Postby SamoZ » Tue Apr 23, 2019 7:38 am
Thanks for the quick response.
I am very well aware of the nature of this project and the limitations. From my point of view, it is the most serious problem that I can not make at least a decent technical drawing, which is as harmonized as possible to some standard (ISO I know very well) if I am already trying to make a 3D model. FreeCAD is primarily a technical application that should be used by users oriented in this direction.
Therefore, it would be appropriate to follow the latest technical standards when finishing up the final drawings (it is strongly recommended that the best ISO/ASME). It is not logical to create some new styles, rules, and tools in the program past these standards. For start, you do not need to enforce all the options of the possible ones in the standards, but at least the most commonly used ones (for example, the standards define several types of dimensioning arrows, the sharpest are the most common and sufficient for start). However, for some functions, the possibility for setting some of the important options are critical (for example, selecting line thicknesses, line types, projection scales...). Drawing of correctly marked sections, hatching surfaces, etc. is also very important.
If we prioritized the problems listed in the TechDraw (TD) module, then the DrawingDimensioning (DD) module would not be needed anymore. Currently, with DD I can do more and more correctly than the TD module. In fact, you should unite some things and improve them a bit, and in this way you could solve over 90% of problems with technical drawings (not optimal, but nevertheless). In the foreseeable future, I can describe in a little bit more detail what anh how would have to be minimally edited in the TD module in order to follow the logic of the technical drawing rules (at least according to ISO, which is almost the same as ASME), if, of course, you want.
