Failed to load module "appmenu-gtk-module"
doubters
Postby doubters » Sun Apr 14, 2019 1:13 pm
FreeCAD from .appimage of new versions does not use the GTK-theme and at the start gives the following warning:
Gtk-Message: 15:14:33.586: Failed to load module "appmenu-gtk-module"
Gtk-Message: 15:14:33.586: Failed to load module "gail"
Gtk-Message: 15:14:33.586: Failed to load module "atk-bridge"
What could be the reason?
System:
Linux pc 4.15.0-42-generic #45-Ubuntu SMP Thu Nov 15 19:32:57 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Distributor ID: Ubuntu
Description: Ubuntu 18.04.2 LTS
Release: 18.04
Codename: bionic
WM: Xfwm4
DE: XFCE
old.png - launch .appimage 0.18.16093 Git
new.png - launch .appimage 0.18 stable
NormandC
Re: Failed to load module "appmenu-gtk-module"
Postby NormandC » Sun Apr 14, 2019 2:53 pm
Confirmed on Ubuntu 18.04/GNOME.
Here's a more detailed output at launch. I also notice it takes a longer time to load the splash screen.
$ ./FreeCAD_0.18_stable.AppImage /tmp/.mount_FreeCATTS59b
FreeCAD 0.18, Libs: 0.18R14555 (Git shallow)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Sheet Metal workbench loaded
Gtk-Message: 10:44:23.579: Failed to load module "gail"
Gtk-Message: 10:44:23.579: Failed to load module "atk-bridge"
Gtk-Message: 10:44:23.590: Failed to load module "canberra-gtk-module"
(FreeCAD:4004): GdkPixbuf-WARNING **: 10:44:37.132: Cannot open pixbuf loader module file '/home/travis/build/FreeCAD/FreeCAD-AppImage/conda/linux_stable/AppDir/usr/lib/gdk-pixbuf-2.0/2.10.0/loaders.cache': No file or folder of this type
This likely means that your installation is broken.
Try running the command
  gdk-pixbuf-query-loaders > /home/travis/build/FreeCAD/FreeCAD-AppImage/conda/linux_stable/AppDir/usr/lib/gdk-pixbuf-2.0/2.10.0/loaders.cache
to make things work again for the time being.
Even though the message indicates "your installation is broken", a quick test shows it to be functioning normally.
triplus
Postby triplus » Sun Apr 14, 2019 3:46 pm
doubters
Postby doubters » Sun Apr 14, 2019 8:18 pm
Best to provide feedback here:
https://forum.freecadweb.org/viewtopic.php?f=10&t=34981
Maybe move this topic there entirely?
