Hi all,
I installed FreeCAD 18,1 form the PPA today but hey presto, I only get basic 4 menus and no workbenches whatsoever.
Launch Log:
Msg: FreeCAD 0.18.1, Libs: 0.18.1R
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Log: Time = Sun Apr 14 09:10:39 2019
Log: AppDataSkipVendor = true
Log: AppHomePath = /usr/lib/freecad/
Log: AppIcon = freecad
Log: AppTempPath = /tmp/
Log: BinPath = /usr/lib/freecad/bin/
Log: BuildRepositoryURL = https://code.launchpad.net/~vcs-imports/freecad/trunk
Log: BuildRevision =
Log: BuildRevisionDate = 2019/04/06 19:19:55
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 18.1
Log: Console = 0
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Log: Debug = 0
Log: DocPath = /usr/lib/freecad/doc/
Log: ExeName = FreeCAD
Log: ExeVendor = FreeCAD
Log: ExeVersion = 0.18.1
Log: LoggingFile = 1
Log: LoggingFileName = /home/<beeeep>/.FreeCAD/FreeCAD.log
Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page
Log: PATH = /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
Log: PYTHONPATH =
Log: PythonSearchPath = /usr/lib/python36.zip:/usr/lib/python3.6:/usr/lib/python3.6:/usr/lib/python3.6/lib-dynload
Log: RunMode = Gui
Log: SplashAlignment = Bottom|Left
Log: SplashInfoColor = #c8c8c8
Log: SplashScreen = freecadsplash
Log: SplashTextColor = #ffffff
Log: StartWorkbench = StartWorkbench
Log: SystemParameter = /home/<beeeep>/.FreeCAD/system.cfg
Log: UserAppData = /home/<beeeep>/.FreeCAD/
Log: UserHomePath = /home/<beeeep>
Log: UserParameter = /home/<beeeep>/.FreeCAD/user.cfg
Log: Verbose =
Log: Create Application
Log: Run App init script
Log: Init: starting App::FreeCADInit.py
Log: Init: Searching for modules...
Log: Init: Initializing /usr/lib/freecad/Mod/FCGear(Init.py not found)... ignore
Log: Using /usr/lib/freecad/Mod as module path!
Log: System path after init:
Log: /usr/lib/freecad/bin
Log: /usr/lib/freecad/Mod/FCGear
Log: /usr/local/sbin
Log: /usr/local/bin
Log: /usr/sbin
Log: /usr/bin
Log: /sbin
Log: /bin
Log: /usr/games
Log: /usr/local/games
Log: /snap/bin
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: Local server 'FreeCAD' started
Log: OpenGL version is: 4.6 (4.6.0 NVIDIA 390.116)
Log: Run Gui init script
Log: Init: Running FreeCADGuiInit.py start script...
Log: Init: Searching modules...
Log: Module: Part
Log: Loading Part module... done
Log: Init: Initializing /usr/lib/freecad/Mod/FCGear... done
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Init: Showing main window
Log: Main window restored
Log: Show main window
Log: Toolbars restored
Log: Couldn't connect to spacenav daemon
Log: Init: Entering event loop
Log: Init: Processing command line files
Log: Hide main window
Log: Finish: Event loop left
Log: Destruct Gui::Application
Log: Couldn't disconnect from spacenav daemon
Log: FreeCAD terminating...
Log: Saving system parameter...
Log: Saving system parameter...done
Log: Saving user parameter...
Log: Saving user parameter...done
Greetings
