FreeCAD debug build with apeltauer's libpack builds release instead
DeepSOIC
Postby DeepSOIC » Fri Apr 26, 2019 11:11 pm
--<original problem - the problem changed, see later posts>--
Hi
Big thanks to @apeltauer for new libpack.
Today, I upgraded my toolchain, and I have (after quite a lot of messing around) managed to do a debug build FreeCAD. It had built, but now it just won't run.
I launch it, and it pops up with an error message:
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
I don't know, how to deal with it. Any clues?
Call stack:
1  QCoreApplicationPrivate::qmljsDebugArgumentsString                  Qt5Core                                 0x7fff9c308858
2  QMessageLogger::fatal                                               Qt5Core                                 0x7fff9c306ac1
3  QGuiApplicationPrivate::init                                        Qt5Gui                                  0x7fff9b2c451d
4  QGuiApplicationPrivate::createPlatformIntegration                   Qt5Gui                                  0x7fff9b2c219d
5  QGuiApplicationPrivate::createEventDispatcher                       Qt5Gui                                  0x7fff9b2c1b6b
6  QCoreApplicationPrivate::init                                       Qt5Core                                 0x7fff9c4a86c2
7  QGuiApplicationPrivate::init                                        Qt5Gui                                  0x7fff9b2c31cd
8  QApplicationPrivate::init                                           Qt5Widgets                              0x7fff9c8e3e2f
9  QApplication::QApplication                                          Qt5Widgets                              0x7fff9c8e011b
10 Gui::GUIApplicationNativeEventAware::GUIApplicationNativeEventAware GuiApplicationNativeEventAware.cpp 65   0x7fffa64016ac
11 Gui::GUISingleApplication::GUISingleApplication                     GuiApplication.cpp                 238  0x7fffa63ff82b
12 Gui::Application::runApplication                                    Application.cpp                    1653 0x7fffa635ada0
13 image00007ff7_d3340000        0x7ff7d33442f7
14 image00007ff7_d3340000        0x7ff7d3345754
15 image00007ff7_d3340000        0x7ff7d3344bda
16 BaseThreadInitThunk                                                 KERNEL32                                0x7fffeacf7974
17 RtlUserThreadStart                                                  ntdll                                   0x7fffed79a271
Microsoft Visual C++ Compiler 16.0.28803.202 (amd64) (AKA MSVC2019, I think)
CMake 3.14.3-win64
libpack 12.1.2
IDE: Qt Creator 4.9.0 Based on Qt 5.12.2 (MSVC 2017, 64 bit)
Also, peculiarly, when I run with debugger, Qt Creator bugs me with an alert that it doesn't look like a debug build. And the executable is named "FreeCAD.exe", not "FreeCAD_d.exe" like it used to be.
DeepSOIC
Re: FreeCAD debug build with apeltauer's libpack fails to run
Postby DeepSOIC » Fri Apr 26, 2019 11:24 pm
found this:
https://stackoverflow.com/questions/541 ... -initializ
And followed a suggestion to copy <libpack>\bin\Lib\site-packages\PySide2\plugins\platforms to bin (so that paths are bin/platforms/some.dll). Now FreeCAD runs, but looks ugly (like it came from win98 era).
It is indeed a release build, even though I have "debug" build set in cmakecache.txt
OS: Windows 10 (10.0)
Version: 0.18.15780 +2 (Git)
Branch: shapebinder_fix (wrong!! it's FC master)
Hash: 96f927fd97984add46042bf1cb7d594548f57995 (possibly, wrong)
Python version: 3.6.8
Qt version: 5.12.1
Locale: Russian/Russia (ru_RU)
DeepSOIC
Re: FreeCAD debug build with apeltauer's libpack builds release instead
Postby DeepSOIC » Sat Apr 27, 2019 12:24 am
Full command line of compiler invocation
C:\PROGRA~2\MICROS~2\2019\BUILDT~1\VC\Tools\MSVC\1420~1.275\bin\HostX64\x64\cl.exe  /nologo /TP -DBUILD_ADDONMGR -DCMAKE_BUILD_TYPE=\"Release\" -DCOIN_DLL -DFCGui -DFreeCADGui_EXPORTS
PYSIDE2 -DHAVE_SHIBOKEN2 -DOVR_OS_WIN32 -DQIIS_MAKEDLL -DQSINT_MAKEDLL -DQT_CORE_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_NO_DEBUG -DQT_OPENGL_LIB -DQT_PRINTSUPPORT_LIB -DQT_SVG_LIB -DQT_UITOOLS_LIB -DQT_WIDGETS_LIB -DQT_XML_LIB -DQUARTER_INTERNAL -DQUARTER_MAKE_DLL -DUNICODE -D_CRT_NONSTDC_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_OCC64 -D_PreComp_ -D_UNICODE -D_USE_3DCONNEXION_SDK -Isrc -IS:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src -I. -IS:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Gui -IS:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Gui\Quarter -Isrc\Gui -IS:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Gui\.. -Isrc\Gui\.. -Isrc\Gui\Language -Isrc\Gui\propertyeditor -Isrc\Gui\TaskView -Isrc\Gui\Quarter -Isrc\Gui\DAGView -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\eigen3 -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\bin\Include -IS:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\3rdParty\OpenGL\api -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\lib\cmake\Shiboken2-5.12.2\..