I installed FC from AUR (https://aur.archlinux.org/packages/freecad/):
OS: Manjaro Linux
Version: 0.18.16117 (Git)
Branch: makepkg
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.7.3
Qt version: 5.12.3
I only used the Path Design WB so far and everything worked fine. Recently I wanted to try out the Path WB but here nothing seems to work.
When I try to open the tool editor, a message appears on the bottom but no window opens. This is what I get in the terminal:
Running the Python command 'Path_ToolLibraryEdit' failed:
File "/usr/lib/freecad/Mod/Path/PathScripts/PathToolLibraryManager.py", line 627, in Activated
self.edit()
File "/usr/lib/freecad/Mod/Path/PathScripts/PathToolLibraryManager.py", line 609, in edit
editor = EditorPanel(job, cb)
File "/usr/lib/freecad/Mod/Path/PathScripts/PathToolLibraryManager.py", line 397, in __init__
self.loadTable()
File "/usr/lib/freecad/Mod/Path/PathScripts/PathToolLibraryManager.py", line 460, in loadTable
self.form.ToolsList.setModel(tooldata)
'PySide2.QtWidgets.QDialog' object has no attribute 'ToolsList'
Running the Python command 'Path_Job' failed:
File "/usr/lib/freecad/Mod/Path/PathScripts/PathJobCmd.py", line 64, in Activated
dialog = PathJobDlg.JobCreate()
File "/usr/lib/freecad/Mod/Path/PathScripts/PathJobDlg.py", line 55, in __init__
self.dialog.templateGroup.hide()
'PySide2.QtWidgets.QDialog' object has no attribute 'templateGroup'
