" and one for "suggests" that are user configurable. Perhaps this is relevant on your system?
iogui
Re: Release of 0.18
Postby iogui » Tue Apr 02, 2019 1:40 am
Just an upgrade:
sudo apt get upgrade
By my experience, dist-upgrade is a little bit destructive and I always avoid it. Anyway, a simple upgrade should suffice.
(...)can you have a look (easiest in gui) at the list of FreeCAD package dependencies?(...)
$ apt-cache depends freecad
freecad
  Depende: freecad-python2
  Quebra: freecad
  Recomenda: calculix-ccx
  Recomenda: graphviz
    graphviz:i386
  Sugere: freecad-doc
  Sugere: povray
  Sugere: python-collada
  Substitui: freecad
It is listed as sugests.
I don't know but I don't think so, my system is an ubuntu 16.04 and I have not changed anything about how it should deal with "recommends" or "suggests". I always simply use apt upgrade an it uses to work. The FreeCAD package is behaving a little bit different then the usual.
BTW. FreeCAD 0.18 is indeed installed and I'm using it. But I had to give up freecad-doc package as to install it, it requeres me to uninstall freecad. In some way and I don't know why, those packages are conflicting to it-selves.
Anyway... if you want a little more info, there it goes:
$ apt-cache showpkg freecad
Package: freecad
Versions:
2:0.18+dfsg1~201903301803~ubuntu16.04.1 (/var/lib/apt/lists/ppa.launchpad.net_freecad-maintainers_freecad-stable_ubuntu_dists_xenial_main_binary-amd64_Packages) (/var/lib/apt/lists/ppa.launchpad.net_freecad-maintainers_freecad-stable_ubuntu_dists_xenial_main_binary-i386_Packages) (/var/lib/dpkg/status)
 Description Language:
                 File: /var/lib/apt/lists/ppa.launchpad.net_freecad-maintainers_freecad-stable_ubuntu_dists_xenial_main_binary-amd64_Packages
                  MD5: d0806b37ee19ba4b2b3b18d48cda12dd
 Description Language: en
                 File: /var/lib/apt/lists/ppa.launchpad.net_freecad-maintainers_freecad-stable_ubuntu_dists_xenial_main_i18n_Translation-en
0.15.4671+dfsg1-4 (/var/lib/apt/lists/br.archive.ubuntu.com_ubuntu_dists_xenial_universe_binary-amd64_Packages)
                 File: /var/lib/apt/lists/br.archive.ubuntu.com_ubuntu_dists_xenial_universe_binary-amd64_Packages
                  MD5: 55d1732b8e97faf08259c4148b4e3f24
                 File: /var/lib/apt/lists/br.archive.ubuntu.com_ubuntu_dists_xenial_universe_binary-i386_Packages
 Description Language: pt_BR
                 File: /var/lib/apt/lists/br.archive.ubuntu.com_ubuntu_dists_xenial_universe_i18n_Translation-pt%5fBR
                 File: /var/lib/apt/lists/br.archive.ubuntu.com_ubuntu_dists_xenial_universe_i18n_Translation-en
Reverse Depends:
  freecad,freecad 1:0.18~
  freecad-common,freecad 1:0.18~
  freecad-dev,freecad 0.15.4671+dfsg1-4
  freecad:i386,freecad
  science-engineering,freecad
  freecad-doc,freecad 0.15.4671+dfsg1-4
Dependencies:
2:0.18+dfsg1~201903301803~ubuntu16.04.1 - freecad-python2 (0 (null)) freecad (3 1:0.18~) freecad:i386 (3 1:0.18~) calculix-ccx (0 (null)) graphviz (0 (null)) freecad-doc (0 (null)) povray (0 (null)) python-collada (0 (null)) freecad (3 1:0.18~) freecad:i386 (3 1:0.18~) freecad:i386 (32 (null))
0.15.4671+dfsg1-4 - libsoqt4-20 (2 1.6) python-collada (0 (null)) python-matplotlib (0 (null)) python-pivy (2 0.5.0~v609hg-2) python-ply (0 (null)) python-pyside (0 (null)) pyside-tools (0 (null)) python:any (2 2.6.6-7~) python2.7 (0 (null)) libboost-program-options1.58.0 (0 (null)) libboost-regex1.58.0 (0 (null)) libboost-signals1.58.0 (0 (null)) libboost-system1.58.0 (0 (null)) libc6 (2 2.14) libcoin80v5 (0 (null)) libfreetype6 (2 2.2.1) libgcc1 (2 1:3.4) libgl1-mesa-glx (16 (null)) libgl1 (0 (null)) libglu1-mesa (16 (null)) libglu1 (0 (null)) liboce-foundation10 (0 (null)) liboce-modeling10 (0 (null)) liboce-ocaf-lite10 (0 (null)) liboce-ocaf10 (0 (null)) liboce-visualization10 (0 (null)) libpython2.7 (2 2.7) libqt4-network (2 4:4.5.3) libqt4-opengl (2 4:4.6.1) libqt4-svg (2 4:4.5.3) libqt4-xml (2 4:4.5.3) libqtcore4 (2 4:4.8.0) libqtgui4 (2 4:4.8.0) libqtwebkit4 (0 (null)) libshiboken1.2v5 (2 1.1.0) libspnav0 (2 0.2.2) libstdc++6 (2 5.2) libx11-6 (0 (null)) libxerces-c3.1 (0 (null)) libzipios++0v5 (0 (null)) zlib1g (2 1:1.1.4) freecad-doc (0 (null)) freecad:i386 (32 (null))