\..\..\include\shiboken2 -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\lib\cmake\PySide2-5.12.2\..\..\..\include\PySide2 -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\lib\cmake\PySide2-5.12.2\..\..\..\include\PySide2\QtCore -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\lib\cmake\PySide2-5.12.2\..\..\..\include\PySide2\QtGui -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\lib\cmake\PySide2-5.12.2\..\..\..\include\PySide2\QtWidgets -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtCore -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\.\mkspecs\win32-msvc -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtWidgets -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtGui -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtANGLE -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtOpenGL -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtPrintSupport -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtSvg -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtNetwork -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtUiTools -IS:\_vt\dev\PC\Qt\FreeCAD\libpack\12.1.2\include\QtXml /DWIN32 /D_WINDOWS /W3 /GR /EHsc -D_OCC64 /MD /O2 /Ob2 /DNDEBUG /Zm150 /Zi /EHa   /Yu"PreCompiled.h" /FI"S:/_vt/dev/PC/Qt/FreeCAD/build-FreeCAD-ellipse-FC64-ttt/src/Gui/FreeCADGui.pch" /Fp"S:/_vt/dev/PC/Qt/FreeCAD/build-FreeCAD-ellipse-FC64-ttt/src/Gui/FreeCADGui.pch" /showIncludes /Fosrc\Gui\CMakeFiles\FreeCADGui.dir\Splashscreen.cpp.obj /Fdsrc\Gui\CMakeFiles\FreeCADGui.dir\ /FS -c S:\_vt\dev\PC\Qt\FreeCAD\FreeCAD-ellipse\src\Gui\Splashscreen.cpp
Postby wmayer » Sat Apr 27, 2019 12:36 pm
Is this a fresh build directory or was it used for your old libpack & toolchain configuration? And are you 100% sure that CMAKE_BUILD_TYPE is set to Debug?
In case you are certain that all the above can be excluded you maybe should try an older CMake version because in the forum some people (including me) had problems with this version. At the moment I use version 3.11 which works flawlessly for me.
Now if all this still doesn't help you can try the following workaround: instead of using nmake, jom or ninja as build system create VisualStudio projects. From the command line you can build the debug version with:
msbuild FreeCAD_trunk.sln /m /p:Configuration=Debug
And to debug the application just start it and use QtCreator's function to attach its debugger to a running application.
Since Qt5 an application requires one of the available platform plugins. The easiest is to create the sibling directory platforms of the executable and put inside qwindows.dll and qwindowsd.dll.
This is because Qt requires some more plugins. I cannot tell you exactly which plugin dll is responsible to make the application look nice so I put all the Qt plugin directories into the bin folder.
Btw, in order to use the StartPage you also have to copy QtWebEngineProcess.exe and QtWebEngineProcessd.exe to the bin directory, copy the resources directory (that contains icudtl.dat, ..., qtwebengine_resources_200p.pak) to the parent of the bin directory, copy the translations directory there too and create the file qt.conf inside the bin directory. Its content should be:
[Paths]
Prefix=..
DeepSOIC
Postby DeepSOIC » Sat Apr 27, 2019 12:59 pm
Yes, and yes, I have tried starting from scratch twice. In the .ninja file, however, I clearly see build-type="Release" in the header.
It seems like I can debug freecad even in release build, so if I fail to make a debug build, that will still work.
Will try, I have been using cmake 3.11 previously, but I updated it because of my screwup actually. I had quite a number of screwups in the process. Forgetting to update the source, launching old qt creator that would mess with newer one's compiler settings, pointing Qt creator at a very old cmake are among the most epic.
<more suggestions>
thanks! I don't care about start page, but the suggestion may be very handy for someone who does.
Postby wmayer » Sat Apr 27, 2019 1:11 pm
Did you also use ninja in the past? As far as I remember there are/were some issues with ninja and QtCreator. I use jom and never had problems with it.
We have added the option to put some minimum debug information also into a release build (see FREECAD_RELEASE_PDB) which can be very helpful to debug a crash on a client's machine and that sends you the crash dump file. However, don't expect too much since usually the content of variables show garbage values.
DeepSOIC
Postby DeepSOIC » Sat Apr 27, 2019 3:50 pm
I don't know :oops: , probably not. I don't even know, who is ninja. It was the default. I have tried switching generator to visual studio 2017, 2019 and nmake (in QT Creator's "kit"), but the result was apparently a cmake crash: I get this in qt creator:
Running "S:\Qt\cmake3-14-3\bin\cmake.exe -E server "--pipe=\\.\pipe\{2d4c5458-6a7f-42ff-aebc-241cb4705692}" --experimental" in S:\_vt\dev\PC\Qt\FreeCAD\build-FreeCAD-ellipse-FC64-ttt.
