Windows 10 Build, OpenCamLib
apeltauer
Postby apeltauer » Thu May 09, 2019 6:41 am
Hi all,
with the latest code stand from the github repository on the main branch, i get the following error when running the unit tests:
  File "C:\Work\FreeCAD_GitHub_Apeltauer\bin_release\Mod\Test\Workbench.py", line 44, in testActivate
    self.assertEqual(FreeCADGui.activeWorkbench().name(), i, "Test on activating workbench {0} failed".format(i))
  File "C:\Work\FreeCAD_GitHub_Apeltauer\bin_release\bin\lib\unittest\case.py", line 829, in assertEqual
    assertion_func(first, second, msg=msg)
  File "C:\Work\FreeCAD_GitHub_Apeltauer\bin_release\bin\lib\unittest\case.py", line 1203, in assertMultiLineEqual
    self.fail(self._formatMessage(msg, standardMsg))
  File "C:\Work\FreeCAD_GitHub_Apeltauer\bin_release\bin\lib\unittest\case.py", line 670, in fail
    raise self.failureException(msg)
AssertionError: 'PartDesignWorkbench' != 'PathWorkbench'
- PartDesignWorkbench
+ PathWorkbench
 : Test on activating workbench PathWorkbench failed
During handling of the above exception, another exception occurred:
  File "C:\Work\FreeCAD_GitHub_Apeltauer\bin_release\bin\lib\unittest\case.py", line 59, in testPartExecutor
    yield
  File "C:\Work\FreeCAD_GitHub_Apeltauer\bin_release\bin\lib\unittest\case.py", line 605, in run
    testMethod()
  File "C:\Work\FreeCAD_GitHub_Apeltauer\bin_release\Mod\Test\Workbench.py", line 46, in testActivate
    self.fail("Loading of workbench '{0}' failed: {1}".format(i, e))
AssertionError: Loading of workbench 'PathWorkbench' failed: 'PartDesignWorkbench' != 'PathWorkbench'
+ PathWorkbench
I am using the LibPack Version 12.1.2. This libpack does not include OpenCamLib. Do we have to added it?
I already tried to compile it but stopped with the following error in cmake when the option "BUILD_PY_LIB" is active:
Boost version: 1.67.0
Boost include path: D:/FreeCAD_3rd_Part/boost_1_67_0
Could not find the following static Boost libraries:
        boost_python36
My version
OS: Windows 10 (10.0)
Version: 0.19.16681 (Git)
Branch: master_remote
Hash: 2876e82faafba00e3b59b6e5e5d177c56bac2a03
Python version: 3.6.8
Qt version: 5.12.1
Locale: English/Germany (en_DE)
Site Admin
Re: Windows 10 Build, OpenCamLib
Postby wmayer » Thu May 09, 2019 9:28 am
I think this should be reported to the Path devs. To it seems that OpenCamLib is not a mandatory 3rd party lib/tool and thus it shouldn't block the whole wb if it's not available.
apeltauer
Postby apeltauer » Thu May 09, 2019 11:27 am
created a topic in the Path/CAM sub forum
https://forum.freecadweb.org/viewtopic.php?f=15&t=36239