Provides:
0.15.4671+dfsg1-4 -
Reverse Provides:
iogui
Postby iogui » Tue Apr 02, 2019 1:59 am
I think that the problem is in the freecad-doc package. It's dependencies are strange... see:
$ apt-cache depends freecad-doc
freecad-doc
  Depende: qt4-dev-tools
It declares that depends just on qt 4 but, if you look at the result of showpkg something different rises up:
$ apt-cache showpkg freecad-doc
Package: freecad-doc
Versions:
1:0.17.13541-1ppa3~ubuntu16.04.1 (/var/lib/apt/lists/ppa.launchpad.net_freecad-maintainers_freecad-stable_ubuntu_dists_xenial_main_binary-amd64_Packages) (/var/lib/apt/lists/ppa.launchpad.net_freecad-maintainers_freecad-stable_ubuntu_dists_xenial_main_binary-i386_Packages)
                  MD5: fda477f676d3946a75bff8a54843e734
0.15.4671+dfsg1-4 (/var/lib/apt/lists/br.archive.ubuntu.com_ubuntu_dists_xenial_universe_binary-amd64_Packages) (/var/lib/apt/lists/br.archive.ubuntu.com_ubuntu_dists_xenial_universe_binary-i386_Packages)
                  MD5: 71cb85cff5b3d4bdf89c1ab6d1523bb8
Reverse Depends:
  freecad-common,freecad-doc 1:0.18~
  freecad,freecad-doc
  freecad,freecad-doc
Dependencies:
1:0.17.13541-1ppa3~ubuntu16.04.1 - qt4-dev-tools (0 (null))
0.15.4671+dfsg1-4 - qt4-dev-tools (0 (null)) freecad (5 0.15.4671+dfsg1-4)
Provides:
0.15.4671+dfsg1-4 -
Reverse Provides:
In it's dependencies freecad package is been listed as:
I'm not an apt specialist but as I know, this number 5 in front of the versions means "Equals" and it is pointing to freecad 0.15 package but till today freecad 0.17 was installed in my system living together and peacefully with freecad-doc package.
For what I know those are the codes:
0 NoOp
1 LessEq
2 GreaterEq
3 Less
4 Greater
5 Equals
6 NotEquals
16 OR
kkremitzki
Re: Release of 0.18
Postby kkremitzki » Tue Apr 02, 2019 2:23 am
In this case, it's necessary because we have to force uninstallation of an old package before we can unpack a new package since they have conflicting file paths.
jmaustpc
Postby jmaustpc » Tue Apr 02, 2019 3:53 am
no, its just that the doc package is for the old FreeCAD 0.17, the package has not yet been updated for 0.18. Its just a case of time available for those that know what to do and priorities of their limited time... i think Kurt said elsewhere that he intended to fix it shortly.
Roland
Postby Roland » Tue Apr 02, 2019 11:48 am
Hi Forum,
Perhaps we have the same problem.
I upgraded from 17 to 18 through the PPA. But FreeCAD is now dead on my system (Linux Mint 19.1 / Ubuntu 18.04). I suggest to read this review: https://forum.freecadweb.org/viewtopic. ... 10#p298604
Any advice welcome, because I need to get it running asap!
Best wishes,
Roland
iogui
Re: Release of 0.18
Postby iogui » Tue Apr 02, 2019 2:56 pm
It is not necessary, as I have already said I was able to update freecad by using apt install frecad and it forced the uninstall of freecad-doc. I've made my post just to warn that something was wrong among freecad and freecad-doc package but my system is working fine just without freecad-doc.
Ok then. I will be using freecad without the doc in the meantime.
Not the same. My freecad works just fine without the docs. It is not dead for me. And my linux is a Ubuntu 16.04.
kkremitzki
Re: Release of 0.18
Postby kkremitzki » Tue Apr 02, 2019 3:22 pm
Let me rephrase: a simple upgrade is not always sufficient, one of either a dist-upgrade/full-upgrade or manual installation is necessary.
