[Solved]Black screen by starting first document
Build-0-Matic
Re: [Solved]Black screen by starting first document
Post by Build-0-Matic »
That's kinda strange... on my version of 0.18 the opengl32sw.dll file is nowhere to be found?
Russ4262 wrote: Fri Jan 03, 2020 3:37 pm Can either of you, or another moderator, add this solution, or a link hereto, to the "Known issues page for Windows users"?
Done so on Dec 21:
chrisb wrote: Sat Dec 21, 2019 12:25 am Thanks for this solution. Excellent that it works for Qt5 as well! I added it to the Known OS specific issues.
Trazus56
Post by Trazus56 »
Thank you so much @Build-0-Matic !!!
I copied "opengl32.dll" into the mentioned "bin" folder and the FreeCAD 0.18 black screen problem was instantly fixed / On Windows 10. What a joy you gave me!
Build-0-Matic
I'm really glad to help :)
triplus
Post by triplus »
And why doesn't Microsoft fix this issue, was the issue already reported to them?
P.S. As Windows 10 is still officially supported.
Laurie Hartley
Post by Laurie Hartley »
It worked for me also on Windows 10 - I just downloaded the 64 bit version, extracted it “here” (the download folder) then copied and pasted it into the bin folder. Thanks Build-O-Matic - what a great forum this is. :D
nickM
Post by nickM »
Big thanks for this dll fix. Works a treat
fourchette
Post by fourchette »
Build-0-Matic wrote: Fri Dec 20, 2019 10:38 pm For FreeCAD, just copy the modified opengl32.dll into the Program Files\FreeCAD 0.18\bin folder.
https://fdossena.com/?p=mesa/index.frag
man... you just made my day! :D
Henkjan
Post by Henkjan »
Thanks a lot @Build-O-Matic , this also also fixed my FreeCAD :D
Build-0-Matic wrote: Fri Dec 20, 2019 10:38 pm .....
The issue seems to be mainly with embedded graphics accelerators.
Here is the link to the DLL file.
The file is compiled by Federico Dossena and not me.
This issue also occurs in other software, e.g. KiCAD as well (needed a workaround there also)
aryehl
Post by aryehl »
Build-O-Matic did it!
:D
Thanks so much!
Aryeh
