some toolbar icons missing on ubuntu freecad 0.18.1
jmaustpc
Re: some toolbar icons missing on ubuntu freecad 0.18.1
Postby jmaustpc » Fri Apr 26, 2019 3:28 pm
I have been missing a different two for some time.
OS: Kubuntu 18.04.2 LTS
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
curiouscow
Postby curiouscow » Sat Apr 27, 2019 11:59 pm
I had the same two icons missing until I installed the 'IconThemes' addon - that brought them back. But then I discovered that there are still more icons missing in the 'Open document' dialog.
OS: Ubuntu 18.04.2 LTS
Version: 0.18.1.
Qt version: 5.9.5
brjhaverkamp
Postby brjhaverkamp » Sun Jan 19, 2020 7:15 am
Hello all,
It has been a while since I reported the missing icon problem for 0.18. But niw I installed 0.19 daily on a new laptop and noticed the problem is still there.
This should be set correctly at start. Especially for new users this is a throw-off. First impressions are everything:-)
Kind regards,
Bert
Postby Kunda1 » Sun Jan 19, 2020 3:06 pm
Hello, please always include your full About information when posting for assistance or reporting a problem. Paste the text, not a screenshot, thank you.
triplus
Postby triplus » Sun Jan 19, 2020 3:31 pm
Hi Bert.
I plan to investigate on how to make desktop icon theme support opt-in on Linux. That is on a to-do list for a while now, just haven't have the time to look into it yet.
P.S. As the current experience usually results in people complaining. In addition people that do want to use custom icons, for that purpose i guess IconThemes module and an icon pack made for FreeCAD is the way to go.
triplus
Postby triplus » Sun Jan 26, 2020 8:14 pm
I created a PR, and now usage of Linux desktop icon theme became an opt-in experience. To enable usage of desktop icon theme navigate to:
Tools -> Edit parameters ... -> Preferences -> Bitmaps -> Theme and create a new Boolean item named ThemeSearchPaths and set it to true. Restart FreeCAD.
triplus
Postby triplus » Mon Feb 03, 2020 4:32 pm
After the discussion on the PR and some further consideration i updated the PR. After merge, here is what to expect on Linux. Starting FreeCAD, that will still pick up the default desktop icon theme and use available icons from it. This is therefore a feature and not a bug. Most people likely don't have issues with that. If for whatever reason you don't like the results:
Tools -> Edit parameters ... -> Preferences -> Bitmaps -> Theme and create a new Boolean item named ThemeSearchPaths and set it to false.
Restart FreeCAD. Now default set of FreeCAD icons should get used on Linux.
P.S. In the future, there might be a checkbox controlling this area in the IconThemes module.
bgoodr
Postby bgoodr » Thu Feb 06, 2020 6:08 am
After the discussion on the PR and some further consideration i updated the PR. After merge, here is what to expect on Linux. ...
Hi triplus,
Thanks for looking into this.
Does "after merge" mean it is not "in" yet? I read the commentary in the PR, but couldn't figure out the status.
My freecad-daily right now on my Ubuntu 19.10 machine has this version:
$ dpkg -l freecad-daily*
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                  Version                              Architecture Description
ii  freecad-daily         0.19~pre2~202002051353~ubuntu19.10.1 all          Extensible Open Source CAx program
ii  freecad-daily-common  0.19~pre2~202002051353~ubuntu19.10.1 all          Extensible Open Source CAx program - common files
un  freecad-daily-doc     <none>                               <none>       (no description available)
un  freecad-daily-python2 <none>                               <none>       (no description available)
ii  freecad-daily-python3 0.19~pre2~202002051353~ubuntu19.10.1 amd64        Extensible Open Source CAx program - Python 3 binaries
un  freecad-daily-runtime <none>                               <none>       (no description available)
Testing with both true and false values to the ThemeSearchPaths boolean had no effect, and I still see this (reported on my other thread) in the upper left corner:
triplus
Postby triplus » Thu Feb 06, 2020 6:37 pm
The PR was not merged yet and there was an additional feedback provided in the PR discussion i need to take a look at.
