macOS build instructions - outdated?
Chamfer036
Postby Chamfer036 » Sun May 05, 2019 2:31 pm
Hello!
I am trying to build the latest Git version on macOS High-Sierra, and it seems that the instructions are outdated, I followed:
* https://www.freecadweb.org/wiki/Developer_hub -> Compiling on Mac OS X
* https://www.freecadweb.org/wiki/CompileOnMac
Then when I try to follow the instructions to install the dependencies:
% brew tap homebrew/science
Updating Homebrew...
Error: homebrew/science was deprecated. This tap is now empty as all its formulae were migrated.
Is there more up to date instructions somewhere? I would be happy to help testing that with a pair of fresh eyes
Thanks!
triplus
Re: macOS build instructions - outdated?
Postby triplus » Mon May 06, 2019 7:42 pm
Hi @Chamfer036
Yes, likely currently macOS build instructions are outdated and dependencies likely aren't in optimal condition.
P.S. Contributions welcome.
Chamfer036
Postby Chamfer036 » Mon May 06, 2019 8:02 pm
Hi triplus,
How are the macOS builds generated then? Is it a developper with a macOS system or an automated build system somewhere?
triplus
Postby triplus » Mon May 06, 2019 8:46 pm
Currently we, Travis is doing that, are repacking packages available from Conda.
Chamfer036
Postby Chamfer036 » Tue May 07, 2019 7:28 pm
Interesting! Do you have any pointer to the job, or anything can could help me to narrow down to the actual macOS build process?
I can see https://github.com/FreeCAD/FreeCAD/blob ... travis.yml that the macOS build are failing:
 # macOS build is failing. See: https://forum.freecadweb.org/viewtopic.php?f=10&t=32272
looo
Postby looo » Tue May 07, 2019 8:04 pm
It's as simple as this:
I increase the build-number here: https://github.com/looooo/freecad-feeds ... e847096b93
this triggers different ci's and creates conda packages: https://anaconda.org/freecad/freecad/fi ... n=0.19.pre
appimage-tools is run every day and creates bundles here: https://github.com/FreeCAD/FreeCAD-AppImage
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
triplus
Postby triplus » Wed May 08, 2019 10:54 am
@looo explained situation regarding Conda packages. AFAIK you can use Conda for FreeCAD compiling purposes. Therefore if you would like to compile FreeCAD, due to being interested in FreeCAD development. Conda could be used for that.
The link you gave is a different thing. That is for crating macOS builds directly on Travis, for CI purposes and for deploying the .dmg files to GitHub releases, without involving Conda. This worked well in the past and the Homebrew set of dependencies was kept in good condition. People being involved in this effort in the past don't have time anymore, and that is why it isn't working ATM.
Chamfer036
Postby Chamfer036 » Wed May 08, 2019 2:18 pm
Thanks triplus, I'll have a look at Conda!
triplus
Postby triplus » Wed May 08, 2019 2:40 pm
You're welcome.
Chamfer036
Postby Chamfer036 » Wed May 08, 2019 2:51 pm
Looks like the build works (at least it has started :lol: ) with the instructions at
just by ignoring the
step.
I'll follow up on this and if the build is successful will request a wiki account to correct that
