QtXmlPatterns Available in Travis Win Build?
wandererfan
Post by wandererfan »
We're having some trouble debugging PR 2238. Builds & tests fine in Linux, but we get a failure for Win:
c:\users\travis\build\freecad\freecad\src\mod\techdraw\app\qdomnodemodel.h(4): fatal error C1083: Cannot open include file: 'QAbstractXmlNodeModel': No such file or directory [C:\Users\travis\build\FreeCAD\FreeCAD\build\src\Mod\TechDraw\App\TechDraw.vcxproj]
Does anybody know how to tell if Qt XML Patterns is available in Travis Win builds?
Thanks,
wf
sgrogan
Re: QtXmlPatterns Available in Travis Win Build?
Post by sgrogan »
wandererfan wrote: Sat Jun 08, 2019 10:18 pm el': No such file or directory [C:\Users\travis\build\FreeCAD\FreeCAD\build\src\Mod\TechDraw\App\TechDraw.vcxproj]
Yes, it's in the Libpack used.
"fight the good fight"
abdullah
Post by abdullah »
wandererfan wrote: Sat Jun 08, 2019 10:18 pm We're having some trouble debugging PR 2238. Builds & tests fine in Linux, but we get a failure for Win:
Thanks,
wf
This is the content of the freecadlibs library:
FreeCADLibs/include/QtXmlPatterns$ ls
5.12.1                     qabstractxmlnodemodel.h  qsourcelocation.h       qtxmlpatternsversion.h  QXmlNamePool        qxmlresultitems.h      qxmlserializer.h
QAbstractMessageHandler    QAbstractXmlReceiver     QtXmlPatterns           QXmlFormatter           qxmlnamepool.h      QXmlSchema
qabstractmessagehandler.h  qabstractxmlreceiver.h   qtxmlpatterns-config.h  qxmlformatter.h         QXmlNodeModelIndex  qxmlschema.h
QAbstractUriResolver       QSimpleXmlNodeModel      QtXmlPatternsDepends    QXmlItem                QXmlQuery           QXmlSchemaValidator
qabstracturiresolver.h     qsimplexmlnodemodel.h    qtxmlpatternsglobal.h   QXmlName                qxmlquery.h         qxmlschemavalidator.h
QAbstractXmlNodeModel      QSourceLocation          QtXmlPatternsVersion    qxmlname.h              QXmlResultItems     QXmlSerializer
May this be related to caps?
I see the build error in Travis:
CMake does not need to re-run because C:/Users/travis/build/FreeCAD/FreeCAD/build/src/Mod/TechDraw/App/CMakeFiles/generate.stamp is up-to-date.
  QDomNodeModel.cpp
May this be cmake related?
tpavlicek
Post by tpavlicek »
Hi to all,
sorry, I was without access to my computer during the weekend. @Abdullah Yes, I am quite sure the missing QAbstractXmlNodeModel header is the problem and as was pointed out, the QXmlPatterns library + all headers needed is present in the libpack. Maybe tomorrow I will be able to get my hands on a Windows machine with VS 2015 installed, so I will try the Windows build and hopefully find out what's going on.
Thanks to all of you for help and support, I am sorry for the inconvenience,
Tomas
Post by wmayer »
wandererfan wrote: Sat Jun 08, 2019 10:18 pm Does anybody know how to tell if Qt XML Patterns is available in Travis Win builds?
As it OK to merge the PR as soon as the Win issues are fixed?
wandererfan
wmayer wrote: Sun Jun 09, 2019 10:38 pm As it OK to merge the PR as soon as the Win issues are fixed?
Better to wait. Still some minor issues - https://forum.freecadweb.org/viewtopic. ... 43#p313088
apeltauer
Post by apeltauer »
Just a hint from my side.
Do we need to add the xml stuff by the cmake config??
Ps: right know I have no access to my machine, just cell phone, otherwise I just looked by myself...
tpavlicek
Post by tpavlicek »
Hello,
finally, the Windows build is successful :-) Thanks all of you for helping hands!
There were several problems, but the important ones were:
  • There is a difference in CMake treatment between Qt4 and Qt5. Qt4 uses QT_QTXMLPATTERNS_INCLUDE_DIR + QT_QTXMLPATTERNS_LIBRARY, while Qt5 sets Qt5XmlPatterns_INCLUDE_DIRS and Qt5XmlPatterns_LIBRARIES.
  • Windows DLLs require __declspec(dllexport) / __declspec(dllimport) depending on whether the DLL functions are exported resp. imported.This needs to be declared directly in the class definition.
Once again thanks and sorry for inconvenience,
Tomas
wandererfan
tpavlicek wrote: Mon Jun 10, 2019 11:38 am finally, the Windows build is successful :-) Thanks all of you for helping hands!
Terrific!
I've pushed a fix for Annotations to your branch and Travis is running now. Maybe we want to squash some commits to make the history cleaner?
I don't have a solution for existing custom Templates. They need to have their font sizes adjusted, yes? Can we write a little script to do this?
tpavlicek
Post by tpavlicek »
Hi WandererFan,
sure no problem with squashing the commits - at least for these with CMake changes this is more than desirable. As for the custom templates, let me take a look on them, definitely the new Russian templates must be updated as well and have the xml:space="preserve" attribute removed from the <text> elements.
Kind regards,
Tomas
PS: Thanks for Your additional fixes!
