Configure Error:Unknown CMake command "fc_wrap_cpp".
tak
Re: Configure Error:Unknown CMake command "fc_wrap_cpp".
Postby tak » Fri May 10, 2019 8:59 am
tak wrote:
Fri May 10, 2019 8:42 am
apeltauer wrote:
Fri May 10, 2019 8:00 am
Good to hear that the compilation worked.
Now you have to copy all files and folder from the libpack to your cmake build directory. (The folder structure needs to be the same then in the libpack)
The following folders are not mandatory to run FreeCAD:
  • cmake
  • inc
  • include
  • lib
Then FreeCAD.exe should run...
I big step forward now.
I copy all libpack file to the cmake build directory.
I can build and run the exe.
it can open the loading page.
https://imgur.com/uewYteR
but after a few second. the loading page is disappear and no software popup. The image is the last screen of the loading page.
I found that there is a folder call "Tux" under "Mod". if I delete it, FC is working fine. Is "Tux" a important mod? Can I work without it?