CMake Project parsing failed.
Parsing of CMake project failed: Connection to CMake server lost.
DeepSOIC
Postby DeepSOIC » Wed May 01, 2019 8:48 pm
Used CMake 3.11.0, generator "NMake makefiles"/Codeblocks this time instead of ninja. With this cmake, it works. But I still get a release build :cry:
Here's CMake output:
Running "S:\Qt\cmake3110\bin\cmake.exe -E server "--pipe=\\.\pipe\{eae7cda8-e0fc-4e56-8a8d-6a66121ffd15}" --experimental" in S:\_vt\dev\PC\Qt\FreeCAD\build-debug.
Starting to parse CMake project.
Compiler: MSVC, version: 19.20.27508.1
prefix: C:/Program Files (x86)/FreeCAD_trunk
datadir: data
docdir: doc
includedir: include
libdir: lib
cmake: 3.11.0
CMake Warning at CMakeLists.txt:328 (message):
  BUILD_OPENSCAD requires BUILD_MESH_PART;BUILD_DRAFT each be ON, but
  BUILD_MESH_PART is "OFF"
Call Stack (most recent call first):
  CMakeLists.txt:346 (REQUIRES_MODS)
PyCXX found:
  Headers:  S:/_vt/dev/PC/Qt/FreeCAD/FreeCAD-ellipse/src
  Sources:  S:/_vt/dev/PC/Qt/FreeCAD/FreeCAD-ellipse/src/CXX
  Version:  6.2.8
Boost version: 1.67.0
Found the following Boost libraries:
  filesystem
  program_options
  regex
  system
  thread
  chrono
  date_time
  atomic
Found Xerces-C: S:/_vt/dev/PC/Qt/FreeCAD/libpack/12.1.2/lib/xerces-c_3.lib
PyCXX found:
  Version:  6.2.8
-- Found OCE/OpenCASCADE version: 7.3.0
-- OCE/OpenCASCADE include directory: S:/_vt/dev/PC/Qt/FreeCAD/libpack/12.1.2/inc
-- OCE/OpenCASCADE shared libraries directory: S:/_vt/dev/PC/Qt/FreeCAD/libpack/12.1.2/lib
Shiboken2Config: Using default python: .cp36-win_amd64
SHIBOKEN_PYTHON_INCLUDE_DIRS computed to value: 'S:/_vt/dev/PC/Qt/FreeCAD/libpack/12.1.2/bin/Include'
SHIBOKEN_PYTHON_LIBRARIES computed to value: 'S:/_vt/dev/PC/Qt/FreeCAD/libpack/12.1.2/bin/libs/python36.lib'
libshiboken built for Release
SHIBOKEN_INCLUDE_DIR: S:/_vt/dev/PC/Qt/FreeCAD/libpack/12.1.2/lib/cmake/Shiboken2-5.12.2/../../../include/shiboken2
SHIBOKEN_LIBRARY: optimized;S:/_vt/dev/PC/Qt/FreeCAD/libpack/12.1.2/lib/cmake/Shiboken2-5.12.2/../../shiboken2.cp36-win_amd64.lib;debug;S:/_vt/dev/PC/Qt/FreeCAD/libpack/12.1.2/lib/cmake/Shiboken2-5.12.2/../../shiboken2_d_d.cp36-win_amd64.lib
PYSIDE_LIBRARY: optimized;S:/_vt/dev/PC/Qt/FreeCAD/libpack/12.1.2/lib/cmake/PySide2-5.12.2/../../pyside2.cp36-win_amd64.lib;debug;S:/_vt/dev/PC/Qt/FreeCAD/libpack/12.1.2/lib/cmake/PySide2-5.12.2/../../pyside2_d.cp36-win_amd64_d.lib
PYSIDE_PYTHONPATH: S:/_vt/dev/PC/Qt/FreeCAD/libpack/12.1.2/Lib/site-packages/PySide2
-- matplotlib-3.0.3 has been found.
Platform is 64-bit, set -D_OCC64
Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
Now run 'make' to build FreeCAD
Configuring done
Generating done
CMake Project was parsed successfully.
There is a slightly suspicious line there, "libshiboken built for Release".
See also CMakeCache.txt:
CMakeCache.txt
(41.7 KiB) Downloaded 94 times
apeltauer
Postby apeltauer » Thu May 02, 2019 5:03 am
Sorry for the question, but why dont you use visual studio?
Postby wmayer » Thu May 02, 2019 8:18 am
  1. You need to activate it after the trial period and therefore need a MS account which not everybody wants to do
  2. VS takes another couple of GB on your HD while QtCreator needs << 500 MB
  3. IntelliSense in QtCreator works much better than in VS -- at least compared to older versions of VS
